adding an "array" attribute
Hello!
I add an attribute array (0x48) for the user cluster.
Having problems using the "array" attribute:
1. If you select the data type of 16 or 32 bits, then an alignment is added in the transmission, since the frame structure is: 8 bits for the type of array variables, then 16 bits for the length. Alignment is added after the 8 bit field for the variable type.
I use an array of 8-bit variables in the declaration, then a pointer to the desired structure and this is not a problem.
2. For some reason, 32 bytes are always transferred, regardless of the size of the specified array. Is this hardcoded or is it possible to specify the size?
#ifndef ZB_ZCL_ANALOG_SIGNAL_H__
#define ZB_ZCL_ANALOG_SIGNAL_H__
#include "zcl/zb_zcl_common.h"
/* Cluster ZB_ZCL_CLUSTER_ID_ANALOG_VALUE */
#define   ANALOG_NUMBER_OF_ARRAY_ELEMENTS     18
#define   ANALOG_DATA_TYPE                    ZB_ZCL_ATTR_TYPE_U8
typedef struct  struct_analog_data
    zb_uint8_t  Element_Type;
    zb_uint8_t  Number_Of_Elements1;
    zb_uint8_t  Number_Of_Elements2;
    zb_uint8_t  allign;
    zb_int16_t  Analog_Signal_Array[ANALOG_NUMBER_OF_ARRAY_ELEMENTS];
} analog_data_t;
enum analog_array_element_t
   ANALOG_T1 = 0,
   ANALOG_T2,
   ANALOG_T3,
   ANALOG_T4,
   ANALOG_T5,
   ANALOG_T6,
   ANALOG_T7,
   ANALOG_T8,
   ANALOG_T9,
   ANALOG_T10,
   ANALOG_T11,
   ANALOG_T12,
   ANALOG_T13,
   ANALOG_T14,
   ANALOG_T15,
   ANALOG_T16,
   ANALOG_DI,
   ANALOG_DO,
typedef struct
    zb_bool_t       OutOfService;
    float           PresentValue;
    zb_uint8_t      StatusFlags;
    analog_data_t   AnalogData;
} zb_zcl_analog_attrs_t;
enum zb_zcl_analog_measurement_attr_e
    ZB_ZCL_ATTR_ANALOG_SERVICE_ID = 0x0051,
    ZB_ZCL_ATTR_ANALOG_VALUE_ID   = 0x0055,
    ZB_ZCL_ATTR_ANALOG_STATUS_ID  = 0x006F,
    ZB_ZCL_ATTR_ANALOG_ARRAY_ID   = 0x0080,
/**@brief MeasuredValue attribute unknown value. */
#define ZB_ZCL_ATTR_ANALOG_VALUE_UNKNOWN                  ((zb_int16_t)0x8000)
/**@brief MinMeasuredValue attribute minimum value. */
#define ZB_ZCL_ATTR_ANALOG_MIN_VALUE_MIN_VALUE            ((zb_int16_t)0x8001)
/**@brief MinMeasuredValue attribute maximum value. */
#define ZB_ZCL_ATTR_ANALOG_MIN_VALUE_MAX_VALUE            0x7FFE
/**@brief MinMeasuredValue attribute invalid value. */
#define ZB_ZCL_ATTR_ANALOG_MIN_VALUE_INVALID              ((zb_int16_t)0x8000)
/**@brief MaxMeasuredValue attribute minimum value. */
#define ZB_ZCL_ATTR_ANALOG_MAX_VALUE_MIN_VALUE            ((zb_int16_t)0x8002)
/**@brief MaxMeasuredValue attribute maximum value. */
#define ZB_ZCL_ATTR_ANALOG_MAX_VALUE_MAX_VALUE            0x7FFF
/**@brief MaxMeasuredValue attribute invalid value. */
#define ZB_ZCL_ATTR_ANALOG_MAX_VALUE_INVALID              ((zb_int16_t)0x8000)
#define ZB_ZCL_ATTR_ANALOG_DEFAULT_STATUS_FLAG            ((zb_uint8_t)0x00)
/**@brief Default value for Value attribute. */
#define ZB_ZCL_ANALOG_VALUE_DEFAULT_VALUE ((zb_int16_t)0x0)
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_ANALOG_VALUE_ID(data_ptr)              \
    ZB_ZCL_ATTR_ANALOG_VALUE_ID,                                                  \
    ZB_ZCL_ATTR_TYPE_SINGLE,                                                      \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_WRITE_OPTIONAL,             \
    (zb_voidp_t) data_ptr                                                         \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_ANALOG_SERVICE_ID(data_ptr)             \
    ZB_ZCL_ATTR_ANALOG_SERVICE_ID,                                                 \
    ZB_ZCL_ATTR_TYPE_BOOL,                                                         \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_ANALOG_STATUS_ID(data_ptr)              \
    ZB_ZCL_ATTR_ANALOG_STATUS_ID,                                                  \
    ZB_ZCL_ATTR_TYPE_8BITMAP,                                                      \
    ZB_ZCL_ATTR_ACCESS_READ_ONLY,                                                  \
#define ZB_SET_ATTR_DESCR_WITH_ZB_ZCL_ATTR_ANALOG_ARRAY_ID(data_ptr)               \
    ZB_ZCL_ATTR_ANALOG_ARRAY_ID,                                                   \
    ZB_ZCL_ATTR_TYPE_ARRAY,                                                        \
/**@brief Declares attribute list for the cluster on the server side.
#define ZB_ZCL_DECLARE_ANALOG_ATTRIB_LIST(attr_list,                   \
    service, value, status, array)                                     \
  ZB_ZCL_START_DECLARE_ATTRIB_LIST(attr_list)                          \
  ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_ANALOG_SERVICE_ID, (service))       \
  ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_ANALOG_VALUE_ID, (value))           \
  ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_ANALOG_STATUS_ID, (status))         \
  ZB_ZCL_SET_ATTR_DESC(ZB_ZCL_ATTR_ANALOG_ARRAY_ID, (array))           \
  ZB_ZCL_FINISH_DECLARE_ATTRIB_LIST
/**@brief Function initialising the server side of Cluster. */
zb_void_t zb_zcl_analog_init_server(void);
/**@brief Function initialising the client side of Cluster. */
zb_void_t zb_zcl_analog_init_client(void);
/**@brief Defines needed for the stack to initialise the cluster correctly. */
#define ZB_ZCL_CLUSTER_ID_CUSTOM_ATTR_SERVER_ROLE_INIT zb_zcl_analog_init_server
#define ZB_ZCL_CLUSTER_ID_CUSTOM_ATTR_CLIENT_ROLE_INIT zb_zcl_analog_init_client
#endif /* ZB_ZCL_ANALOG_SIGNAL_H__ */
