Is there a way to update text neatly using GFX driver?
Hello
I am using sdk17 and st7735 drivers in GFX example.
Later, I will add several UI to the display, but now I am simply outputting sensor values.
Below is the code that simply updates the sensor value.  However, whenever text is updated, 'screen_clear()" blinks throughout the screen and makes it look bad.
When updating text on a screen, what method should I use to update text parts naturally? Is this method in sdk?
//st7735
// Some ready-made 16-bit ('565') color settings:
#define GRAY            0xC618
#define RED             0xF800
#define BLUE            0x001F
#define BLACK           0x0000
#define WHITE           0xFFFF
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define ORANGE          0xFC00
//static const char * test_text = "nRF52 family"; //test
extern const nrf_gfx_font_desc_t orkney_8ptFontInfo; //font
extern const nrf_lcd_t nrf_lcd_st7735;
static const nrf_gfx_font_desc_t * p_font = &orkney_8ptFontInfo;
static const nrf_lcd_t * p_lcd = &nrf_lcd_st7735;
static void gfx_initialization(void)
    APP_ERROR_CHECK(nrf_gfx_init(p_lcd));
char display_sensor[20];
static void display_sensor_print(void)
    sprintf(display_sensor, "%d", new_adc_value);
    nrf_gfx_point_t text_start = NRF_GFX_POINT(50,70); //position
    APP_ERROR_CHECK(nrf_gfx_print(p_lcd, &text_start, 0, display_sensor, p_font, true)); //instance, position, color, string, pont, wrap
static void screen_clear(void)
    nrf_gfx_screen_fill(p_lcd, WHITE);
    bool erase_bonds;
    uint32_t err_code;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    //saadc
    saadc_all_init();
    //st7735
    gfx_initialization();
    screen_clear();
    //test
    //char app_test[100];
    //int test_value = 5;
    // Enter main loop.
    for (;;)
        idle_state_handle();
        if(new_adc_value > 0)
              //display
              screen_clear(); //clear display
              display_sensor_print();
              new_adc_value = 0;
Thank you.
