BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST problem :
I am using CUSTOM service in nrf52 for BLE Communication.In the tutorial, there isn't any BLE READ event but I figured that BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event is generated when we send request to read the data from the device. But once that event is generated nrf52 hangs or something like that and it gets disconnected.
Can you tell me the possible reason behind that?
Thanks in advance.
     See this chart:
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.s132.api.v7.0.1%2Fgroup___b_l_e___g_a_t_t_s___r_e_a_d___r_e_q___a_u_t_h___m_s_c.html
    It could be that your application is not authorizing the read with sd_ble_gatts_rw_authorize_reply()
  • Here is my code:
    #include "sdk_common.h"
    #include "ble_cus.h"
    #include
    #include "ble_srv_common.h"
    #include "nrf_gpio.h"
    #include "boards.h"
    #include "nrf_log.h"
    /**@brief Function for handling the Connect event.
     * @param[in]   p_cus       Custom Service structure.
     * @param[in]   p_ble_evt   Event received from the BLE stack.
    static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
        ble_cus_evt_t evt;
        evt.evt_type = BLE_CUS_EVT_CONNECTED;
        p_cus->evt_handler(p_cus, &evt);
    /**@brief Function for handling the Disconnect event.
    static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        UNUSED_PARAMETER(p_ble_evt);
        p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
        ble_cus_evt_t evt;
        evt.evt_type = BLE_CUS_EVT_DISCONNECTED;
    /**@brief Function for handling the Write event.
    static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
        // Custom Value Characteristic Written to.
        if (p_evt_write->handle == p_cus->custom_value_handles.value_handle)
            nrf_gpio_pin_toggle(LED_4);
            if(*p_evt_write->data == 0x01)
                nrf_gpio_pin_clear(20);
            else if(*p_evt_write->data == 0x02)
                nrf_gpio_pin_set(20);
              //Do nothing
        // Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
        if ((p_evt_write->handle == p_cus->custom_value_handles.cccd_handle)
            && (p_evt_write->len == 2)
            // CCCD written, call application event handler
            if (p_cus->evt_handler != NULL)
                ble_cus_evt_t evt;
                if (ble_srv_is_notification_enabled(p_evt_write->data))
                    evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
                    evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
                // Call the application event handler.
    static void on_read(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
    void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
        ble_cus_t * p_cus = (ble_cus_t *) p_context;
        ble_gatts_rw_authorize_reply_params_t rdReply;
        uint16_t returnlength;
        ret_code_t res;
        static char array[]="hello";
        NRF_LOG_INFO("BLE event received. Event type = %d\r\n", p_ble_evt->header.evt_id);
        if (p_cus == NULL || p_ble_evt == NULL)
            return;
            case BLE_GAP_EVT_CONNECTED:
                on_connect(p_cus, p_ble_evt);
                on_disconnect(p_cus, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_cus, p_ble_evt);
     //Handling this event is not necessary
            case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
                NRF_LOG_INFO("EXCHANGE_MTU_REQUEST event received.\r\n");
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                rdReply.type = BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST;
                rdReply.params.read.offset = 0;
                rdReply.params.read.update = 0;
                returnlength = strlen(array);
                rdReply.params.read.len = returnlength;
                rdReply.params.read.p_data = array;
                NRF_LOG_INFO("READ REQUEST event received.\r\n");
                res= sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gap_evt.conn_handle,&rdReply);
                if(res==NRF_SUCCESS)
                    NRF_LOG_INFO("No error.\r\n");
                    NRF_LOG_INFO("Error. res =%d\r\n",res);
                on_read(p_cus, p_ble_evt);
                // No implementation needed.
    /**@brief Function for adding the Custom Value characteristic.
     * @param[in]   p_cus        Battery Service structure.
     * @param[in]   p_cus_init   Information needed to initialize the service.
     * @return      NRF_SUCCESS on success, otherwise an error code.
    static uint32_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        uint32_t            err_code;
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        // Add Custom Value characteristic
        memset(&cccd_md, 0, sizeof(cccd_md));
        //  Read  operation on cccd should be possible without authentication.
