during build time in keil arm software getting this as an error therefore not getting target completed
Hi
Are you trying to build one of the SDK example projects? What SDK version are you using?
ret_code_t is defined in the sdk_errors.h header file in the SDK. Please make sure that it is included in the following path: C:\...\YOUR_SDK_FOLDER\nRF5_SDK_17.0.2_d674dde\components\libraries\util\sdk_errors.h
Simon
yes ret_code_t is defined there as a name(datatype) of structure
And have you added it as part of your preprocessor definitions? Are you building one of the example projects in the SDK or have you made a project from scratch? We strongly suggest using one of the existing example projects as a template that should be compiling and building successfully from scratch.
Also, if you're using SDK 17.0.0, it is strongly recommended that you switch to SDK v17.0.2 instead, which is a bug fix release replacing v17.0.0.
Simon
