Fanstel BT832X evaluation board with softdevice does not run
I have a Fanstel BT832X evaluation board (model EV-BT840(832)-V4). Nordic examples without softdevice are working fine. Examples with softdevice are not working. I have checked my evaluation board and made sure the SW5 switch is ON (32kHz clock is enabled). I even tried changing the `sdk_config.h` to use internal RC, but both are not working. I tried changing the clock PPM to 250, 500, none are working.
I programmed the softdevice first by running `make flash_softdevice`, then programmed the application by running `make flash`.
What I am doing wrong? Any help would be appreciated.
