After installing nrfConnect SDK v1.6.1 on MacOS (Big Sur 11.5.1) using Toolchain Manager, I can't find nrfjprog.
When I try and run nfrjprog in Terminal, I get:
"zsh: command not found: nrfjprog"
Other command line tools, like nfrutil are available & seem to work OK.
The Toolchain Manager install seemed to have completed without any errors into the following folders:
/opt/nordic/ncs/v1.6.1
/Applications/SEGGER Embedded Studio for ARM 5.50d
/Applications/SEGGER/JLink
/Applications/SEGGER/JLink_V752c
In terminal, $PATH now returns:
zsh: no such file or directory: /Library/Frameworks/Python.framework/Versions/3.9/bin:/opt/local/bin:/opt/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Library/Apple/usr/bin
Does nfrjprog need to be installed manually or should it have been installed automatically by a clean install of nrf Connect by the Toolchain Manager?
How do I get nfrjprog?
I am worried that there is something incomplete with my nrfConnect SDK Install?
Any help would be appreciated.
Thanks!
