Hello.
I am trying to write code to read data using saadc and write the sampled data in a micro SD card using fatfs.
I started from the fatfs example and initialized and configured the saadc exactly as in saadc example except that I changed the timer to sample 120 samples at every 1 ms.
I configured a queue to received the sampled data. I store the data in the queue at every call to the saadc callback:
void saadc_callback(nrf_drv_saadc_evt_t const * p_event) { if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { ret_code_t err_code; err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); if(done < NUMBER_OF_PACKETS){ err_code = byte_queue_write(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER * 2);//If data cannot be written to queue done++; } else{ NRF_LOG_INFO("DONE WRITING TO THE FILE"); } } }
In the while loop, if there is data in the queue, I try to get it and save it in the file on the SD card:
while (true) { //__WFE(); if(!(byte_queue_read(saadc_source, sizeof(saadc_source)))){ unit16_2_uint8(saadc_source, saadc_destination); NRF_LOG_INFO("Writing to file " FILE_NAME "..."); ff_result = f_open(&file, FILE_NAME2, FA_READ | FA_WRITE | FA_OPEN_APPEND); if (ff_result != FR_OK) { NRF_LOG_INFO("Unable to open or create file: " FILE_NAME "."); } ff_result = f_write(&file, saadc_destination, sizeof(saadc_destination) - 1, (UINT *) &bytes_written); if (ff_result != FR_OK) { NRF_LOG_INFO("Write failed\r\n."); } else { NRF_LOG_INFO("%d bytes written.", bytes_written); } (void) f_close(&file); } }
However, the f_open() function always returns FR_NOT_ENABLED
And the device ends up stuck here:
This error seems to happen in this location at the file ff.c:
However, If I call the function fatfs_example() I can save the example file NORDIC.TXT without any errors.
Would anyone happen to know what could be causing the error?
Thank you.
