LIBUARTE - no NRF_LIBUARTE_ASYNC_EVT_RX_DATA event
Hi
I have combined the ble_app_uart and libuarte example. The combination works "nearly" well.Transmit is ok, but when receiving characters over UARTE, no NRF_LIBUARTE_ASYNC_EVT_RX_DATA event is generated until a buffer is full. Hence, I don't get any timeout! When printing the buffer, I can see that all RX characters are received correctly, but for small packages, I would like to have timeouts.
I'm using nRF5 SDK version17.2 on a custom board.
this is the definition:
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 5);
..and the rest of the essential code:
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            NRF_LOG_HEXDUMP_INFO(p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            // Done processing buffer, release buffer back to libUARTE
            nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (!nrf_queue_is_empty(&m_buf_queue))
                buffer_t buf;
                ret = nrf_queue_pop(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
                UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
                // done transmitting....start listening
                rs485_duplex_mode(RS485_RX);
void
msgSend (uint8_t* data, uint8_t len)
    // turn on rs485 Tx --- TODO: turn off in callback
    rs485_duplex_mode(RS485_TX);
//    NRF_LOG_HEXDUMP_INFO(data,len);
    ret_code_t ret = nrf_libuarte_async_tx(&libuarte, data, len);
    if (ret == NRF_ERROR_BUSY)
        buffer_t buf = {
            .p_data = data,
            .length = len,
        ret = nrf_queue_push(&m_buf_queue, &buf);
void libuarte_init(void){
    ret_code_t ret = nrf_drv_clock_init();
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_115200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_MID
    ret_code_t err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
Note: The msgSend() is used since I have placed libuarte definitions outside main(), and msgSend() is called from main() since libuarte is not defined in main()
Note: Communication is over half duplex RS485. Hence, rs485_duplex_mode().
