sdk 17.0.2 merge ble_app_multirole_lesc and ble_app_blinky
how am i going to merge ble_app_multirole_lesc and ble_app_blinky
I add
    ret_code_t         err_code;
    ble_lbs_init_t     init     = {0};
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
into ble_app_multirole_lesc main.c
and it stuck in services_init()
seems like the err_code = nrf_ble_qwr_init(&m_qwr, &qwr_init); do have some problem
sdk config:
2821.sdk_config.h
my main file:
 * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief Application main file for the BLE multirole LE Secure Connections (LESC) example.
 * @detail This application demonstrates bonding with LE Secure Connections both as a peripheral and as a central.
 * LED layout:
 * LED 1: Central side is scanning.       LED 2: Central side is connected to a peripheral.
 * LED 3: Peripheral side is advertising. LED 4: Peripheral side is connected to a central.
 * @note: This application requires the use of an external ECC library for public key and shared secret calculation.
 *        Refer to the application's documentation for more details.
#include "sdk_config.h"
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "app_util.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_hrs.h"
#include "ble_hrs_c.h"
#include "ble_conn_state.h"
#include "fds.h"
#include "nrf_crypto.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_lesc.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "ble_lbs.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define LEDBUTTON_LED                   BSP_BOARD_LED_0                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0
#define LESC_DEBUG_MODE                 0                                               /**< Set to 1 to use the LESC debug keys. The debug mode allows you to use a sniffer to inspect traffic. */
#define LESC_MITM_NC                    1                                               /**< Use MITM (Numeric Comparison). */
/** @brief The maximum number of peripheral and central links combined. */
#define NRF_BLE_LINK_COUNT              (NRF_SDH_BLE_PERIPHERAL_LINK_COUNT + NRF_SDH_BLE_CENTRAL_LINK_COUNT)
#define APP_BLE_CONN_CFG_TAG            1                                               /**< Tag that identifies the SoftDevice BLE configuration. */
//#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
//#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_4
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_5
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define SCAN_DURATION                   0x0000                                          /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
#define APP_ADV_DURATION                18000                                           /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define SEC_PARAMS_BOND                 1                                               /**< Perform bonding. */
#if LESC_MITM_NC
#define SEC_PARAMS_MITM                 1                                               /**< Man In The Middle protection required. */
#define SEC_PARAMS_IO_CAPABILITIES      BLE_GAP_IO_CAPS_DISPLAY_YESNO                   /**< Display Yes/No to force Numeric Comparison. */
#else
#define SEC_PARAMS_MITM                 0                                               /**< Man In The Middle protection required. */
#define SEC_PARAMS_IO_CAPABILITIES      BLE_GAP_IO_CAPS_NONE                            /**< No I/O caps. */
#define SEC_PARAMS_LESC                 1                                               /**< LE Secure Connections pairing required. */
#define SEC_PARAMS_KEYPRESS             0                                               /**< Keypress notifications not required. */
#define SEC_PARAMS_OOB                  0                                               /**< Out Of Band data not available. */
#define SEC_PARAMS_MIN_KEY_SIZE         7                                               /**< Minimum encryption key size in octets. */
#define SEC_PARAMS_MAX_KEY_SIZE         16                                              /**< Maximum encryption key size in octets. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                           /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                          /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                               /**< Number of attempts before giving up the connection parameter negotiation. */
/**@brief   Priority of the application BLE event handler.
