nRESET/DIO pin specifications? recommended filtering, inconsistent state between resets.
As noted in recent past cases, we have an issue with the state of the nRESET pin that is causing unwanted resets when connected/disconnected from external hardware (programmer, battery charger.
In testing for state of the pin between resets (forced and unwanted), it is found to randomly come up either internally pulled up, or floating, and either immune to resets, or not. Adding an external 1K pullup has appeared helped to some marginal degree, but is not fully reliable. We have scoped the pint and there is invariably a significant glitch on the pin the characteristics of which seem to change based on, presumably, internal termination and/or other reset parameters.  There appears to be 3 fundamental conditions that the pin comes up in:
     1.)  Floating, in which case, any attempted connect or disconnect causes the chip to reset (most prevalent)
     2.)  Internally pulled up, in which case, connect may or may not cause a reset, and
     3.) Unknown pullup, but never resets when connected/disconnected (presumably somehow placed in debug mode?)
At any rate, we need to design some level of filtration ahead of this pin (and perhaps the SWCLK pin) to eliminate these unwanted resets, without affecting programmability.
However, There appears to be no specifications in the documents for these pins that describe threshold levels and timing requirements for the reset and programming interfaces.
Can someone please help with this by either providing a "know to work"  pin cushioning circuit, or the specification for these pins to start a filter design?
Thank you all kindly,
Robin @ TL
  • Hello yet again, Kenneth,
    I dont think it drive strength, since both programa us the same hardware.  I am not aware if clock speed can be changed from within the jprog software, but I will look.
    Yet again,
    A resounding thank you
    Robin @ TL
  • Hi Kenneth,
    Here's the latest:
    1.) I can indeed reduce the programming clock rate in both the IDE, and jProg applications.
    2.) At 1 MHz both successfully program the chip.
    3.) With filter caps on both the SWDIO and SWCLK pins and each pin respectively pulled up/down by 1K, things are greatly improved.  I have done this to 2 boards.  An older board with a chip code ending in 1, and a newer board with a code ending in 3.  The boards behave a bit differently.
    4.) The board with the older chip does not reset when connecting/disconnecting.
    5.) The board with the newer chip resets about 1 in 5 connect/disconnects.  I suspect this may actually be a connector problem, but that is difficult to prove/disprove.
    6.) We can live with the reset rate so long as it never corrupts code, which was the original problem.
    7.) To test this I have downloaded the latest nrfjprog to verify flash between resets, however I cannot get the program to work.  I have another case open to try to helo resolve this.  Please have a look at case 274972 and let me know what your thoughts are.
    8.) Finally, one last unknown: When a hard reset happens via the nRESET pin, is flash protected, or is there a way to detect the reset and do so?  There are flash write in our code, but very seldomly performed.
    With the specs you are chasing on the SWD  interface and help on 7 and 8  I think we could wrap this up.  Whatever you can do is greatly appreciated.
    Gratefully,
    Robin @ TL
    Kenneth,
    Here my proposed "Program Enable" circuit.  Can you find any reason this should not allow the chip to be initially programmable, and then re-programming enabled/disabled as needed afterwards?
    Thx
    Robin
     Program Enable.pdf
  • Hello again,
    Some quick comments below, I have asked the designers if they can provide more electrical parameters for the SWD interface.
    For test 4 and 5, is this programming cable or charger? I don't expect testing with a programming cable is a realistic test for the end product, though I can understand that a reset when plugin the charger is a problem.
    7. Each nRF command line tools release is tested with a specific segger j-link release, so mixing with a different j-link version can cause problems yes.
    8. Causing a pin reset during a flash write or erase operation I would assume can be problematic yes, I don't see any way to easliy work around this other than try to avoid it by design (e.g. filter on nRESET like you already do).
    Kenneth
  • Hi Kenneth,
    With regard to charge/programming cable, they are both the same type USB-A to micro-USB.  We jave custom Segger interface board to implement that interface.  Reset plugging into programmer is not a test, just a noted similar response.
    Are different release versions of the NRF available for download?  I did not see them if they are, and the tool version is not the same as the Segger dll version.  Can you tell me which tool version aligns with the Segger dll I have?
    Thx
    Robin @ TL
  • Hello Kenneth,
    Best to you and yours,
    I have the nrfjprog up and working now, and yes it was a misalignment of Nordic/Segger versions.  BTW, it is not an easy process to determine that alignment.  I suggest something be added to the site to indicate which segger version the tools are compatible with.
    So on the testing front, I have found that the best I can do is minimize the reset incidence with the RC filter.  Turns out there that with the uUSB connectors, there is no way of guaranteeing that the shell of the male will not drag across the reset pin of the femaie, particularly when being plugged in. And it does appear, that when that happens, there may be instances when there are multiple resets close enough together to corrupt the code (testing to follow).  So, my long term plan now is to design an active program interface that isolates those pins once our app is up and running.
    That said, in addition to the SWD specs I have asked for, I need know the GPIO pin loading and drive conditions in all states from blank chip through programming.
    The hopes is that I can use 1 or 2 of these pins to qualify the programming pins once the chip is up and running our code and add a command to enable/disable re-programming as needed. Please let me know if you are aware of anyone else who has done something like this, or if can see through how it might be done, or worse yet if you're sure it cannot.  I will draft up a simple schematic with my idea based on what I know now and upload it for you to review.
    Thanks ad nauseum,
    Robin @ TL
