MbedTLS RNG fail
I am trying to generate ECC key pairs using MbedTLS on Connect SDK.
I found this code block on stackoverflow and validated from mbedtls/programs.
    mbedtls_pk_context key;
    mbedtls_entropy_context entropy;
    mbedtls_ctr_drbg_context ctr_drbg;
    mbedtls_pk_type_t pk_alg = MBEDTLS_PK_ECKEY;
    mbedtls_pk_init(&key);
    mbedtls_entropy_init( &entropy );
    mbedtls_ctr_drbg_init(&ctr_drbg);
    ret = mbedtls_pk_setup(&key, mbedtls_pk_info_from_type(pk_alg));
    ret = mbedtls_ctr_drbg_seed(&ctr_drbg, mbedtls_entropy_func,
                               &entropy,
                               (const unsigned char *) "ecdsa",
                               strlen(pers)
    ret = mbedtls_ecp_gen_key(<KEY TYPE>,
                              mbedtls_pk_ec(key),
                              mbedtls_ctr_drbg_random,
                              &ctr_drbg
"mbedtls_ctr_drbg_seed" function returns "-52" because "mbedtls_entropy_func" not working properly.
You may find auto generated conf.
CONFIG_GPIO=y
# CONFIG_SPI is not set
# CONFIG_I2C is not set
# CONFIG_KSCAN is not set
# CONFIG_WIFI is not set
CONFIG_NET_CONFIG_IEEE802154_DEV_NAME="DW1000"
# CONFIG_MODEM is not set
CONFIG_BOARD="decawave_dwm1001_dev"
CONFIG_SOC="nRF52832_QFAA"
CONFIG_SOC_SERIES="nrf52"
CONFIG_NUM_IRQS=39
CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
CONFIG_HEAP_MEM_POOL_SIZE=0
# CONFIG_WATCHDOG is not set
CONFIG_PM=y
# CONFIG_PM_DEVICE is not set
CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
# CONFIG_CORTEX_M_SYSTICK is not set
CONFIG_NRF52_ANOMALY_132_WORKAROUND=y
CONFIG_CLOCK_CONTROL=y
CONFIG_NRF_RTC_TIMER=y
CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
CONFIG_BUILD_OUTPUT_HEX=y
# CONFIG_FPU is not set
CONFIG_ROM_START_OFFSET=0
CONFIG_FLASH_SIZE=512
CONFIG_FLASH_BASE_ADDRESS=0x0
# CONFIG_GPIO_MCUX is not set
# CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
# CONFIG_TINYCRYPT is not set
# CONFIG_SERIAL is not set
# CONFIG_SRAM_VECTOR_TABLE is not set
# Modules
# Available modules.
# nrf (D:NRFtoolchainv1.6.1nrf)
# Nordic nRF Connect
CONFIG_MAIN_STACK_SIZE=1024
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_ENTROPY_GENERATOR=y
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
# Bootloader
# CONFIG_BUILD_S1_VARIANT is not set
# CONFIG_SECURE_BOOT is not set
CONFIG_PM_PARTITION_SIZE_PROVISION=0x1000
# CONFIG_B0_MIN_PARTITION_SIZE is not set
CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x7000
# CONFIG_SECURE_BOOT_CRYPTO is not set
# Secure Boot firmware validation
CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
CONFIG_SB_VALIDATION_INFO_VERSION=2
CONFIG_SB_VALIDATION_METADATA_OFFSET=0
CONFIG_SB_VALIDATE_FW_SIGNATURE=y
# end of Secure Boot firmware validation
# end of Bootloader
# Bluetooth Low Energy
CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1024
# BLE over nRF RPC
# end of BLE over nRF RPC
# end of Bluetooth Low Energy
# DFU
# DFU
# CONFIG_DFU_TARGET is not set
# end of DFU
CONFIG_MBEDTLS_HEAP_SIZE=512
# end of DFU
# CONFIG_ESB is not set
# Peripheral CPU DFU (PCD)
# CONFIG_PCD is not set
# end of Peripheral CPU DFU (PCD)
# Networking
# Application protocols
# CONFIG_NRF_CLOUD is not set
# CONFIG_DOWNLOAD_CLIENT is not set
# CONFIG_AWS_IOT is not set
# CONFIG_AWS_JOBS is not set
# CONFIG_AZURE_IOT_HUB is not set
# CONFIG_CLOUD_API is not set
# Self-Registration (Zi ZHu Ce)
# end of Self-Registration (Zi ZHu Ce)
# CONFIG_ICAL_PARSER is not set
# CONFIG_FTP_CLIENT is not set
# CONFIG_LWM2M_CLIENT_UTILS is not set
# end of Application protocols
# end of Networking
# NFC
# CONFIG_NFC_NDEF is not set
# CONFIG_NFC_NDEF_PARSER is not set
# CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
# CONFIG_NFC_T2T_PARSER is not set
# CONFIG_NFC_T4T_NDEF_FILE is not set
# CONFIG_NFC_T4T_ISODEP is not set
# CONFIG_NFC_T4T_APDU is not set
# CONFIG_NFC_T4T_CC_FILE is not set
# CONFIG_NFC_T4T_HL_PROCEDURE is not set
# CONFIG_NFC_PLATFORM is not set
# CONFIG_NFC_TNEP_TAG is not set
# CONFIG_NFC_TNEP_POLLER is not set
# CONFIG_NFC_TNEP_CH is not set
# end of NFC
# CONFIG_PROFILER is not set
# SPM
# CONFIG_SPM is not set
# CONFIG_IS_SPM is not set
# end of SPM
# CONFIG_FW_INFO is not set
# CONFIG_PPI_TRACE is not set
# CONFIG_CPU_LOAD is not set
# Nordic MPSL
CONFIG_MPSL_THREAD_COOP_PRIO=8
CONFIG_MPSL_SIGNAL_STACK_SIZE=1024
CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
# CONFIG_MPSL_ASSERT_HANDLER is not set
# CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
# end of Nordic MPSL
# Partition Manager
# CONFIG_PARTITION_MANAGER_ENABLED is not set
CONFIG_SRAM_SIZE=64
CONFIG_SRAM_BASE_ADDRESS=0x20000000
# Zephyr subsystem configurations
# end of Zephyr subsystem configurations
# Zephyr samples configurations
# end of Zephyr samples configurations
# NCS subsystem configurations
# NCS samples configurations
# end of NCS samples configurations
# CONFIG_PM_SINGLE_IMAGE is not set
# CONFIG_PM_EXTERNAL_FLASH is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x10000
# end of Partition Manager
# nRF RPC (Remote Procedure Call) library
# end of nRF RPC (Remote Procedure Call) library
# Full Modem Firmware Update Management(FMFU)
# end of Full Modem Firmware Update Management(FMFU)
# CONFIG_CAF is not set
CONFIG_BOOT_SIGNATURE_KEY_FILE=""
CONFIG_INIT_ARCH_HW_AT_BOOT=y
# CONFIG_CDDL_GEN is not set
# Libraries
# CONFIG_AGPS is not set
# Binary libraries
# end of Binary libraries
# CONFIG_NRF_MODEM_LIB is not set
# BSD library (deprecated)
# All the configs below are deprecated, please use NRF_MODEM_LIB equivalents instead
# CONFIG_BSD_LIBRARY is not set
# end of BSD library (deprecated)
# CONFIG_ADP536X is not set
# AT Command driver
# end of AT Command driver
# CONFIG_LTE_LINK_CONTROL is not set
# CONFIG_FPROTECT is not set
CONFIG_NRF_BPROT_FLASH_REGION_SIZE=0x1000
CONFIG_FPROTECT_BLOCK_SIZE=0x1000