 * @note    There is no need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
typedef struct
    bool           is_connected;
    ble_gap_addr_t address;
} conn_peer_t;
NRF_BLE_GQ_DEF(m_ble_gatt_queue,                                            /**< BLE GATT Queue instance. */
               NRF_SDH_BLE_CENTRAL_LINK_COUNT,
               NRF_BLE_GQ_QUEUE_SIZE);
BLE_HRS_DEF(m_hrs);                                                         /**< Heart Rate Service instance. */
BLE_LBS_DEF(m_lbs);
BLE_HRS_C_DEF(m_hrs_c);                                                     /**< Structure used to identify the Heart Rate client module. */
NRF_BLE_GATT_DEF(m_gatt);                                                   /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);
//NRF_BLE_QWR_DEF(m_qwr);                    /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising);                                         /**< Advertising module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                            /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                                   /**< Scanning Module instance. */
static uint16_t           m_conn_handle_hrs_c                = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the HRS central application. */
static volatile uint16_t  m_conn_handle_num_comp_central     = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the central that needs a numeric comparison button press. */
static volatile uint16_t  m_conn_handle_num_comp_peripheral  = BLE_CONN_HANDLE_INVALID;  /**< Connection handle for the peripheral that needs a numeric comparison button press. */
static conn_peer_t        m_connected_peers[NRF_BLE_LINK_COUNT];                         /**< Array of connected peers. */
static char * roles_str[] =
    "INVALID_ROLE",
    "PERIPHERAL",
    "CENTRAL",
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state);
static void services_init(void);
/**@brief Names that the central application scans for, and that are advertised by the peripherals.
 *  If these are set to empty strings, the UUIDs defined below are used.
static const char m_target_periph_name[] = "";
/**@brief UUIDs that the central application scans for if the name above is set to an empty string,
 * and that are to be advertised by the peripherals.
static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_HEART_RATE_SERVICE,         BLE_UUID_TYPE_BLE},
                                   {BLE_UUID_RUNNING_SPEED_AND_CADENCE,  BLE_UUID_TYPE_BLE}};
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Heart Rate Service Client.
static void hrs_c_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling errors from the Connection Parameters module.
 * @param[in] nrf_error  Error code that contains information about what went wrong.
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    ble_uuid_t          target_uuid =
        .uuid = BLE_UUID_HEART_RATE_SERVICE,
        .type = BLE_UUID_TYPE_BLE
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    if (strlen(m_target_periph_name) != 0)
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
                                       SCAN_UUID_FILTER,
                                       &target_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_NAME_FILTER | NRF_BLE_SCAN_UUID_FILTER,
                                           false);
/**@brief Function for initializing the scanning.
static void scan_start(void)
    err_code = nrf_ble_scan_start(&m_scan);
    NRF_LOG_INFO("Scanning");
/**@brief Function for initializing the advertising and the scanning.
static void adv_scan_start(void)
    scan_start();
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
    // Start advertising.
    err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    NRF_LOG_INFO("Advertising");
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            adv_scan_start();
/**@brief Function for changing filter settings after establishing the connection.
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
                                           SCAN_NAME_FILTER,
/**@brief Handles events coming from the Heart Rate central module.
static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_hrs_c = p_hrs_c_evt->conn_handle;
                // We do not want to connect to two peripherals offering the same service, so when
                // a UUID is matched, we check whether we are not already connected to a peer which
                // offers the same service
                filter_settings_change();
                NRF_LOG_INFO("CENTRAL: HRS discovered on conn_handle 0x%x",
                             m_conn_handle_hrs_c);
                err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                    m_conn_handle_hrs_c,
                                                    &p_hrs_c_evt->params.peer_db);
                // Heart rate service discovered. Enable notification of Heart Rate Measurement.
                err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break; // BLE_HRS_C_EVT_DISCOVERY_COMPLETE
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("CENTRAL: Heart Rate = %d", p_hrs_c_evt->params.hrm.hr_value);
        } break;
            // No implementation needed.
/**@brief Function for checking whether a link already exists with a newly connected peer.
 * @details This function checks whether the newly connected device is already connected.
 * @param[in]   p_connected_evt Bluetooth connected event.
 * @return                      True if the peer's address is found in the list of connected peers,
 *                              false otherwise.
static bool is_already_connected(ble_gap_addr_t const * p_connected_adr)
    for (uint32_t i = 0; i < NRF_BLE_LINK_COUNT; i++)
        if (m_connected_peers[i].is_connected)
            if (m_connected_peers[i].address.addr_type == p_connected_adr->addr_type)
                if (memcmp(m_connected_peers[i].address.addr,
                           p_connected_adr->addr,
                           sizeof(m_connected_peers[i].address.addr)) == 0)
                    return true;
    return false;
/** @brief Function for handling a numeric comparison match request. */
static void on_match_request(uint16_t conn_handle, uint8_t role)
    // Mark the appropriate conn_handle as pending. The rest is handled on button press.
