Hardfault triggered after p nrf_fstorage_erase
Hi!
Writing to flash memory.
After calling nrf_fstorage_erase (...) a hardfault happens. It only NOT happens if JLink is enabled (using dbg or rtt logs).
So I can not debug it deeply. I did simple de-bug procedure, with LED flashing the number of cfsr_msgs[]. This number is 10,
meaning [10] = "Data bus error (return address in the stack frame is not related to the instruction that caused the error)".
Looks like the flash area is not erased as the result.
Looks like it happens not every time. I load the program into debugger (it works good), then I go out of the debugger session.
The program continues to run, and after 2 or 3 erase/write cycles it fails and calls for hardfault.
This piece of the program is taken from a working program, so looks like the problem depends on the code size, or RAM map, or
FLASH map. Can not understand.
I know this situation happens with NRF52832 not in first time, as there are some answers in this community already. But it does not help.
Anybody could help me?
Alex.
  • o.k.
    As we use Keil IDE, there is a window there, with ROM areas mapping.
    I just excluded the area, I want to erase, from ROM map - and Keil now is not setting NO bits at all in BPROT register.
    My ROM area, I want to erase, is one page long, and starts from 0x6D000 address.
    I can do it myself, instead - I mean - switch on all ROM pages protection, I want.
    I guess, at this point, the ticket can be closed.
    Thanks everybody!
  • It's good that you found a workaround, but I really don't see how the linker configuration could affect the BPROT settings when you don't have anything in your application code that accesses the BPROT registers.
    Have you checked if the protection bits get set if you run any of the other SDK examples?
  • Hello.
    Doing the checks now. Yes, the information is contradictory.
    The program works. Sometimes. Sometimes - does not.
    The program starts to execute from the address 0xA80
    Then it jumps somewhere (I guess this is SoftDevice procedures)
    Then returns, and jumps to the address 0x783D4. Is that Bootloader? Do not know.
    But, in this code, the program sets BPROT register in different ways.
    Sometimes all CONFIGx registers of BPROT are set as 0xFFFFFFFF
    Sometimes - the area from 0x73000 to 0x78000 are set as Not-protected.
    Sometimes this area expands from 0x71000
    Sometimes from 0x70000
    Sometimes nothing is protected at all
    What is program doing there? How to manage that BPROT bits? Still not clear.
    I thought at the beginning, that if I define
    NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage_options) =
    /* Set a handler for fstorage events. */
    .evt_handler = fstorage_evt_handler_options,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
    * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
    * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
    * last page of flash available to write data. */
    .start_addr = WORK_FLASH_DATA_ADDR,
    .end_addr = WORK_FLASH_DATA_END,
    this area will stay unprotected. I was wrong.
    In few words: 1) I do not switch on the protection 2) who does it - I can not understand 3) How to overcome it - I can not understand 4) Why our main project still works - I can not understand
  • 0x71000 and 0x78000 are both common start addresses for the bootloader. Could you please check if you have anything at these addresses? You can use the programmer app in nRF connect for this.
    Memory layout read from nRF52832 with the Programmer app
  • nRF_Connect_Programmer_1629478104493.hex
    Do not know about NRF Connect, but if to load my Application.hex file into J-Flash program - it shows, that only the region 0x26000 to 0x6EFFF is occupied
