[Zigbee] Sleepy end device get out of sleep in approx 10 mins
Hi everyone,
I have this question to ask. So I am trying do make an end device that run on low power. I can see that there is an example about the sleepy end device in the Zigbee and Thread SDK 4.1. So i try it and measure the current through the prolifier kit. Because i am running a NRF52833 on a custom board(just some with some io pins to use led and button), i run the code for PCA10100 on the light switch example. Then, I also modify some part of the code like delete the finding and binding part as well as pressing a button for the device to go sleepy but instead got sleepy automatically at startup. In addition, i also use the RTT log instead of the UART backend log.ut
When i first measure the power by the prolifier board version 1, it is get to 2.4uA on average, so good so far. But then, when i measure for a little longer like in 15 mins, the current start to go up to 80uA at 10-11mins i did not even start to commission the device to the coordinator. This is really weird since I keep like 90% of the code in the example. So, I have not modified any part of the code so that i can send it to you. Also, I try to not start the zigbee module and just run  __WFE() and __SEV() in the main while(1) loop and it working just fine. So i have a wild guess that there are some thing need to be done in the zigbee configuration that i miss.
Please help and reply soon, I attach the code i make with this.
Test_lowpower.zip
Hoang Ngoc Tu
  • Hi
    Unfortunately most of my colleagues experienced with Zigbee are on holiday for this week and next, so it is a bit limited what Zigbee support we can provide until they are back.
    Have you done any testing with the debugger to try and figure out what might be happening when the current consumption increases?
    Might there be any log output that could indicate something?
    Would you say it happens consistently after a reset, at the same time?
    Best regards
    Torbjørn
  • Hi Ovrebekk,
    Nice to meet you.
    Yes, i have a JlinkV9 debugger and use RTTViewer to see the log. I also put the code below in the zigbee handler and it is showing the time it have before waking up. In the first 10 mins, it just showing occationally the sleep_tmo. and the number are changing correctly (from the maximum timeout to to 0) but after 10 mins or even less, the sleep_tmo is poping up repeatedly (like in milisec). Beside that, I do not have anything in the log since the code i modified from the example are at the bare minimum of the example. I guess this have something to do with the Zigbee since i am not starting anything else but a buttons and some leds.
    This is always happen every time after i reset and start up the program.
            case ZB_COMMON_SIGNAL_CAN_SLEEP:
                    zb_zdo_signal_can_sleep_params_t *can_sleep_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_can_sleep_params_t);
                    NRF_LOG_INFO("Can sleep for %ld ms", can_sleep_params->sleep_tmo);
                    zb_sleep_now();
    Hope that help,
    Tu
  • Hi Tu
    Thanks for the additional information.
    So if I understand you correctly you are not connected to anything over Zigbee?
    There are no other Zigbee devices in the area that might try to communicate with yours?
    Best regards
    Torbjørn
  • Hi Torbjørn,
    Yes, you got that right, no devices were trying to communication to my board as well as my board was not connect to zigbee since there are no gw to send permit join request.
    Tu
  • Hi Tu
    I think I will need help from the Zigbee experts to investigate this further, and I will do my best to get back to you early next week when they are back in office.
    Best regards
    Torbjørn