# AT Host Library for nrf91
# CONFIG_AT_HOST_LIBRARY is not set
# end of AT Host Library for nrf91
# CONFIG_DK_LIBRARY is not set
# CONFIG_MODEM_INFO is not set
CONFIG_RESET_ON_FATAL_ERROR=y
# CONFIG_SMS is not set
# CONFIG_SUPL_CLIENT_LIB is not set
# CONFIG_DATE_TIME is not set
# CONFIG_RAM_POWER_DOWN_LIBRARY is not set
# CONFIG_WAVE_GEN_LIB is not set
CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=1500
# CONFIG_MODEM_JWT is not set
# end of Libraries
# Device Drivers
# CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
# CONFIG_ETH_RTT is not set
# CONFIG_SENSOR is not set
# GPS Drivers
# CONFIG_GPS_SIM is not set
# end of GPS Drivers
# CONFIG_NRF_SW_LPUART is not set
# end of Device Drivers
# External libraries
# end of External libraries
# CONFIG_UNITY is not set
# end of Nordic nRF Connect
CONFIG_ZEPHYR_NRF_MODULE=y
# end of nrf (D:NRFtoolchainv1.6.1nrf)
# mcuboot (D:NRFtoolchainv1.6.1bootloadermcuboot)
# MCUboot
CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
# end of MCUboot
CONFIG_ZEPHYR_MCUBOOT_MODULE=y
# end of mcuboot (D:NRFtoolchainv1.6.1bootloadermcuboot)
# trusted-firmware-m (D:NRFtoolchainv1.6.1modulesteetfm)
# CONFIG_TFM_MINIMAL is not set
CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
# end of trusted-firmware-m (D:NRFtoolchainv1.6.1modulesteetfm)
# cjson (D:NRFtoolchainv1.6.1moduleslibcjson)
CONFIG_ZEPHYR_CJSON_MODULE=y
# end of cjson (D:NRFtoolchainv1.6.1moduleslibcjson)
# pelion-dm (D:NRFtoolchainv1.6.1moduleslibpelion-dm)
CONFIG_MBEDTLS_CFG_FILE="config-tls-generic.h"
CONFIG_ZEPHYR_PELION_DM_MODULE=y
# end of pelion-dm (D:NRFtoolchainv1.6.1moduleslibpelion-dm)
# cddl-gen (D:NRFtoolchainv1.6.1moduleslibcddl-gen)
CONFIG_ZEPHYR_CDDL_GEN_MODULE=y
# end of cddl-gen (D:NRFtoolchainv1.6.1moduleslibcddl-gen)
# memfault-firmware-sdk (D:NRFtoolchainv1.6.1moduleslibmemfault-firmware-sdk)
# CONFIG_MEMFAULT is not set
CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
# end of memfault-firmware-sdk (D:NRFtoolchainv1.6.1moduleslibmemfault-firmware-sdk)
# hal_nordic (D:NRFtoolchainv1.6.1moduleshalnordic)
CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
CONFIG_HAS_NORDIC_DRIVERS=y
# Nordic drivers
# CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
# CONFIG_NRF_802154_SER_HOST is not set
# end of Nordic drivers
CONFIG_HAS_NRFX=y
# nrfx drivers
CONFIG_NRFX_CLOCK=y
CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
# CONFIG_NRFX_COMP is not set
# CONFIG_NRFX_EGU is not set
# CONFIG_NRFX_EGU0 is not set
# CONFIG_NRFX_EGU1 is not set
# CONFIG_NRFX_EGU2 is not set
# CONFIG_NRFX_EGU3 is not set
# CONFIG_NRFX_EGU4 is not set
# CONFIG_NRFX_EGU5 is not set
CONFIG_NRFX_GPIOTE=y
# CONFIG_NRFX_I2S is not set
# CONFIG_NRFX_LPCOMP is not set
# CONFIG_NRFX_NFCT is not set
# CONFIG_NRFX_NVMC is not set
# CONFIG_NRFX_PDM is not set
# CONFIG_NRFX_POWER is not set
# CONFIG_NRFX_PPI is not set
# CONFIG_NRFX_PWM is not set
# CONFIG_NRFX_PWM0 is not set
# CONFIG_NRFX_PWM1 is not set
# CONFIG_NRFX_PWM2 is not set
# CONFIG_NRFX_QDEC is not set
CONFIG_NRFX_RNG=y
# CONFIG_NRFX_RTC is not set
# CONFIG_NRFX_RTC0 is not set
# CONFIG_NRFX_RTC1 is not set
# CONFIG_NRFX_RTC2 is not set
# CONFIG_NRFX_SAADC is not set
# CONFIG_NRFX_SPI is not set
# CONFIG_NRFX_SPI0 is not set
# CONFIG_NRFX_SPI1 is not set
# CONFIG_NRFX_SPI2 is not set
# CONFIG_NRFX_SPIM is not set
# CONFIG_NRFX_SPIM0 is not set
# CONFIG_NRFX_SPIM1 is not set
# CONFIG_NRFX_SPIM2 is not set
# CONFIG_NRFX_SPIS is not set
# CONFIG_NRFX_SPIS0 is not set
# CONFIG_NRFX_SPIS1 is not set
# CONFIG_NRFX_SPIS2 is not set
# CONFIG_NRFX_SYSTICK is not set
# CONFIG_NRFX_TEMP is not set
# CONFIG_NRFX_TIMER is not set
# CONFIG_NRFX_TIMER0 is not set
# CONFIG_NRFX_TIMER1 is not set
# CONFIG_NRFX_TIMER2 is not set
# CONFIG_NRFX_TIMER3 is not set
# CONFIG_NRFX_TIMER4 is not set
# CONFIG_NRFX_TWI is not set
# CONFIG_NRFX_TWI0 is not set
# CONFIG_NRFX_TWI1 is not set
# CONFIG_NRFX_TWIM is not set
# CONFIG_NRFX_TWIM0 is not set
# CONFIG_NRFX_TWIM1 is not set
# CONFIG_NRFX_TWIS is not set
# CONFIG_NRFX_TWIS0 is not set
# CONFIG_NRFX_TWIS1 is not set
# CONFIG_NRFX_UART is not set
# CONFIG_NRFX_UART0 is not set
# CONFIG_NRFX_UARTE is not set
# CONFIG_NRFX_UARTE0 is not set
# CONFIG_NRFX_WDT is not set
# CONFIG_NRFX_WDT0 is not set
# CONFIG_NRFX_PRS is not set
# CONFIG_NRFX_PRS_BOX_0 is not set
# CONFIG_NRFX_PRS_BOX_1 is not set
# CONFIG_NRFX_PRS_BOX_2 is not set
# CONFIG_NRFX_PRS_BOX_3 is not set
# CONFIG_NRFX_PRS_BOX_4 is not set
# end of nrfx drivers
# end of hal_nordic (D:NRFtoolchainv1.6.1moduleshalnordic)
# mbedtls (D:NRFtoolchainv1.6.1modulescryptombedtls)
CONFIG_ZEPHYR_MBEDTLS_MODULE=y
CONFIG_MBEDTLS=y
CONFIG_MBEDTLS_BUILTIN=y
# CONFIG_MBEDTLS_LIBRARY is not set
# CONFIG_CUSTOM_MBEDTLS_CFG_FILE is not set
# TLS configuration
# Supported TLS version
# CONFIG_MBEDTLS_TLS_VERSION_1_0 is not set
# CONFIG_MBEDTLS_TLS_VERSION_1_1 is not set
CONFIG_MBEDTLS_TLS_VERSION_1_2=y
# CONFIG_MBEDTLS_DTLS is not set
# CONFIG_MBEDTLS_SSL_EXPORT_KEYS is not set
# CONFIG_MBEDTLS_SSL_ALPN is not set
# end of Supported TLS version
# Ciphersuite configuration
# Supported key exchange modes
# CONFIG_MBEDTLS_KEY_EXCHANGE_ALL_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_PSK_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_PSK_ENABLED is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA_ENABLED=y
# CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA_ENABLED is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA_ENABLED is not set
# CONFIG_MBEDTLS_ECDSA_DETERMINISTIC is not set
# CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA_ENABLED is not set
CONFIG_MBEDTLS_KEY_EXCHANGE_ECJPAKE_ENABLED=y
# Supported elliptic curves
CONFIG_MBEDTLS_ECP_ALL_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE448_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# Supported cipher modes