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
        cccd_md.write_perm = p_cus_init->custom_value_char_attr_md.cccd_write_perm;
        cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read   = 1;
        char_md.char_props.write  = 1;
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.type = p_cus->uuid_type;
        ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID;
        memset(&attr_md, 0, sizeof(attr_md));
        attr_md.read_perm  = p_cus_init->custom_value_char_attr_md.read_perm;
        attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 1;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 0;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid    = &ble_uuid;
        attr_char_value.p_attr_md = &attr_md;
        attr_char_value.init_len  = sizeof(uint8_t);
        attr_char_value.init_offs = 0;
        attr_char_value.max_len   = sizeof(uint8_t);
        err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
                                                   &attr_char_value,
                                                   &p_cus->custom_value_handles);
        if (err_code != NRF_SUCCESS)
            return err_code;
        return NRF_SUCCESS;
    uint32_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
        if (p_cus == NULL || p_cus_init == NULL)
            return NRF_ERROR_NULL;
        uint32_t   err_code;
        // Initialize service structure
        p_cus->evt_handler               = p_cus_init->evt_handler;
        // Add Custom Service UUID
        ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
        err_code =  sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.uuid = CUSTOM_SERVICE_UUID;
        // Add the Custom Service
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
            return err_code;
        return custom_value_char_add(p_cus, p_cus_init);
    uint32_t ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value)
        NRF_LOG_INFO("In ble_cus_custom_value_update. \r\n");
        if (p_cus == NULL)
        uint32_t err_code = NRF_SUCCESS;
        ble_gatts_value_t gatts_value;
        // Initialize value struct.
        memset(&gatts_value, 0, sizeof(gatts_value));
        gatts_value.len     = sizeof(uint8_t);
        gatts_value.offset  = 0;
        gatts_value.p_value = &custom_value;
        // Update database.
        err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
                                          p_cus->custom_value_handles.value_handle,
                                          &gatts_value);
            return err_code;
        // Send value if connected and notifying.
        if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
            ble_gatts_hvx_params_t hvx_params;
            memset(&hvx_params, 0, sizeof(hvx_params));
            hvx_params.handle = p_cus->custom_value_handles.value_handle;
            hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
            hvx_params.offset = gatts_value.offset;
            hvx_params.p_len  = &gatts_value.len;
            hvx_params.p_data = gatts_value.p_value;
            err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
            NRF_LOG_INFO("sd_ble_gatts_hvx result: %x. \r\n", err_code);
            err_code = NRF_ERROR_INVALID_STATE;
            NRF_LOG_INFO("sd_ble_gatts_hvx result: NRF_ERROR_INVALID_STATE. \r\n");
        return err_code;
    Can you tell me where am I going wrong?
    Thanks in advance.
  • Here is my code:
        uint32_t time = 0;
        ret_code_t err_code;
        ble_gatts_evt_rw_authorize_request_t  req = p_ble_evt->evt.gatts_evt.params.authorize_request;
        unsigned char data[5]="Hello";
        if(req.type == BLE_GATTS_AUTHORIZE_TYPE_READ){
            ble_gatts_rw_authorize_reply_params_t response;
            response.params.read.gatt_status = BLE_GATT_STATUS_SUCCESS;
            response.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
            response.params.read.update = 1;
            response.params.read.offset = 0;
            response.params.read.len =20;
            response.params.read.p_data = (uint8_t *)data;
            response.params.read.gatt_status = (BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2); // Feature not supported
            err_code=sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle, &response);
            NRF_LOG_INFO("Reply function responded with: %d", err_code);
    But could not get any value when read command is sent by mobile device. Please guide me.
    Thank you in advance.
  • Any reply Nordic?
    I am stuck at this point from last 2 weeks. Please guide me.
    Thanks in advance.
    Try this:
        uint32_t time = 0;
        unsigned char data[1]="H";
            response.params.read.len =1;
    PS: From your function custom_value_char_add(), you are setting max length to 1 byte:
    If it's still not working, then let me know if e.g. sd_ble_gatts_rw_authorize_reply() returned any error codes.
