Problems with LCD clearing screen a few minutes after running and no longer updating
Hello
I am using sdk17 and st7735(GFX) drivers.
I am simply printing the sensor value on the display. Initially, it works well, but after a few minutes, the screen is cleared and the values are no longer updated.
Debugging does not produce errors, and sensor values continue to output well to the terminal. (Only the display seems to have a problem)
This is display code.
// Some ready-made 16-bit ('565') color settings:
#define GRAY            0xC618
#define RED             0xF800
#define BLUE            0x001F
#define BLACK           0x0000
#define WHITE           0xFFFF
#define GREEN           0x07E0
#define CYAN            0x07FF
#define MAGENTA         0xF81F
#define YELLOW          0xFFE0
#define ORANGE          0xFC00
extern const nrf_gfx_font_desc_t orkney_8ptFontInfo; //font
extern const nrf_gfx_font_desc_t orkney_24ptFontInfo; //font
extern const nrf_lcd_t nrf_lcd_st7735;
static const nrf_gfx_font_desc_t * text_font = &orkney_8ptFontInfo;
static const nrf_gfx_font_desc_t * title_font = &orkney_24ptFontInfo;
static const nrf_lcd_t * p_lcd = &nrf_lcd_st7735;
static void gfx_initialization(void)
    APP_ERROR_CHECK(nrf_gfx_init(p_lcd));
char display_sensor[20];
static void display_sensor_print(void)
    sprintf(display_sensor, "%d", new_adc_value);
    nrf_gfx_point_t text_position = NRF_GFX_POINT(50,80); //position
    APP_ERROR_CHECK(nrf_gfx_print(p_lcd, &text_position, ORANGE, display_sensor, text_font, true)); //instance, position, color, string, pont, wrap
static void display_title_print(void)
    nrf_gfx_point_t text_position = NRF_GFX_POINT(20,20); //position
    APP_ERROR_CHECK(nrf_gfx_print(p_lcd, &text_position, CYAN, "Title", title_font, true));
static void screen_clear(void)
    nrf_gfx_screen_fill(p_lcd, WHITE);
static void rect_draw(void) //sensor value clear
    nrf_gfx_rect_t rect_size = NRF_GFX_RECT(45,75,33,30); //x,y,width,height
    APP_ERROR_CHECK(nrf_gfx_rect_draw(p_lcd, &rect_size, 1, WHITE, true)); //instance, position, Thickness of the border, color, fill(bool)
    bool erase_bonds;
    uint32_t err_code;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    advertising_start();
    //crypto
    err_code = nrf_crypto_init();
    err_code = nrf_mem_init();
    //saadc
    saadc_all_init();
    //st7735
    gfx_initialization();
    screen_clear();
    display_title_print();
    // Enter main loop.
    for (;;)
        idle_state_handle();
        if(new_adc_value > 0)
          if(new_adc_value != prev_adc_value) //Compare to previous values
              prev_adc_value = new_adc_value;
              //display
              //screen_clear();
              rect_draw(); //instead of clear
              display_sensor_print();
              new_adc_value = 0;
And this is my whole code. (main.c)
/** @file
 * @defgroup ble_sdk_uart_over_ble_main main.c
 * @ingroup  ble_sdk_app_nus_eval
 * @brief    UART over BLE application main file.
 * This file contains the source code for a sample application that uses the Nordic UART service.
 * This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
//crypto
#include "nrf_drv_clock.h"
#include "nrf_drv_power.h"
#include "app_util.h"
#include "boards.h"
#include "nrf_crypto.h"
#include "nrf_crypto_error.h"
#include "mem_manager.h"
//saadc
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
//st7735
#include "nrf_gfx.h"
#define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME                     "Medical level devic"                               /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION                0 //18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY                   0                                           /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
 *          the device. It also sets the permissions and appearance.
    uint32_t                err_code;
                                          strlen(DEVICE_NAME));
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_evt       Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
    uint32_t           err_code;
    ble_nus_init_t     nus_init;
    // Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module
 *          which are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply setting
 *       the disconnect_on_fail config parameter, but instead we use the event handler
 *       mechanism to demonstrate its use.
    uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
    uint32_t err_code;
    //uint32_t err_code = bsp_indication_set(BSP_INDICATE_IDLE);
    //APP_ERROR_CHECK(err_code);
    //// Prepare wakeup buttons.
    //err_code = bsp_btn_ble_sleep_mode_prepare();
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            //err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
        case BLE_ADV_EVT_IDLE: //When disconnected bluetooth, power off
            //sleep_mode_enter();
//check connection
int connection_state;
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            connection_state = 1;
            NRF_LOG_INFO("Disconnected");
            connection_state = 0;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
            // Pairing not supported
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
/**@brief Function for the SoftDevice initialization.
 * @details This function initializes the SoftDevice and the BLE event interrupt.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
 * @param[in]   event   Event generated by button press.