CONFIG_MBEDTLS_CIPHER_ALL_ENABLED=y
CONFIG_MBEDTLS_CIPHER_AES_ENABLED=y
CONFIG_MBEDTLS_AES_ROM_TABLES=y
CONFIG_MBEDTLS_CIPHER_CAMELLIA_ENABLED=y
CONFIG_MBEDTLS_CIPHER_DES_ENABLED=y
CONFIG_MBEDTLS_CIPHER_ARC4_ENABLED=y
CONFIG_MBEDTLS_CIPHER_CHACHA20_ENABLED=y
CONFIG_MBEDTLS_CIPHER_BLOWFISH_ENABLED=y
CONFIG_MBEDTLS_CIPHER_CCM_ENABLED=y
CONFIG_MBEDTLS_CIPHER_GCM_ENABLED=y
CONFIG_MBEDTLS_CIPHER_MODE_XTS_ENABLED=y
CONFIG_MBEDTLS_CIPHER_MODE_CBC_ENABLED=y
CONFIG_MBEDTLS_CIPHER_MODE_CTR_ENABLED=y
CONFIG_MBEDTLS_CHACHAPOLY_AEAD_ENABLED=y
# Supported message authentication methods
CONFIG_MBEDTLS_MAC_ALL_ENABLED=y
CONFIG_MBEDTLS_MAC_MD4_ENABLED=y
CONFIG_MBEDTLS_MAC_MD5_ENABLED=y
CONFIG_MBEDTLS_MAC_SHA1_ENABLED=y
CONFIG_MBEDTLS_MAC_SHA256_ENABLED=y
CONFIG_MBEDTLS_SHA256_SMALLER=y
CONFIG_MBEDTLS_MAC_SHA512_ENABLED=y
CONFIG_MBEDTLS_MAC_POLY1305_ENABLED=y
CONFIG_MBEDTLS_MAC_CMAC_ENABLED=y
# end of Ciphersuite configuration
# Random number generators
CONFIG_MBEDTLS_CTR_DRBG_ENABLED=y
CONFIG_MBEDTLS_HMAC_DRBG_ENABLED=y
# Other configurations
CONFIG_MBEDTLS_CIPHER=y
CONFIG_MBEDTLS_MD=y
CONFIG_MBEDTLS_GENPRIME_ENABLED=y
# CONFIG_MBEDTLS_PEM_CERTIFICATE_FORMAT is not set
# CONFIG_MBEDTLS_HAVE_ASM is not set
CONFIG_MBEDTLS_ENTROPY_ENABLED=y
# CONFIG_MBEDTLS_USER_CONFIG_ENABLE is not set
# CONFIG_MBEDTLS_SERVER_NAME_INDICATION is not set
CONFIG_MBEDTLS_PK_WRITE_C=y
# end of TLS configuration
# CONFIG_MBEDTLS_DEBUG is not set
# CONFIG_MBEDTLS_MEMORY_DEBUG is not set
# CONFIG_MBEDTLS_TEST is not set
CONFIG_APP_LINK_WITH_MBEDTLS=y
# end of mbedtls (D:NRFtoolchainv1.6.1modulescryptombedtls)
# TraceRecorder (D:NRFtoolchainv1.6.1modulesdebugTraceRecorder)
CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
# end of TraceRecorder (D:NRFtoolchainv1.6.1modulesdebugTraceRecorder)
# nrfxlib (D:NRFtoolchainv1.6.1nrfxlib)
# Nordic nrfxlib
CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
# CONFIG_NFC_T2T_NRFXLIB is not set
# CONFIG_NFC_T4T_NRFXLIB is not set
# CONFIG_MPSL is not set
# Crypto libraries for nRF5x SOCs.
# CONFIG_NRF_OBERON is not set
# CONFIG_NRF_CC310_BL is not set
# end of Crypto libraries for nRF5x SOCs.
# Nordic Security
# CONFIG_NORDIC_SECURITY_BACKEND is not set
# end of Nordic Security
# CONFIG_NRF_RPC is not set
CONFIG_NRF_802154_SOURCE_NRFXLIB=y
# end of Nordic nrfxlib
CONFIG_ZEPHYR_NRFXLIB_MODULE=y
# end of nrfxlib (D:NRFtoolchainv1.6.1nrfxlib)
# connectedhomeip (D:NRFtoolchainv1.6.1moduleslibmatter)
# CONFIG_CHIP is not set
CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
# end of connectedhomeip (D:NRFtoolchainv1.6.1moduleslibmatter)
# Optional modules. Make sure they're installed, via the project manifest.
# CONFIG_CANOPENNODE is not set
# CONFIG_CIVETWEB is not set
CONFIG_HAS_CMSIS_CORE=y
CONFIG_HAS_CMSIS_CORE_M=y
# CONFIG_LIBMETAL is not set
# CONFIG_HAS_SEMTECH_LORAMAC is not set
# CONFIG_HAS_SEMTECH_SOFT_SE is not set
# CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
# CONFIG_HAS_MEC_HAL is not set
# CONFIG_OPENAMP is not set
# CONFIG_SOF is not set
# CONFIG_MIPI_SYST_LIB is not set
# CONFIG_TINYCBOR is not set
# CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
# Unavailable modules, please install those via the project manifest.
# Nanopb module not available.
# end of Modules
CONFIG_BOARD_DECAWAVE_DWM1001_DEV=y
# Board Options
CONFIG_BOARD_ENABLE_DCDC=y
CONFIG_BT_DEVICE_NAME="UWBBordaBadge"