    NRF_LOG_INFO("Press Button 1 to confirm, Button 2 to reject");
    if (role == BLE_GAP_ROLE_CENTRAL)
        m_conn_handle_num_comp_central = conn_handle;
    else if (role == BLE_GAP_ROLE_PERIPH)
        m_conn_handle_num_comp_peripheral = conn_handle;
/**@brief Function for assigning new connection handle to the available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief Function for handling BLE Stack events that are common to both the central and peripheral roles.
 * @param[in] conn_handle Connection Handle.
 * @param[in] p_ble_evt  Bluetooth stack event.
static void on_ble_evt(uint16_t conn_handle, ble_evt_t const * p_ble_evt)
    char        passkey[BLE_GAP_PASSKEY_LEN + 1];
    uint16_t    role = ble_conn_state_role(conn_handle);
    pm_handler_secure_on_connection(p_ble_evt);
        case BLE_GAP_EVT_CONNECTED:
            m_connected_peers[conn_handle].is_connected = true;
            m_connected_peers[conn_handle].address = p_ble_evt->evt.gap_evt.params.connected.peer_addr;
            multi_qwr_conn_handle_assign(conn_handle);
            memset(&m_connected_peers[conn_handle], 0x00, sizeof(m_connected_peers[0]));
            NRF_LOG_INFO("%s: BLE_GAP_EVT_SEC_PARAMS_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_PASSKEY_DISPLAY:
            memcpy(passkey, p_ble_evt->evt.gap_evt.params.passkey_display.passkey, BLE_GAP_PASSKEY_LEN);
            passkey[BLE_GAP_PASSKEY_LEN] = 0x00;
            NRF_LOG_INFO("%s: BLE_GAP_EVT_PASSKEY_DISPLAY: passkey=%s match_req=%d",
                         nrf_log_push(roles_str[role]),
                         nrf_log_push(passkey),
                         p_ble_evt->evt.gap_evt.params.passkey_display.match_request);
            if (p_ble_evt->evt.gap_evt.params.passkey_display.match_request)
                on_match_request(conn_handle, role);
        case BLE_GAP_EVT_AUTH_KEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_KEY_REQUEST", nrf_log_push(roles_str[role]));
        case BLE_GAP_EVT_LESC_DHKEY_REQUEST:
            NRF_LOG_INFO("%s: BLE_GAP_EVT_LESC_DHKEY_REQUEST", nrf_log_push(roles_str[role]));
         case BLE_GAP_EVT_AUTH_STATUS:
             NRF_LOG_INFO("%s: BLE_GAP_EVT_AUTH_STATUS: status=0x%x bond=0x%x lv4: %d kdist_own:0x%x kdist_peer:0x%x",
                          p_ble_evt->evt.gap_evt.params.auth_status.auth_status,
                          p_ble_evt->evt.gap_evt.params.auth_status.bonded,
                          p_ble_evt->evt.gap_evt.params.auth_status.sm1_levels.lv4,
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_own),
                          *((uint8_t *)&p_ble_evt->evt.gap_evt.params.auth_status.kdist_peer));
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
            ret_code_t err_code = sd_ble_gap_phy_update(p_ble_evt->evt.gap_evt.conn_handle, &phys);
        } break;
/**@brief Function for handling BLE Stack events that are related to central application.
 * @details This function keeps the connection handles of central application up-to-date. It
 * parses scanning reports, initiates a connection attempt to peripherals when a target UUID
 * is found, and manages connection parameter update requests. Additionally, it updates the status
 * of LEDs used to report the central application's activity.
 * @note        Since this function updates connection handles, @ref BLE_GAP_EVT_DISCONNECTED events
 *              must be dispatched to the target application before invoking this function.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
        //  discovery, update LEDs status, and resume scanning, if necessary.
            NRF_LOG_INFO("CENTRAL: Connected, handle: %d.", p_gap_evt->conn_handle);
            // If no Heart Rate Sensor is currently connected, try to find them on this peripheral.
                NRF_LOG_INFO("CENTRAL: Searching for HRS on conn_handle 0x%x", p_gap_evt->conn_handle);
                err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
            // Update status of LEDs.
            bsp_board_led_off(CENTRAL_SCANNING_LED);
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected, update
        // the status of LEDs, and start scanning again.