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        case BSP_EVENT_WHITELIST_OFF:
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= m_ble_nus_max_data_len))
                if (index > 1)
                    do
                    } while (err_code == NRF_ERROR_RESOURCES);
                index = 0;
        case APP_UART_FIFO_ERROR:
/**@brief  Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance = true; //false //Determines if Appearance shall be included (bluetooth Icon?)
    //init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; //For infinity scan
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
static void log_init(void)
        nrf_pwr_mgmt_run();
//AES CTR
int new_adc_value; //saadc
int prev_adc_value;
#define NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE  (100) //(100)
#define AES_ERROR_CHECK(error)  \
    do {            \
        if (error)  \
            NRF_LOG_RAW_INFO("\r\nError = 0x%x\r\n%s\r\n",           \
                             (error),                                \
                             nrf_crypto_error_string_get(error));    \
            return; \
    } while (0);
/* Maximum allowed key = 256 bit */
static uint8_t m_key[32] = {'V', 'E', 'C', 'T', 'R', 'O', 'W',
                            'S', 'E', 'M', 'I', 'C', 'O', 'N', 'D', 'U', 'C', 'T', 'O', 'R',
                            'A', 'E', 'S', '&', 'C', 'T', 'R', ' ', 'T', 'E', 'S', 'T'};
/* Below text is used as plain text for encryption and decryption in AES CTR mode. */
//static char m_plain_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE] =
//    "AES CTR Mode Test"
char m_plain_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE]; //100
static char m_encrypted_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE]; //encrypt
static char m_decrypted_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE]; //decrypt
//char encrypted_array[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE];
char app_encrypted_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE];
char app_plain_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE];
char app_label_text[NRF_CRYPTO_EXAMPLE_AES_MAX_TEXT_SIZE];
uint16_t length_app_encrypt;
static void text_print(char const* p_label, char const * p_text, size_t len)
    uint32_t err_code;
    NRF_LOG_RAW_INFO("-%s-\r\n", p_label);
    NRF_LOG_FLUSH();
    for(size_t i = 0; i < len; i++) //output sensor value
        NRF_LOG_RAW_INFO("%c", p_text[i]);
        NRF_LOG_FLUSH();
    NRF_LOG_RAW_INFO("\r\n\r\n");
    NRF_LOG_FLUSH();
//test
uint32_t check_nus_send;
static void hex_text_print(char const* p_label, char const * p_text, size_t len) //char const* p_label, char const * p_text, size_t len
    uint32_t err_code;
    NRF_LOG_FLUSH();
    // Handle partial line (left)
    for (size_t i = 0; i < len; i++) //len = 18
        if (((i & 0xF) == 0) && (i > 0))
            NRF_LOG_RAW_INFO("\r\n");
            NRF_LOG_FLUSH();
        NRF_LOG_RAW_INFO("%02x ", p_text[i]);
        NRF_LOG_FLUSH();
        //send to app (crypto sensor value)  //problem : Only some data, not all data, has been sent
        if(connection_state == 1)
          sprintf(app_encrypted_text, "%02x ", p_text[i]);
          //uint16_t length_app_encrypt = len;
          err_code = ble_nus_data_send(&m_nus, &app_encrypted_text, &length_app_encrypt, m_conn_handle);
          check_nus_send = err_code; //test
              (err_code != NRF_ERROR_NOT_FOUND) &&
              (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING))
                  APP_ERROR_CHECK(err_code); //error when disconnted bluetooth? -> OK
          nrf_delay_ms(10); //Used to prevent continuous transmission stop (change NRF_SDH_BLE_GAP_EVENT_LENGTH in config.h)
    //test
    //NRF_LOG_INFO("%d", check_nus_send); //err_code : NRF_ERROR_INVALID_STATE(Invalid state, operation disallowed in this state)
    NRF_LOG_FLUSH();
static void plain_text_print(void)
    text_print("Plain text", m_plain_text, strlen(m_plain_text));
    //hex_text_print("Plain text (hex)", m_plain_text, strlen(m_plain_text));
static void encrypted_text_print(char const * p_text, size_t encrypted_len)
    hex_text_print("Encrypted text (hex)", p_text, encrypted_len);
static void decrypted_text_print(char const * p_text, size_t decrypted_len)
    text_print("Decrypted text", p_text, decrypted_len);
    //hex_text_print("Decrypted text (hex)", p_text, decrypted_len);
static void crypt_ctr(void)
    uint8_t     iv[16];
    ret_code_t  ret_val;
    size_t      len_in;
    size_t      len_out;
    static nrf_crypto_aes_context_t ctr_encr_128_ctx; // AES CTR encryption context
    static nrf_crypto_aes_context_t ctr_decr_128_ctx; // AES CTR decryption context
    plain_text_print();
    /* Init encryption context for 128 bit key */
    ret_val = nrf_crypto_aes_init(&ctr_encr_128_ctx,
                                  &g_nrf_crypto_aes_ctr_128_info,
                                  NRF_CRYPTO_ENCRYPT);
    AES_ERROR_CHECK(ret_val);
    /* Set key for encryption context - only first 128 key bits will be used */
    ret_val = nrf_crypto_aes_key_set(&ctr_encr_128_ctx, m_key);
    memset(iv, 0, sizeof(iv));
    /* Set IV for encryption context */
    ret_val = nrf_crypto_aes_iv_set(&ctr_encr_128_ctx, iv);
    len_in = strlen(m_plain_text); //size of sensor value is 1~3 byte?
