I have modified the HRS example (central+peripheral) from SDK 17 to operate in Long-Range mode (PHY CODED). This appears to work correctly assuming that a bond was previously established in 1MBPs mode. However, if the devices have been erased of bond data, they are unable to discover each other from the Long-Range mode. Is there any known limitation that prevents this capability, or are there additional configurations needed to make this work? Should I always bond at 1MBPs and switch to Long-Range after?
Thanks.
