Hello everyone
I hope summer's kind with you (or winter, for the southern hemisphere...)
Here's the deal: my printf and NRF_LOG_INFO output zeros, while my register clearly displays non zero values
Context:
- Based my code on the Peripheral > blinky freeRTOS code example
- I am now using TWIM to read sensor values (TXRX xfer) and would like to output values in the twim_handler
My setup:
- Customer board with nRF52833; debugger using nRF52840-DK
- Segger
- SDK nRF 17.0.2
- Extract from sdk_config.h
- nRF_Drivers
- NRFX_UART_ENABLED 1
- NRFX_UARTE_ENABLED 1
- UART_ENABLED 1
- nRF_Log
- LOGNRF_LOG_BACKEND_RTT_ENABLED 1
- NRF_LOG_BACKEND_UART_ENABLED 1
- NRF_LOG_ENABLED 1
- SEGGER_RTT_CONFIG_DEFAULT_MODE: 2 = BLOCK_IF_FIFO_FULL
Do you think I should ...
- ...persevere and find the problem (hopefully with your help)
- ...look into Libuarte
-... something else?
Thank you, in advance, for your help!
Jerome
