APP irq priority
Hi, I have developed a BLE/ZigBee application starting from nRF5 SDK for Thread and Zigbee v3.2.0.
Now I need to add a "timer" for measurement timing most precise as possible.
I tried:
- RTC, but unfortunatly: RTC0 is locked by SoftDevice, RTC2 is locked by 802.15.4 radio functions and RTC1 is used by APP timers.
- configuring by application_timers_start() function an application timer.
In this last case, I tried to change the IRQ priority reconfiguring APP_TIMER_CONFIG_IRQ_PRIORITY macro inside sdk_config.h header file
As on comment here below, I tried with priority level 2 or 3, but as sonn as the BLE connect, the FW goes into Hard Fault Handler
Where I wrong?
In addition, using the application timer with IRQ priority level 6, irq timing is not granted: for example, using 1 millisecond timer, very often the timer is served after 3-5 milliseconds, but the very troublesome think is that the followings IRQ after this issue, starts very time shifted and the long time sincronicity is not longer granted
How can I solve this issue?
Abele
  • Hello Torbjørn,
    I'm bit confused... in one previous comment you said
    Would it be an option to use a TIMER module rather than an RTC module?
    because on nRF5 SDK for Thread and Zigbee v3.2.0. there are no RTC available, then you suggested to use a TIMER module instead of RTC.
    Your 32768 Khz clock precision considerations are right, but in my case RTC is not usable.
    Abele
  • Hi Abele
     Yes. If you don't have any RTC's available then the remaining options are to use either a TIMER module or to use the app_timer module.
    Have you been able to identify which function calls preceded the HardFault by running the debugger when the issue occurs?
    Using the app_timer at priority level 2 or 3 can be risky, because you are not able to call any SoftDevice functions at these priorities. If you want to call a SoftDevice function, or any SDK function that calls the SoftDevice under the hood, you need to be at priority 6 or lower.
    But the app_timer should be, no?
    Did you try and configure a 100ms repeated timer through the app_timer, and use this to update your timestamp?
    Best regards
    Torbjørn
  • Hello Torbjørn,
    I'm now using the app_timer based on RTC1 module, but I must have a 10ms repeated timer because of some timed function that need less than 100ms.
    I will check if this solution is enough to have quite time clock
    BR
    Abele
  • Hi Abele
    One thing I forgot to mention is that you can always read out the current state of the RTC1 module, in order to get a more accurate time stamp than that provided by a 100ms callback. In other words you can schedule a callback every 100ms or later, and read the RTC counter value to get a timestamp with 1ms accuracy or less.
    I am not sure if that solves your 10ms repeated timer issue though, since a 10ms repeated timer can still be affected by other interrupts in the system.
    Best regards
    Torbjørn
  • Hi Torbjørn,
    could you more explain how can I read RTC1 counter and make best precision timestamp? If possible, can I have e sample code to make it?
    Many thanks in advance
    Abele