#define PARTIAL_MESSAGE_SIZE (16u)  // 16 bytes
    /* Encrypt first 10 bytes */
    ret_val = nrf_crypto_aes_update(&ctr_encr_128_ctx,
                                    (uint8_t *)m_plain_text,
                                    PARTIAL_MESSAGE_SIZE,           // encrypt first 10 bytes
                                    (uint8_t *)m_encrypted_text);
    size_t offset = PARTIAL_MESSAGE_SIZE;
    len_out = sizeof(m_encrypted_text) - PARTIAL_MESSAGE_SIZE;
    /* Encrypt first rest of text */
    ret_val = nrf_crypto_aes_finalize(&ctr_encr_128_ctx,
                                      (uint8_t *)m_plain_text + offset, // skip already encrypted bytes
                                      len_in - offset,
                                      (uint8_t *)m_encrypted_text + offset,
                                      &len_out);
    encrypted_text_print(m_encrypted_text, PARTIAL_MESSAGE_SIZE + len_out);
    len_in  = len_out + offset; // length of encrypted message is an input for decryption
    len_out = sizeof(m_decrypted_text);
    /* Decrypt with integrated function */
    ret_val = nrf_crypto_aes_crypt(&ctr_decr_128_ctx,
                                   NRF_CRYPTO_DECRYPT,
                                   m_key,
                                   iv,
                                   (uint8_t *)m_encrypted_text,
                                   len_in,
                                   (uint8_t *)m_decrypted_text,
                                   &len_out);
    decrypted_text_print(m_decrypted_text, len_out);
    if (memcmp(m_plain_text, m_decrypted_text, len_out) == 0)
        //NRF_LOG_RAW_INFO("AES CTR example executed successfully.\r\n");
        NRF_LOG_RAW_INFO("AES CTR example failed!!!\r\n");
        NRF_LOG_FLUSH();
//saadc
#define SAMPLES_IN_BUFFER 5
#define ADC_Time 100 //700
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(2); //0
static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t     m_ppi_channel;
static uint32_t              m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
    /* setup m_timer for compare event every (ADC_Time)ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, ADC_Time); //output time
                                   NRF_TIMER_CC_CHANNEL0,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
    int sum = 0;
    int value = 0;
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        //NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
        for (int i = 0; i < SAMPLES_IN_BUFFER; i++)
            value = p_event->data.done.p_buffer[i];
            sum = sum + value;
        new_adc_value = sum / SAMPLES_IN_BUFFER;
        //m_adc_evt_counter++;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1); //9(p0.03)
        //add option
        //adc input range = reperence / gain   (REFERENCE_VDD4 / GAIN1_4 = VDD)
        channel_config.gain = NRF_SAADC_GAIN1_4; //volt gain change (ADC range, Gain factor 1/4)
        channel_config.reference = NRF_SAADC_REFERENCE_VDD4; //VDD/4 as reference
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
void saadc_all_init()
    saadc_init();
    saadc_sampling_event_init();
//st7735
#define GRAY            0xC618
#define RED             0xF800
#define BLUE            0x001F
#define CYAN            0x07FF
//static const char * test_text = "nRF52 family"; //test
    //nrf_gfx_point_t text_position = NRF_GFX_POINT(5, nrf_gfx_height_get(p_lcd) - 50);
/**@brief Application main function.
    bool erase_bonds;
    uint32_t err_code;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    //crypto
    //saadc
    saadc_all_init();
    //st7735
    screen_clear();
    //test
    //char app_test[100];
    //int test_value = 5;
    // Enter main loop.
    for (;;)
        //display_title_print();
        if(new_adc_value > 0) // || new_adc_value == 0
            if(new_adc_value > prev_adc_value+5 || new_adc_value < prev_adc_value-5)
              //display
              //screen_clear();
              sprintf(m_plain_text, "%d               ", new_adc_value); //error : The length of the one or more output arguments was too small (longer than 16byte)
              crypt_ctr();
              new_adc_value = 0;
          //screen_clear();
          //nrf_gfx_point_t text_position = NRF_GFX_POINT(50,80); //position
          //APP_ERROR_CHECK(nrf_gfx_print(p_lcd, &text_position, ORANGE, "0", text_font, true));
May I know about this problem?
Thank you.