# end of Board Options
# CONFIG_SOC_SERIES_BEETLE is not set
# CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
# CONFIG_SOC_SERIES_MPS2 is not set
# CONFIG_SOC_SERIES_MPS3 is not set
# CONFIG_SOC_SERIES_MUSCA_B1 is not set
# CONFIG_SOC_SERIES_MUSCA_S1 is not set
# CONFIG_SOC_SERIES_SAMD20 is not set
# CONFIG_SOC_SERIES_SAMD21 is not set
# CONFIG_SOC_SERIES_SAMD51 is not set
# CONFIG_SOC_SERIES_SAME51 is not set
# CONFIG_SOC_SERIES_SAME53 is not set
# CONFIG_SOC_SERIES_SAME54 is not set
# CONFIG_SOC_SERIES_SAMR21 is not set
# CONFIG_SOC_SERIES_SAM3X is not set
# CONFIG_SOC_SERIES_SAM4E is not set
# CONFIG_SOC_SERIES_SAM4L is not set
# CONFIG_SOC_SERIES_SAM4S is not set
# CONFIG_SOC_SERIES_SAME70 is not set
# CONFIG_SOC_SERIES_SAMV71 is not set
# CONFIG_SOC_SERIES_VALKYRIE is not set
# CONFIG_SOC_SERIES_VIPER is not set
# CONFIG_SOC_SERIES_PSOC62 is not set
# CONFIG_SOC_SERIES_PSOC63 is not set
# CONFIG_SOC_SERIES_XMC_4XXX is not set
# CONFIG_SOC_SERIES_MEC1501X is not set
# CONFIG_SOC_SERIES_MEC1701X is not set
# CONFIG_SOC_SERIES_NRF51X is not set
CONFIG_SOC_SERIES_NRF52X=y
# CONFIG_SOC_SERIES_NRF53X is not set
# CONFIG_SOC_SERIES_NRF91X is not set
# CONFIG_SOC_SERIES_M48X is not set
# CONFIG_SOC_SERIES_NPCX7 is not set
# CONFIG_SOC_SERIES_IMX_6X_M4 is not set
# CONFIG_SOC_SERIES_IMX7_M4 is not set
# CONFIG_SOC_SERIES_IMX8MM_M4 is not set
# CONFIG_SOC_SERIES_IMX_RT6XX is not set
# CONFIG_SOC_SERIES_IMX_RT is not set
# CONFIG_SOC_SERIES_KINETIS_K2X is not set
# CONFIG_SOC_SERIES_KINETIS_K6X is not set
# CONFIG_SOC_SERIES_KINETIS_K8X is not set
# CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
# CONFIG_SOC_SERIES_KINETIS_KL2X is not set
# CONFIG_SOC_SERIES_KINETIS_KV5X is not set
# CONFIG_SOC_SERIES_KINETIS_KWX is not set
# CONFIG_SOC_SERIES_LPC11U6X is not set
# CONFIG_SOC_SERIES_LPC54XXX is not set
# CONFIG_SOC_SERIES_LPC55XXX is not set
# CONFIG_SOC_EOS_S3 is not set
# CONFIG_SOC_SERIES_RCAR_GEN3 is not set
# CONFIG_SOC_SERIES_EFM32GG11B is not set
# CONFIG_SOC_SERIES_EFM32HG is not set
# CONFIG_SOC_SERIES_EFM32JG12B is not set
# CONFIG_SOC_SERIES_EFM32PG12B is not set
# CONFIG_SOC_SERIES_EFM32PG1B is not set
# CONFIG_SOC_SERIES_EFM32WG is not set
# CONFIG_SOC_SERIES_EFR32BG13P is not set
# CONFIG_SOC_SERIES_EFR32FG13P is not set
# CONFIG_SOC_SERIES_EFR32FG1P is not set
# CONFIG_SOC_SERIES_EFR32MG12P is not set
# CONFIG_SOC_SERIES_EFR32MG21 is not set
# CONFIG_SOC_SERIES_STM32F0X is not set
# CONFIG_SOC_SERIES_STM32F1X is not set
# CONFIG_SOC_SERIES_STM32F2X is not set
# CONFIG_SOC_SERIES_STM32F3X is not set
# CONFIG_SOC_SERIES_STM32F4X is not set
# CONFIG_SOC_SERIES_STM32F7X is not set
# CONFIG_SOC_SERIES_STM32G0X is not set
# CONFIG_SOC_SERIES_STM32G4X is not set
# CONFIG_SOC_SERIES_STM32H7X is not set
# CONFIG_SOC_SERIES_STM32L0X is not set
# CONFIG_SOC_SERIES_STM32L1X is not set
# CONFIG_SOC_SERIES_STM32L4X is not set
# CONFIG_SOC_SERIES_STM32L5X is not set
# CONFIG_SOC_SERIES_STM32MP1X is not set
# CONFIG_SOC_SERIES_STM32WBX is not set
# CONFIG_SOC_SERIES_STM32WLX is not set
# CONFIG_SOC_TI_LM3S6965 is not set
# CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
# CONFIG_SOC_SERIES_CC32XX is not set
# CONFIG_SOC_SERIES_MSP432P4XX is not set
# CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
# Hardware Configuration
CONFIG_CPU_HAS_ARM_MPU=y
CONFIG_HAS_SWO=y
CONFIG_SOC_FAMILY="nordic_nrf"
CONFIG_SOC_FAMILY_NRF=y
CONFIG_HAS_HW_NRF_BPROT=y
CONFIG_HAS_HW_NRF_CCM=y
CONFIG_HAS_HW_NRF_CCM_LFLEN_8BIT=y
CONFIG_HAS_HW_NRF_CLOCK=y
CONFIG_HAS_HW_NRF_COMP=y
CONFIG_HAS_HW_NRF_ECB=y
CONFIG_HAS_HW_NRF_EGU0=y
CONFIG_HAS_HW_NRF_EGU1=y
CONFIG_HAS_HW_NRF_EGU2=y
CONFIG_HAS_HW_NRF_EGU3=y
CONFIG_HAS_HW_NRF_EGU4=y
CONFIG_HAS_HW_NRF_EGU5=y
CONFIG_HAS_HW_NRF_GPIO0=y
CONFIG_HAS_HW_NRF_GPIOTE=y
CONFIG_HAS_HW_NRF_I2S=y
CONFIG_HAS_HW_NRF_LPCOMP=y
CONFIG_HAS_HW_NRF_MWU=y
CONFIG_HAS_HW_NRF_NFCT=y
CONFIG_HAS_HW_NRF_PDM=y
CONFIG_HAS_HW_NRF_POWER=y
CONFIG_HAS_HW_NRF_PPI=y
CONFIG_HAS_HW_NRF_PWM0=y
CONFIG_HAS_HW_NRF_PWM1=y
CONFIG_HAS_HW_NRF_PWM2=y
CONFIG_HAS_HW_NRF_QDEC=y
CONFIG_HAS_HW_NRF_RADIO_BLE_2M=y
CONFIG_HAS_HW_NRF_RNG=y
CONFIG_HAS_HW_NRF_RTC0=y
CONFIG_HAS_HW_NRF_RTC1=y
CONFIG_HAS_HW_NRF_RTC2=y
CONFIG_HAS_HW_NRF_SAADC=y
CONFIG_HAS_HW_NRF_SPI0=y
CONFIG_HAS_HW_NRF_SPI1=y
CONFIG_HAS_HW_NRF_SPI2=y
CONFIG_HAS_HW_NRF_SPIM0=y