            NRF_LOG_INFO("CENTRAL: Disconnected, handle: %d, reason: 0x%x",
                         p_gap_evt->conn_handle,
                       p_gap_evt->params.disconnected.reason);
            // Update the status of LEDs.
            bsp_board_led_off(CENTRAL_CONNECTED_LED);
            if (p_gap_evt->conn_handle == m_conn_handle_hrs_c)
                ble_uuid_t target_uuid = {.uuid = BLE_UUID_HEART_RATE_SERVICE, .type = BLE_UUID_TYPE_BLE};
                                                   SCAN_UUID_FILTER,
                                                   &target_uuid);
            scan_start();
        } break; // BLE_GAP_EVT_DISCONNECTED
        case BLE_GAP_EVT_TIMEOUT:
            // Timeout for scanning is not specified, so only connection attemps can time out.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("CENTRAL: Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            NRF_LOG_DEBUG("CENTRAL: GATT Client Timeout.");
        case BLE_GATTS_EVT_TIMEOUT:
            NRF_LOG_DEBUG("CENTRAL: GATT Server Timeout.");
/**@brief Function for handling BLE Stack events that involves peripheral applications. Manages the
 * LEDs used to report the status of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("PERIPHERAL: Connected, handle %d.", p_ble_evt->evt.gap_evt.conn_handle);
            bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            NRF_LOG_INFO("PERIPHERAL: Disconnected, handle %d, reason 0x%x.",
                         p_ble_evt->evt.gap_evt.params.disconnected.reason);
            NRF_LOG_DEBUG("PERIPHERAL: GATT Client Timeout.");
            NRF_LOG_DEBUG("PERIPHERAL: GATT Server Timeout.");
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
        case BLE_ADV_EVT_IDLE:
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        } break;
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    if (    (p_ble_evt->header.evt_id == BLE_GAP_EVT_CONNECTED)
        &&  (is_already_connected(&p_ble_evt->evt.gap_evt.params.connected.peer_addr)))
        NRF_LOG_INFO("%s: Already connected to this device as %s (handle: %d), disconnecting.",
                     (role == BLE_GAP_ROLE_PERIPH) ? "PERIPHERAL" : "CENTRAL",
                     (role == BLE_GAP_ROLE_PERIPH) ? "CENTRAL"    : "PERIPHERAL",
                     conn_handle);
        (void)sd_ble_gap_disconnect(conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // Do not process the event further.
        return;
    on_ble_evt(conn_handle, p_ble_evt);
        // Manages peripheral LEDs.
        on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
        on_ble_central_evt(p_ble_evt);
/**@brief Function for initializing the Heart Rate Service client. */
static void hrs_c_init(void)
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler   = hrs_c_evt_handler;
    hrs_c_init_obj.error_handler = hrs_c_error_handler;
    hrs_c_init_obj.p_gatt_queue  = &m_ble_gatt_queue;
    err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
     // Configure the BLE stack by using the default settings.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing the Peer Manager. */
static void peer_manager_init(void)
    ble_gap_sec_params_t sec_params;
    err_code = pm_init();
    memset(&sec_params, 0, sizeof(ble_gap_sec_params_t));
    sec_params.bond           = SEC_PARAMS_BOND;
    sec_params.mitm           = SEC_PARAMS_MITM;
    sec_params.lesc           = SEC_PARAMS_LESC;
    sec_params.keypress       = SEC_PARAMS_KEYPRESS;
    sec_params.io_caps        = SEC_PARAMS_IO_CAPABILITIES;
    sec_params.oob            = SEC_PARAMS_OOB;
    sec_params.min_key_size   = SEC_PARAMS_MIN_KEY_SIZE;
    sec_params.max_key_size   = SEC_PARAMS_MAX_KEY_SIZE;
    sec_params.kdist_own.enc  = 1;
    sec_params.kdist_own.id   = 1;
    sec_params.kdist_peer.enc = 1;
    sec_params.kdist_peer.id  = 1;
    err_code = pm_sec_params_set(&sec_params);
/** @brief Delete all data stored for all peers. */
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/** @brief Function for accepting or rejecting a numeric comparison. */
static void num_comp_reply(uint16_t conn_handle, bool accept)
    uint8_t    key_type;
    if (accept)
        NRF_LOG_INFO("Numeric Match. Conn handle: %d", conn_handle);
        key_type = BLE_GAP_AUTH_KEY_TYPE_PASSKEY;
        NRF_LOG_INFO("Numeric REJECT. Conn handle: %d", conn_handle);
        key_type = BLE_GAP_AUTH_KEY_TYPE_NONE;
    err_code = sd_ble_gap_auth_key_reply(conn_handle,
                                         key_type,
                                         NULL);
/** @brief Function for handling button presses for numeric comparison match requests. */
static void on_num_comp_button_press(bool accept)
    // Check whether any links have pending match requests, and if so, send a reply.
