Hello Everyone,
I am trying to use a display (through SPI) in a custom board with nRF51822 and SoftDevice S120. All works great as long as I call the SPI methods from main, and I am able to set up the screen properly and write everything I want in it.
The problem comes whenever I try to send/receive data through SPI outside main. Either I try to call it from a timer handler or an event handler, it only send 2 bytes max. through SPI.
To configure or write the screen I need to send a large amount of bytes, so when I am limited to 2 bytes from outside main I am not able to make it work. (Checked with Saleae Logic Analyzer)
Is there any kind of limitation of SPI I missed? Is it working only from main?
I already tried to send byte by byte with timing in between, send the full byte array at once, initialize the SPI in the timer, etc... but there is no way I can make it work.
Any advice or solution would be much appreciated.
Thanks in advance,
Gabriel.