CONFIG_HAS_HW_NRF_SPIM1=y
CONFIG_HAS_HW_NRF_SPIM2=y
CONFIG_HAS_HW_NRF_SPIS0=y
CONFIG_HAS_HW_NRF_SPIS1=y
CONFIG_HAS_HW_NRF_SPIS2=y
CONFIG_HAS_HW_NRF_SWI0=y
CONFIG_HAS_HW_NRF_SWI1=y
CONFIG_HAS_HW_NRF_SWI2=y
CONFIG_HAS_HW_NRF_SWI3=y
CONFIG_HAS_HW_NRF_SWI4=y
CONFIG_HAS_HW_NRF_SWI5=y
CONFIG_HAS_HW_NRF_TEMP=y
CONFIG_HAS_HW_NRF_TIMER0=y
CONFIG_HAS_HW_NRF_TIMER1=y
CONFIG_HAS_HW_NRF_TIMER2=y
CONFIG_HAS_HW_NRF_TIMER3=y
CONFIG_HAS_HW_NRF_TIMER4=y
CONFIG_HAS_HW_NRF_TWI0=y
CONFIG_HAS_HW_NRF_TWI1=y
CONFIG_HAS_HW_NRF_TWIM0=y
CONFIG_HAS_HW_NRF_TWIM1=y
CONFIG_HAS_HW_NRF_TWIS0=y
CONFIG_HAS_HW_NRF_TWIS1=y
CONFIG_HAS_HW_NRF_UART0=y
CONFIG_HAS_HW_NRF_UARTE0=y
CONFIG_HAS_HW_NRF_WDT=y
CONFIG_NRF_HW_RTC1_RESERVED=y
CONFIG_SOC_NRF52832=y
# CONFIG_SOC_NRF52805_CAAA is not set
# CONFIG_SOC_NRF52810_QFAA is not set
# CONFIG_SOC_NRF52811_QFAA is not set
# CONFIG_SOC_NRF52820_QDAA is not set
# CONFIG_SOC_NRF52832_CIAA is not set
CONFIG_SOC_NRF52832_QFAA=y
# CONFIG_SOC_NRF52832_QFAB is not set
# CONFIG_SOC_NRF52833_QIAA is not set
# CONFIG_SOC_NRF52840_QIAA is not set
CONFIG_SOC_DCDC_NRF52X=y
CONFIG_GPIO_AS_PINRESET=y
CONFIG_NRF_ENABLE_ICACHE=y
CONFIG_NRF52_ANOMALY_132_DELAY_US=330
# CONFIG_NFCT_PINS_AS_GPIOS is not set
# end of Hardware Configuration
CONFIG_SOC_COMPATIBLE_NRF=y
CONFIG_SOC_COMPATIBLE_NRF52X=y
CONFIG_SOC_COMPATIBLE_NRF52832=y
# ARM Options
CONFIG_ARCH="arm"
CONFIG_CPU_CORTEX=y
# CONFIG_CODE_DATA_RELOCATION is not set
# CONFIG_CODE_DATA_RELOCATION_SRAM is not set
CONFIG_CPU_CORTEX_M=y
CONFIG_ISA_THUMB2=y
CONFIG_ASSEMBLER_ISA_THUMB2=y
CONFIG_COMPILER_ISA_THUMB2=y
CONFIG_STACK_ALIGN_DOUBLE_WORD=y
# CONFIG_RUNTIME_NMI is not set
CONFIG_PLATFORM_SPECIFIC_INIT=y
CONFIG_FAULT_DUMP=2
CONFIG_CPU_CORTEX_M4=y
CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
CONFIG_CPU_CORTEX_M_HAS_DWT=y
CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
CONFIG_CPU_CORTEX_M_HAS_VTOR=y
CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
CONFIG_ARMV7_M_ARMV8_M_FP=y
# ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_GEN_ISR_TABLES=y
# CONFIG_ZERO_LATENCY_IRQS is not set
# CONFIG_SW_VECTOR_RELAY is not set
# CONFIG_CORTEX_M_DWT is not set
CONFIG_TEST_EXTRA_STACKSIZE=0
# end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
CONFIG_CORTEX_M_DEBUG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
# CONFIG_CORTEX_M_DEBUG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
# CONFIG_CORTEX_M_DEBUG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
CONFIG_GEN_IRQ_VECTOR_TABLE=y
CONFIG_ARM_MPU=y
CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
# CONFIG_MPU_STACK_GUARD is not set
# CONFIG_MPU_ALLOW_FLASH_WRITE is not set
# CONFIG_CUSTOM_SECTION_ALIGN is not set
CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
# end of ARM Options
CONFIG_ARM=y
CONFIG_ARCH_IS_SET=y
# General Architecture Options
# CONFIG_HW_STACK_PROTECTION is not set
# CONFIG_USERSPACE is not set
CONFIG_KOBJECT_TEXT_AREA=256
CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
CONFIG_GEN_PRIV_STACKS=y
# CONFIG_STACK_GROWS_UP is not set
# Interrupt Configuration
# CONFIG_DYNAMIC_INTERRUPTS is not set
CONFIG_GEN_SW_ISR_TABLE=y
CONFIG_ARCH_SW_ISR_TABLE_ALIGN=0
CONFIG_GEN_IRQ_START_VECTOR=0
# CONFIG_EXTRA_EXCEPTION_INFO is not set
# end of Interrupt Configuration
# end of General Architecture Options
CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
CONFIG_ARCH_HAS_STACK_PROTECTION=y
CONFIG_ARCH_HAS_USERSPACE=y
CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
CONFIG_ARCH_SUPPORTS_COREDUMP=y
CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
CONFIG_ARCH_HAS_THREAD_ABORT=y
CONFIG_CPU_HAS_FPU=y
CONFIG_CPU_HAS_MPU=y
CONFIG_MPU=y
CONFIG_MPU_REQUIRES_POWER_OF_TWO_ALIGNMENT=y
CONFIG_SRAM_REGION_PERMISSIONS=y
# Floating Point Options
# end of Floating Point Options
# Cache Options
# CONFIG_CACHE_MANAGEMENT is not set
# end of Cache Options
CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