    if (m_conn_handle_num_comp_central != BLE_CONN_HANDLE_INVALID)
        num_comp_reply(m_conn_handle_num_comp_central, accept);
    else if (m_conn_handle_num_comp_peripheral != BLE_CONN_HANDLE_INVALID)
        num_comp_reply(m_conn_handle_num_comp_peripheral, accept);
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    switch (event)
        case BSP_EVENT_KEY_0:
            err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, 87);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
            on_num_comp_button_press(true);
      case BSP_EVENT_KEY_1:
            on_num_comp_button_press(false);
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  True if the clear bonding button is pressed to
 *                            wake the application up. False otherwise.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
/**@brief Function for initializing the GAP.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device, including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    gap_conn_params = m_scan.conn_params;
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details A pointer to this function is passed to each service that may need to inform the
/**@brief Function for initializing the Queued Write instances.
static void qwr_init(void)
    nrf_ble_qwr_init_t qwr_init_obj = {0};
    qwr_init_obj.error_handler = nrf_qwr_error_handler;
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init_obj);
/**@brief Function for initializing the Connection Parameters module. */
    cp_init.start_on_notify_cccd_handle    = BLE_GATT_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_hrs_on_db_disc_evt(&m_hrs_c, p_evt);
/**@brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
    ble_db_discovery_init_t db_init;
    memset(&db_init, 0, sizeof(db_init));
    db_init.evt_handler =  db_disc_handler;
    db_init.p_gatt_queue = &m_ble_gatt_queue;
    ret_code_t err_code = ble_db_discovery_init(&db_init);
/**@brief Function for initializing the Heart Rate service. */
static void hrs_init(void)
    ble_hrs_init_t hrs_init_params;
    uint8_t        body_sensor_location;
    // Initialize the Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init_params, 0, sizeof(hrs_init_params));
    hrs_init_params.evt_handler                 = NULL;
    hrs_init_params.is_sensor_contact_supported = true;
    hrs_init_params.p_body_sensor_location      = &body_sensor_location;
    // Require LESC with MITM (Numeric Comparison).
    hrs_init_params.hrm_cccd_wr_sec = SEC_MITM;
    hrs_init_params.bsl_rd_sec      = SEC_MITM;
    err_code = ble_hrs_init(&m_hrs, &hrs_init_params);
/**@brief Function for initializing the advertising functionality. */
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    init.advdata.include_appearance      = true;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    init.config.ble_adv_fast_interval = ADV_INTERVAL;
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing the timer. */
static void timer_init(void)
 * @details Handles any pending log or key operations, or both, then sleeps until the next event occurs.
    err_code = nrf_ble_lesc_request_handler();
        nrf_pwr_mgmt_run();
    bool erase_bonds;
    // Initialize.
    log_init();
    timer_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    qwr_init();
  //  hrs_init();
   // hrs_c_init();
    services_init();
    peer_manager_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("LE Secure Connections example started.");
    if (erase_bonds == true)
        delete_bonds();
        // Scanning and advertising is started by PM_EVT_PEERS_DELETE_SUCEEDED.
        adv_scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
    // Initialize LBS.
    if (led_state)
can anyone help me?
my goal is to only reserve the
PERIPHERAL_ADVERTISING and PERIPHERAL_CONNECTED in ble_app_multirole_lesc
and add GATT service and characteristics of ble_led_blink into ble_app_multirole_lesc
I dont need the CENTRAL in ble_app_multirole_lesc
I have upload it the proj
