nRF Sniffer Interface not showing up in Wireshark on macOS (11.5.1)
I recently followed the instructions laid out in the "nRF Sniffer for Bluetooth LE" User Guide version 4.0.0 and having trouble seeing the nRF Sniffer interface in Wireshark (v 3.4.7).
The only way I could get it to show up is to run Wireshark as an administrator. I recall this being an issue a couple of years ago, has this not been fixed? or is there something special that needs to be done to enable Wireshark to see the nRF Sniffer when run in user mode? I can see all the other interfaces, but not the nRF Sniffer.
Parents Reply
  • Hi Vidar,
    All is well now. I ended up building wireshark from source but that ended not been the solution either. I also already had my user as part of the wireshark group.
    The problem was that I copied the Nordic sniffer extcap folder contents to wireshark "Global Extcap Path" instead of "Personal Extcap Path".
    My thinking was that, if it resides in the global path then any user can access it but for some reason it does not seem to be happy with this.
    Other issues that was observed when using the global path was that when wireshark is started with sudo you can only start the sniffer once and to restart it, one has to close wireshark and relaunch as it says complains it can't save files.
    Anyway all is working now. Thanks for your speedy response and just also can confirm that Nordic sniffer plugins works with wireshark 4.0.0
    Regards
    Ola