# General Kernel Options
CONFIG_MULTITHREADING=y
CONFIG_NUM_COOP_PRIORITIES=16
CONFIG_NUM_PREEMPT_PRIORITIES=15
CONFIG_MAIN_THREAD_PRIORITY=0
CONFIG_COOP_ENABLED=y
CONFIG_PREEMPT_ENABLED=y
CONFIG_PRIORITY_CEILING=0
CONFIG_NUM_METAIRQ_PRIORITIES=0
# CONFIG_SCHED_DEADLINE is not set
# CONFIG_SCHED_CPU_MASK is not set
CONFIG_IDLE_STACK_SIZE=320
CONFIG_ISR_STACK_SIZE=2048
CONFIG_THREAD_STACK_INFO=y
# CONFIG_THREAD_CUSTOM_DATA is not set
CONFIG_ERRNO=y
CONFIG_SCHED_DUMB=y
# CONFIG_SCHED_SCALABLE is not set
# CONFIG_SCHED_MULTIQ is not set
# CONFIG_WAITQ_SCALABLE is not set
CONFIG_WAITQ_DUMB=y
# Kernel Debugging and Metrics
# CONFIG_INIT_STACKS is not set
CONFIG_BOOT_DELAY=0
# CONFIG_THREAD_MONITOR is not set
# CONFIG_THREAD_NAME is not set
# CONFIG_THREAD_RUNTIME_STATS is not set
# end of Kernel Debugging and Metrics
# Work Queue Options
CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
# CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
# end of Work Queue Options
# Atomic Operations
CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
# end of Atomic Operations
# Timer API Options
CONFIG_TIMESLICING=y
CONFIG_TIMESLICE_SIZE=0
CONFIG_TIMESLICE_PRIORITY=0
# CONFIG_POLL is not set
# end of Timer API Options
# Other Kernel Object Options
# CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
CONFIG_NUM_MBOX_ASYNC_MSGS=10
CONFIG_NUM_PIPE_ASYNC_MSGS=10
CONFIG_KERNEL_MEM_POOL=y
# end of Other Kernel Object Options
CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
CONFIG_SWAP_NONATOMIC=y
CONFIG_SYS_CLOCK_EXISTS=y
CONFIG_TIMEOUT_64BIT=y
CONFIG_XIP=y
# Initialization Priorities
CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
CONFIG_APPLICATION_INIT_PRIORITY=90
# end of Initialization Priorities
# Security Options
# CONFIG_STACK_CANARIES is not set
CONFIG_STACK_POINTER_RANDOM=0
# end of Security Options
# SMP Options
CONFIG_MP_NUM_CPUS=1
# end of SMP Options
CONFIG_TICKLESS_KERNEL=y
# end of General Kernel Options
CONFIG_HAS_DTS=y
CONFIG_HAS_DTS_GPIO=y
# Device Drivers
# CONFIG_IEEE802154 is not set
# CONFIG_LORA is not set
# CONFIG_CONSOLE is not set
CONFIG_HAS_SEGGER_RTT=y
CONFIG_USE_SEGGER_RTT=y
# CONFIG_SEGGER_RTT_CUSTOM_LOCKING is not set
CONFIG_SEGGER_RTT_MAX_NUM_UP_BUFFERS=3
CONFIG_SEGGER_RTT_MAX_NUM_DOWN_BUFFERS=3
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=1024
CONFIG_SEGGER_RTT_BUFFER_SIZE_DOWN=16
CONFIG_SEGGER_RTT_PRINTF_BUFFER_SIZE=64
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# CONFIG_SEGGER_RTT_MODE_NO_BLOCK_TRIM is not set
# CONFIG_SEGGER_RTT_MODE_BLOCK_IF_FIFO_FULL is not set
CONFIG_SEGGER_RTT_MODE=0
# CONFIG_SEGGER_RTT_MEMCPY_USE_BYTELOOP is not set
CONFIG_SEGGER_RTT_SECTION_NONE=y
# CONFIG_SEGGER_RTT_SECTION_DTCM is not set
# CONFIG_EC_HOST_CMD_PERIPH is not set
# CONFIG_NET_LOOPBACK is not set
# Interrupt Controllers
# CONFIG_SWERV_PIC is not set
# CONFIG_MULTI_LEVEL_INTERRUPTS is not set
# end of Interrupt Controllers
# Timer Drivers
CONFIG_APIC_TIMER_IRQ_PRIORITY=4
CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=0
# CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
# CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
CONFIG_SYSTEM_CLOCK_DISABLE=y
# CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
# CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
CONFIG_TICKLESS_CAPABLE=y
# end of Timer Drivers
CONFIG_ENTROPY_NRF5_RNG=y
# CONFIG_ENTROPY_NRF5_BIAS_CORRECTION is not set
CONFIG_ENTROPY_NRF5_THR_POOL_SIZE=8
CONFIG_ENTROPY_NRF5_THR_THRESHOLD=4
CONFIG_ENTROPY_NRF5_ISR_POOL_SIZE=16
CONFIG_ENTROPY_NRF5_ISR_THRESHOLD=12
CONFIG_ENTROPY_HAS_DRIVER=y
# CONFIG_PCIE is not set
# CONFIG_PCIE_ENDPOINT is not set
# CONFIG_GPIO_DW is not set
CONFIG_GPIO_NRFX=y
CONFIG_GPIO_NRF_INIT_PRIORITY=40
CONFIG_GPIO_NRF_P0=y
CONFIG_GPIO_NRF_INT_EDGE_USING_GPIOTE=y
