nRESET/DIO pin specifications? recommended filtering, inconsistent state between resets.
As noted in recent past cases, we have an issue with the state of the nRESET pin that is causing unwanted resets when connected/disconnected from external hardware (programmer, battery charger.
In testing for state of the pin between resets (forced and unwanted), it is found to randomly come up either internally pulled up, or floating, and either immune to resets, or not. Adding an external 1K pullup has appeared helped to some marginal degree, but is not fully reliable. We have scoped the pint and there is invariably a significant glitch on the pin the characteristics of which seem to change based on, presumably, internal termination and/or other reset parameters.  There appears to be 3 fundamental conditions that the pin comes up in:
     1.)  Floating, in which case, any attempted connect or disconnect causes the chip to reset (most prevalent)
     2.)  Internally pulled up, in which case, connect may or may not cause a reset, and
     3.) Unknown pullup, but never resets when connected/disconnected (presumably somehow placed in debug mode?)
At any rate, we need to design some level of filtration ahead of this pin (and perhaps the SWCLK pin) to eliminate these unwanted resets, without affecting programmability.
However, There appears to be no specifications in the documents for these pins that describe threshold levels and timing requirements for the reset and programming interfaces.
Can someone please help with this by either providing a "know to work"  pin cushioning circuit, or the specification for these pins to start a filter design?
Thank you all kindly,
Robin @ TL
  • Robin said:
    That said, in addition to the SWD specs I have asked for, I need know the GPIO pin loading and drive conditions in all states from blank chip through programming.
    Sorry, but we don't have more information than stated in the datasheet already. From my understanding you are considering/planning to connect one or several gpios directly or indirectly to the nRESET pin, unfortunately we can't guarantee that the gpios will have a defined level during reset, so I can't recommend such a solution.
    One thing that can be considered is to either pre-program the chips, or for instance have a solder bridge of some sort, so you can connect nRESET directly to VDD during production test/assembly.
    If you are making a new layout, feel free create a new case for review.
    Kenneth
  • Hello Kenneth,
    Indeed I need to protect these pins in the final build, so yes I will, and have already started, a new board layout. The circuits I sent, I now realize will not work, so I jave abandoned that idea.  I do have a new scheme that should work. I'll close this case and continue in a new one if needed.
    I do want to say, however, that it does bother me that there are no specs available on the SWD interface.  That is a real problem for anyone needing to work issues such as ours.  I plead one last attempt at recovering this info before closing this case.
    Kindly,
    Robin @TL
  • Hello Kenneth,
    I now  have a working  prototype circuit that enable and disables the program pins (nRESET/SWDIO and SWDCLK.  BUT i have no blank chips to test the initial state programming with.  I have opened another ticket (275543) to find a way of insuring we can return a chip to "factory delivered state".  Please  see that case and respond there.  Once we have a dialogue started thee, I will close this ticket.
    Best to you,
    Robin @ TL
