LIBUARTE - no NRF_LIBUARTE_ASYNC_EVT_RX_DATA event
Hi
I have combined the ble_app_uart and libuarte example. The combination works "nearly" well.Transmit is ok, but when receiving characters over UARTE, no NRF_LIBUARTE_ASYNC_EVT_RX_DATA event is generated until a buffer is full. Hence, I don't get any timeout! When printing the buffer, I can see that all RX characters are received correctly, but for small packages, I would like to have timeouts.
I'm using nRF5 SDK version17.2 on a custom board.
this is the definition:
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 5);
..and the rest of the essential code:
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            NRF_LOG_HEXDUMP_INFO(p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
            // Done processing buffer, release buffer back to libUARTE
            nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (!nrf_queue_is_empty(&m_buf_queue))
                buffer_t buf;
                ret = nrf_queue_pop(&m_buf_queue, &buf);
                APP_ERROR_CHECK(ret);
                UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
                // done transmitting....start listening
                rs485_duplex_mode(RS485_RX);
void
msgSend (uint8_t* data, uint8_t len)
    // turn on rs485 Tx --- TODO: turn off in callback
    rs485_duplex_mode(RS485_TX);
//    NRF_LOG_HEXDUMP_INFO(data,len);
    ret_code_t ret = nrf_libuarte_async_tx(&libuarte, data, len);
    if (ret == NRF_ERROR_BUSY)
        buffer_t buf = {
            .p_data = data,
            .length = len,
        ret = nrf_queue_push(&m_buf_queue, &buf);
void libuarte_init(void){
    ret_code_t ret = nrf_drv_clock_init();
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_115200,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_MID
    ret_code_t err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
Note: The msgSend() is used since I have placed libuarte definitions outside main(), and msgSend() is called from main() since libuarte is not defined in main()
Note: Communication is over half duplex RS485. Hence, rs485_duplex_mode().
  • Hi
    What is your LF clock setting?
    By default the SDK projects are set up to use external 32kHz crystal, which you may or may not have included on your custom board?
    If you don't have an external 32kHz crystal available you need to set CLOCK_CONFIG_LF_SRC to 0 in sdk_config.h
    Other than that I can't really see any issue with your code.
    Best regards
    Torbjørn
  • Hi Torbjørn
    I do have a 32 kHz crystal. A quick test setting  CLOCK_CONFIG_LF_SRC  to 0 (RC) did non change anything. I even tried these settings (one at a time):
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, NRF_LIBUARTE_PERIPHERAL_NOT_USED, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 16, 5);
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 1, 16, 5);
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 1, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 2, 16, 5);
    1. The first one did no change
    2. The second one gave fatal error. Maybe because timer 1 is used for softdevice?
    3. The third option did work after I enabled timer 2 in sdk_config.h
    But why doesn't RTC work? Any settings to change or tests to perform to find out?
    Best Regards
    Bård
  • Hi Bård
    1. In this case you don't assign any RTC or TIMER to handle the RX timeout, and the driver will revert to using the app_timer instead. If you initialize the app_timer library before you initialize libuarte this should work.
    2. In this case both of the libuarte TIMER modules are set to 1, which means you get a conflict. The third and fifth parameter needs to point to different timers.
    I forgot to check if you use SoftDevice. The SoftDevice uses RTC0, which is probably why your original configuration didn't work.
    If you only use RTC modules for the SoftDevice (RTC0) and app_timer (RTC1), then RTC2 should be available for libuarte.
    Alternatively we can look into why the app_timer option doesn't seem to work, which is a good option if you are planning to use app_timer anyway.
    Best regards
    Torbjørn
  • Hi Torbjørn
    Thank you for the very precise answer :-) Most helpful!
    Both case 1 and using RTC2 works well. In case 1 I had app_timer initialized AFTER libuarte. That didn't work.
    Best Regards
    Bård
  • Hi Bård
    Good to hear you figured it out, I am glad I could be of help. The best of luck with your project Slight smile
    Best regards
    Torbjørn