# CONFIG_GPIO_NRF_INT_EDGE_USING_SENSE is not set
# CONFIG_GPIO_ITE_IT8XXX2 is not set
# CONFIG_GPIO_INTEL is not set
# CONFIG_GPIO_XLNX_AXI is not set
# CONFIG_GPIO_EMUL is not set
# CONFIG_SHARED_IRQ is not set
# CONFIG_I2S is not set
# CONFIG_PWM is not set
# CONFIG_PINMUX is not set
# CONFIG_ADC is not set
# CONFIG_DAC is not set
CONFIG_CLOCK_CONTROL_NRF=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_LOW_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_EXT_FULL_SWING is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
# CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
# CONFIG_PTP_CLOCK is not set
# CONFIG_IPM is not set
# CONFIG_FLASH is not set
# CONFIG_COUNTER is not set
# CONFIG_DMA is not set
# CONFIG_USB is not set
CONFIG_CRYPTO=y
CONFIG_CRYPTO_INIT_PRIORITY=90
# CONFIG_CRYPTO_TINYCRYPT_SHIM is not set
CONFIG_CRYPTO_MBEDTLS_SHIM=y
CONFIG_CRYPTO_MBEDTLS_SHIM_DRV_NAME="CRYPTO_MTLS"
CONFIG_CRYPTO_MBEDTLS_SHIM_MAX_SESSION=2
# CONFIG_CRYPTO_NRF_ECB is not set
# CONFIG_DISPLAY is not set
# CONFIG_LED_STRIP is not set
# CONFIG_LED is not set
# CONFIG_CAN is not set
# CONFIG_AUDIO is not set
# CONFIG_NEURAL_NET_ACCEL is not set
# CONFIG_HWINFO is not set
# CONFIG_ESPI is not set
# CONFIG_PS2 is not set
# CONFIG_VIDEO is not set
# CONFIG_EEPROM is not set
# CONFIG_PECI is not set
# CONFIG_PECI_INTERRUPT_DRIVEN is not set
# CONFIG_REGULATOR is not set
# CONFIG_MEMC is not set
# CONFIG_VIRTUALIZATION is not set
# CONFIG_EDAC is not set
# CONFIG_PM_CPU_OPS is not set
# Miscellaneous Drivers
# end of Miscellaneous Drivers
# CONFIG_DISK_DRIVERS is not set
# CONFIG_CACHE is not set
# C Library
CONFIG_MINIMAL_LIBC=y
# CONFIG_NEWLIB_LIBC is not set
# CONFIG_EXTERNAL_LIBC is not set
CONFIG_HAS_NEWLIB_LIBC_NANO=y
CONFIG_MINIMAL_LIBC_MALLOC=y
CONFIG_MINIMAL_LIBC_MALLOC_ARENA_SIZE=0
CONFIG_MINIMAL_LIBC_CALLOC=y
CONFIG_MINIMAL_LIBC_REALLOCARRAY=y
# CONFIG_MINIMAL_LIBC_LL_PRINTF is not set
# end of C Library
# Additional libraries
# CONFIG_LVGL is not set
# OS Support Library
# CONFIG_JSON_LIBRARY is not set
# CONFIG_RING_BUFFER is not set
# CONFIG_BASE64 is not set
# CONFIG_SYS_HEAP_VALIDATE is not set
CONFIG_SYS_HEAP_ALLOC_LOOPS=3
# CONFIG_PRINTK64 is not set
# CONFIG_PRINTK_SYNC is not set
# CONFIG_MPSC_PBUF is not set
CONFIG_REBOOT=y
CONFIG_CBPRINTF_COMPLETE=y
# CONFIG_CBPRINTF_NANO is not set
CONFIG_CBPRINTF_FULL_INTEGRAL=y
# CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
# CONFIG_CBPRINTF_FP_SUPPORT is not set
# CONFIG_CBPRINTF_FP_A_SUPPORT is not set
# CONFIG_CBPRINTF_FP_ALWAYS_A is not set
CONFIG_CBPRINTF_N_SPECIFIER=y
# CONFIG_CBPRINTF_LIBC_SUBSTS is not set
# CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
# CONFIG_CBPRINTF_STATIC_PACKAGE_CHECK_ALIGNMENT is not set
# end of OS Support Library
CONFIG_POSIX_MAX_FDS=4
# CONFIG_POSIX_API is not set
# CONFIG_PTHREAD_IPC is not set
# CONFIG_POSIX_CLOCK is not set
CONFIG_MAX_TIMER_COUNT=5
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_EVENTFD is not set
# CONFIG_OPENAMP_RSC_TABLE is not set
# Util libraries
# CONFIG_FNMATCH is not set
# CONFIG_GETOPT is not set
# end of Util libraries
# end of Additional libraries
# Sub Systems and OS Services
# CONFIG_BT is not set
# Controller Area Network (CAN) bus subsystem
# CONFIG_ISOTP is not set
# end of Controller Area Network (CAN) bus subsystem
# CONFIG_CONSOLE_SUBSYS is not set
# CONFIG_CPLUSPLUS is not set
# System Monitoring Options
# CONFIG_THREAD_ANALYZER is not set
# end of System Monitoring Options
# Debugging Options
# CONFIG_DEBUG is not set
# CONFIG_STACK_USAGE is not set
# CONFIG_STACK_SENTINEL is not set
CONFIG_PRINTK=y
# CONFIG_EARLY_CONSOLE is not set
# CONFIG_ASSERT is not set
# CONFIG_FORCE_NO_ASSERT is not set
CONFIG_ASSERT_VERBOSE=y
