About the ESB "TX failed events" of nrf5340
I use two nrf5340dks to run the routines in NCS \ v1.5.0 \ NRF \ samples \ ESB; The distance between the two nrf5340dks is only 10cm. When the transmission interval is set to 100US, a large number of "TX failed events" (about 10 per 1000) are printed in the PTX side com. Is this a normal phenomenon? Or what happened?
我使用两块nrf5340dk运行ncs\v1.5.0\nrf\samples\esb中的例程;两块nrf5340dk距离只有10cm,在发送间隔时间设置为 100us时,在ptx端com中打印出大量的"TX FAILED EVENT"(大概每1000个出现10个),请问这是正常的现象吗?还是发生了什么问题?
 * Copyright (c) 2018 Nordic Semiconductor ASA
#include <drivers/clock_control.h>
#include <drivers/clock_control/nrf_clock_control.h>
#include <drivers/gpio.h>
#include <irq.h>
#include <logging/log.h>
#include <nrf.h>
#include <esb.h>
#include <zephyr.h>
#include <zephyr/types.h>
LOG_MODULE_REGISTER(esb_ptx, CONFIG_ESB_PTX_APP_LOG_LEVEL);
#define LED_ON 0
#define LED_OFF 1
static bool ready = true;
static const struct device *led_port;
static struct esb_payload rx_payload;
static struct esb_payload tx_payload = ESB_CREATE_PAYLOAD(0,
	0x01, 0x00, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08);
#define _RADIO_SHORTS_COMMON                                                   \
	(RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_DISABLE_Msk |         \
	 RADIO_SHORTS_ADDRESS_RSSISTART_Msk |                                  \
	 RADIO_SHORTS_DISABLED_RSSISTOP_Msk)
void event_handler(struct esb_evt const *event)
	ready = true;
	switch (event->evt_id) {
	case ESB_EVENT_TX_SUCCESS:
		//LOG_DBG("TX SUCCESS EVENT");
	case ESB_EVENT_TX_FAILED:
		LOG_DBG("TX FAILED EVENT");
	case ESB_EVENT_RX_RECEIVED:
		while (esb_read_rx_payload(&rx_payload) == 0) {
			LOG_DBG("Packet received, len %d : "
				"0x%02x, 0x%02x, 0x%02x, 0x%02x, "
				"0x%02x, 0x%02x, 0x%02x, 0x%02x",
				rx_payload.length, rx_payload.data[0],
				rx_payload.data[1], rx_payload.data[2],
				rx_payload.data[3], rx_payload.data[4],
				rx_payload.data[5], rx_payload.data[6],
				rx_payload.data[7]);
int clocks_start(void)
	int err;
	int res;
	struct onoff_manager *clk_mgr;
	struct onoff_client clk_cli;
	clk_mgr = z_nrf_clock_control_get_onoff(CLOCK_CONTROL_NRF_SUBSYS_HF);
	if (!clk_mgr) {
		LOG_ERR("Unable to get the Clock manager");
		return -ENXIO;
	sys_notify_init_spinwait(&clk_cli.notify);
	err = onoff_request(clk_mgr, &clk_cli);
	if (err < 0) {
		LOG_ERR("Clock request failed: %d", err);
		return err;
	do {
		err = sys_notify_fetch_result(&clk_cli.notify, &res);
		if (!err && res) {
			LOG_ERR("Clock could not be started: %d", res);
			return res;
	} while (err);
	LOG_DBG("HF clock started");
	return 0;
int esb_initialize(void)
	int err;
	/* These are arbitrary default addresses. In end user products
	 * different addresses should be used for each set of devices.
	uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
	uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
	uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8};
	struct esb_config config = ESB_DEFAULT_CONFIG;
	config.protocol = ESB_PROTOCOL_ESB_DPL;
	config.retransmit_delay = 600;
	config.bitrate = ESB_BITRATE_2MBPS;
	config.event_handler = event_handler;
	config.mode = ESB_MODE_PTX;
	config.selective_auto_ack = true;
	err = esb_init(&config);
	if (err) {
		return err;
	err = esb_set_base_address_0(base_addr_0);
	if (err) {
		return err;
	err = esb_set_base_address_1(base_addr_1);
	if (err) {
		return err;
	err = esb_set_prefixes(addr_prefix, ARRAY_SIZE(addr_prefix));
	if (err) {
		return err;
	return 0;
static int leds_init(void)
	led_port = device_get_binding(DT_GPIO_LABEL(DT_ALIAS(led0), gpios));
	if (!led_port) {
		LOG_ERR("Could not bind to LED port %s",
		return -EIO;
	const uint8_t pins[] = {DT_GPIO_PIN(DT_ALIAS(led0), gpios),
			     DT_GPIO_PIN(DT_ALIAS(led1), gpios),
			     DT_GPIO_PIN(DT_ALIAS(led2), gpios),
			     DT_GPIO_PIN(DT_ALIAS(led3), gpios)};
	for (size_t i = 0; i < ARRAY_SIZE(pins); i++) {
		int err = gpio_pin_configure(led_port, pins[i], GPIO_OUTPUT);
		if (err) {
			LOG_ERR("Unable to configure LED%u, err %d", i, err);
			led_port = NULL;
			return err;
	return 0;
static void leds_update(uint8_t value)
	bool led0_status = !(value % 8 > 0 && value % 8 <= 4);
	bool led1_status = !(value % 8 > 1 && value % 8 <= 5);
	bool led2_status = !(value % 8 > 2 && value % 8 <= 6);
	bool led3_status = !(value % 8 > 3);
	gpio_port_pins_t mask =
		1 << DT_GPIO_PIN(DT_ALIAS(led0), gpios) |
		1 << DT_GPIO_PIN(DT_ALIAS(led1), gpios) |
		1 << DT_GPIO_PIN(DT_ALIAS(led2), gpios) |
		1 << DT_GPIO_PIN(DT_ALIAS(led3), gpios);
	gpio_port_value_t val =
		led0_status << DT_GPIO_PIN(DT_ALIAS(led0), gpios) |
		led1_status << DT_GPIO_PIN(DT_ALIAS(led1), gpios) |
		led2_status << DT_GPIO_PIN(DT_ALIAS(led2), gpios) |
		led3_status << DT_GPIO_PIN(DT_ALIAS(led3), gpios);
	if (led_port != NULL) {
		(void)gpio_port_set_masked_raw(led_port, mask, val);
void main(void)
	int err;
	LOG_INF("Enhanced ShockBurst ptx sample");
	err = clocks_start();
	if (err) {
		return;
	leds_init();
	err = esb_initialize();
	if (err) {
		LOG_ERR("ESB initialization failed, err %d", err);
		return;
	LOG_INF("Initialization complete");
	LOG_INF("Sending test packet");
	tx_payload.noack = false;
	while (1) {
		if (ready) {
			ready = false;
			esb_flush_tx();
			leds_update(tx_payload.data[1]);
			err = esb_write_payload(&tx_payload);
			if (err) {
				LOG_ERR("Payload write failed, err %d", err);
			tx_payload.data[1]++;
		k_sleep(K_USEC(100));
