Hi, my 1-button system off/on example works perfectly fine on nRF52 DK. However, when I move the exact same code to nRF52805, there are some errors.
I choose pin 21 as the system off/on pin. By default, pin 21 is a reset pin. So firstly, according to this link (see the verified answer), I removed the default reset pin function. Then, I build & run the application code to nRF52805.
By using RTT viewer, I found that the code doesn't execute bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler). It's NOT an issue on nRF52 DK. But nRF52805 has this issue.
I attached my entire project code here in a ZIP file. Thanks in advance!
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "bsp.h"
#include "bsp_nfc.h"
#include "app_timer.h"
#include "nordic_common.h"
#include "app_error.h"
#include "nrf_drv_clock.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#if NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
#include "app_scheduler.h"
#define APP_SCHED_MAX_EVENT_SIZE 0 /**< Maximum size of scheduler events. */
#define APP_SCHED_QUEUE_SIZE 4 /**< Maximum number of events in the scheduler queue. */
#endif // NRF_PWR_MGMT_CONFIG_USE_SCHEDULER
#define BTN_ID 20
/**@brief Handler for shutdown preparation.
bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
uint32_t err_code;
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
NRF_LOG_INFO("NRF_PWR_MGMT_EVT_PREPARE_WAKEUP");
err_code = bsp_buttons_disable();
// Suppress NRF_ERROR_NOT_SUPPORTED return code.
UNUSED_VARIABLE(err_code);
err_code = bsp_wakeup_button_enable(BTN_ID);
err_code = app_timer_stop_all();
return true;
/**@brief Register application shutdown handler with priority 0. */
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, 0);
/**@brief Function for handling BSP events.
static void bsp_evt_handler(bsp_event_t evt)
#if NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_ENABLED
nrf_pwr_mgmt_feed();
NRF_LOG_INFO("Power management fed");
#endif // NRF_PWR_MGMT_CONFIG_STANDBY_TIMEOUT_ENABLED
switch (evt)
case BSP_EVENT_DEFAULT:
case BSP_EVENT_SYSOFF:
// Application will prepare the wakeup mechanism: NRF_PWR_MGMT_EVT_PREPARE_WAKEUP
/**@brief Function for shutting down the system.
* @param[in] shutdown_type Type of operation.
* @details All callbacks will be executed prior to shutdown.
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
// NRF_LOG_INFO("2) System OFF is entered\r\n");
// NRF_POWER->SYSTEMOFF = 1;
return; // no implementation needed
/**@brief Function for initializing low-frequency clock.
static void lfclk_config(void)
ret_code_t err_code = nrf_drv_clock_init();
/**@brief Function for initializing the BSP module.
static void bsp_configuration()
NRF_LOG_INFO("3.0")
uint32_t err_code;
err_code = bsp_init(BSP_INIT_BUTTONS, bsp_evt_handler);
NRF_LOG_INFO("3.1");
err_code = bsp_event_to_button_action_assign(BTN_ID,
BSP_BUTTON_ACTION_LONG_PUSH,
BSP_EVENT_DEFAULT);
NRF_LOG_INFO("3.2")
BSP_BUTTON_ACTION_RELEASE,
BSP_EVENT_SYSOFF);
NRF_LOG_INFO("3.3")
* @brief Function for application main entry.
NRF_LOG_INFO("Power Management example");
lfclk_config();
NRF_LOG_INFO("1");
uint32_t err_code = app_timer_init();
NRF_LOG_INFO("2");
APP_SCHED_INIT(APP_SCHED_MAX_EVENT_SIZE, APP_SCHED_QUEUE_SIZE);
NRF_LOG_INFO("3");
bsp_configuration();
NRF_LOG_INFO("4");
ret_code_t ret_code = nrf_pwr_mgmt_init();
APP_ERROR_CHECK(ret_code);
NRF_LOG_INFO("5");
while (true)
app_sched_execute();
nrf_pwr_mgmt_run();
20210811 BC805M 1 button ONOFF.zip