# CONFIG_ASSERT_NO_FILE_INFO is not set
# CONFIG_ASSERT_NO_COND_INFO is not set
# CONFIG_ASSERT_NO_MSG_INFO is not set
# CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_OPENOCD_SUPPORT is not set
# CONFIG_DEBUG_THREAD_INFO is not set
# CONFIG_DEBUG_COREDUMP is not set
# end of Debugging Options
# CONFIG_DISK_ACCESS is not set
# CONFIG_EMUL is not set
# CONFIG_CHARACTER_FRAMEBUFFER is not set
# File Systems
# CONFIG_FILE_SYSTEM is not set
# CONFIG_NVS is not set
# end of File Systems
# Inter Processor Communication
# CONFIG_RPMSG_SERVICE is not set
# end of Inter Processor Communication
# CONFIG_JWT is not set
# CONFIG_LOG is not set
# Device Management
# Host command handler subsystem
# CONFIG_EC_HOST_CMD is not set
# end of Host command handler subsystem
# CONFIG_MCUMGR is not set
# CONFIG_HAWKBIT is not set
# CONFIG_UPDATEHUB is not set
# CONFIG_OSDP is not set
# end of Device Management
# CONFIG_MODBUS is not set
# Networking
# CONFIG_NET_BUF is not set
# CONFIG_NETWORKING is not set
# end of Networking
# Portability
# end of Portability
# Power Management
# CONFIG_SYS_POWER_MANAGEMENT is not set
# CONFIG_PM_DEBUG is not set
CONFIG_PM_POLICY_RESIDENCY=y
# CONFIG_PM_POLICY_DUMMY is not set
# CONFIG_PM_POLICY_APP is not set
CONFIG_PM_POLICY_RESIDENCY_DEFAULT=y
# CONFIG_DEVICE_POWER_MANAGEMENT is not set
# end of Power Management
# CONFIG_SHELL is not set
# CONFIG_STATS is not set
# CONFIG_IMG_MANAGER is not set
# Random Number Generators
CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
# CONFIG_XOROSHIRO_RANDOM_GENERATOR is not set
CONFIG_CSPRING_ENABLED=y
# CONFIG_HARDWARE_DEVICE_CS_GENERATOR is not set
CONFIG_CTR_DRBG_CSPRNG_GENERATOR=y
CONFIG_CS_CTR_DRBG_PERSONALIZATION="zephyr ctr-drbg seed"
# end of Random Number Generators
# Storage
# CONFIG_STREAM_FLASH is not set
# end of Storage
# CONFIG_SETTINGS is not set
# CONFIG_TASK_WDT is not set
# Testing
# CONFIG_ZTEST is not set
# CONFIG_ZTEST_MOCKING is not set
# CONFIG_TEST is not set
# CONFIG_TEST_USERSPACE is not set
# end of Testing
# CONFIG_TIMING_FUNCTIONS is not set
# CONFIG_TRACING is not set
# end of Sub Systems and OS Services
CONFIG_TOOLCHAIN_GNUARMEMB=y
# Build and Link Features
# Linker Options
# CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
CONFIG_LINKER_ORPHAN_SECTION_WARN=y
# CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
CONFIG_HAS_FLASH_LOAD_OFFSET=y
# CONFIG_USE_DT_CODE_PARTITION is not set
CONFIG_FLASH_LOAD_OFFSET=0
CONFIG_FLASH_LOAD_SIZE=0
# CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
CONFIG_KERNEL_ENTRY="__start"
CONFIG_LINKER_SORT_BY_ALIGNMENT=y
CONFIG_SRAM_OFFSET=0
# end of Linker Options
# Compiler Options
# CONFIG_CODING_GUIDELINE_CHECK is not set
# CONFIG_NATIVE_APPLICATION is not set
CONFIG_SIZE_OPTIMIZATIONS=y
# CONFIG_SPEED_OPTIMIZATIONS is not set
# CONFIG_DEBUG_OPTIMIZATIONS is not set
# CONFIG_NO_OPTIMIZATIONS is not set
CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
CONFIG_COMPILER_OPT=""
# end of Compiler Options
# CONFIG_ASSERT_ON_ERRORS is not set
# CONFIG_NO_RUNTIME_CHECKS is not set
CONFIG_RUNTIME_ERROR_CHECKS=y
# Build Options
CONFIG_KERNEL_BIN_NAME="zephyr"
CONFIG_OUTPUT_STAT=y
CONFIG_OUTPUT_DISASSEMBLY=y
# CONFIG_OUTPUT_DISASSEMBLE_ALL is not set
CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
# CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
# CONFIG_BUILD_NO_GAP_FILL is not set
CONFIG_BUILD_OUTPUT_BIN=y
# CONFIG_BUILD_OUTPUT_EXE is not set
# CONFIG_BUILD_OUTPUT_S19 is not set
# CONFIG_BUILD_OUTPUT_UF2 is not set
# CONFIG_BUILD_OUTPUT_STRIPPED is not set
# CONFIG_APPLICATION_DEFINED_SYSCALL is not set
# CONFIG_MAKEFILE_EXPORTS is not set
# end of Build Options
# end of Build and Link Features
# Boot Options
# CONFIG_IS_BOOTLOADER is not set
# CONFIG_BOOTLOADER_MCUBOOT is not set
# CONFIG_MISRA_SANE is not set
# end of Boot Options
# Compatibility
CONFIG_COMPAT_INCLUDES=y
# end of Compatibility
