Using SES v1.6.1 with the nRF9160 module, I added the necessary CMSIS DSP defines for my project. Each define compiles a lot of files and it does not look like the linker includes only files used.
My code size has went over 466Kb. After adding more unrelated features, the code went over the 512Kb mark after which I remark part of the added code since I do not want to get into adjusting boot loader defines yet (a learning curve also there).
We need the CMSIS libraries and the calculations seems to work but it looks like the linker adds a ton of functions that are not even called.
Is there a way that the linker will remove them or should I just select all of the files I need in a new directory (bad I know). How can I determine which files are used or not?
CONFIG_CMSIS_DSP=y
CONFIG_CMSIS_DSP_SUPPORT=y
CONFIG_CMSIS_DSP_FASTMATH=y
CONFIG_CMSIS_DSP_COMPLEXMATH=y
CONFIG_CMSIS_DSP_STATISTICS=y
CONFIG_CMSIS_DSP_TRANSFORM=y
Thanks David
