Hi, dear Nordic & all:
I found nrfx_saadc_uninit() did not work when use SAADC's differential mode with SDK17.0.2, nrf52832, the fellowing is saadc init and configuration code:
static nrfx_saadc_channel_t channels[SAADC_CHANNEL_TOTAL_COUNT] = {NRFX_SAADC_DEFAULT_CHANNEL_DIFFERENTIAL(NRF_SAADC_INPUT_AIN0, NRF_SAADC_INPUT_AIN1, 0),
NRFX_SAADC_DEFAULT_CHANNEL_DIFFERENTIAL(NRF_SAADC_INPUT_AIN2, NRF_SAADC_INPUT_AIN3, 1)};
void saadc_event_handler(nrfx_saadc_evt_t const * p_event)
float val = 180.0 / 3.14159265358979323846;
uint32_t err_code;
if (p_event->type == NRFX_SAADC_EVT_DONE)
//NRF_LOG_INFO("ADC Values: %6d %6d",p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1]);
data = -atan2(p_event->data.done.p_buffer[0], p_event->data.done.p_buffer[1])*val + 180;
//NRF_LOG_INFO("float data:"NRF_LOG_FLOAT_MARKER"\n",NRF_LOG_FLOAT(data));
if (data > prev_angle)
if (prev_angle > 270)
positive_direction_judge[2] = true;
else if (prev_angle > 180)
positive_direction_judge[1] = true;
else if (prev_angle > 90)
positive_direction_judge[0] = true;
if (prev_angle > 355.00 && positive_direction_judge[0] && positive_direction_judge[1] && positive_direction_judge[2])
m_angle.turns++;
memset(positive_direction_judge, false, 3);
memset(negative_direction_judge, false, 3);
prev_angle = 360;
if (data < prev_angle)
if (prev_angle < 90)
negative_direction_judge[2] = true;
else if (prev_angle < 180)
negative_direction_judge[1] = true;
else if (prev_angle < 270)
negative_direction_judge[0] = true;
if (prev_angle < 5.00 && negative_direction_judge[0] && negative_direction_judge[1] && negative_direction_judge[2])
m_angle.turns--;
prev_angle = 0;
m_angle.integer_part = (uint16_t)data;
m_angle.decimal_part = (data - m_angle.integer_part) * 100;
prev_angle = data;
//NRF_LOG_INFO("turns: %d, integer: %d, decimal: %d", m_angle.turns, m_angle.integer_part, m_angle.decimal_part);
if(is_frist_time){
x_initial_value = p_event->data.done.p_buffer[0];
y_initial_value = p_event->data.done.p_buffer[1];
x_amplitude_max = x_amplitude_min = x_initial_value;
y_amplitude_max = y_amplitude_min = y_initial_value;
is_frist_time = false;
}else
x_value = p_event->data.done.p_buffer[0];
y_value = p_event->data.done.p_buffer[1];
//ct310_data_send_schedule();
nrfx_saadc_uninit();
/* Applying workaround from Errata 212, otherwise current is stuck at 4-500uA during sleep after first sample. */
// volatile uint32_t temp1;
// volatile uint32_t temp2;
// volatile uint32_t temp3;
// temp1 = *(volatile uint32_t *)0x40007640ul;
// temp2 = *(volatile uint32_t *)0x40007644ul;
// temp3 = *(volatile uint32_t *)0x40007648ul;
// *(volatile uint32_t *)0x40007FFCul = 0ul;
// *(volatile uint32_t *)0x40007FFCul;
// *(volatile uint32_t *)0x40007FFCul = 1ul;
// *(volatile uint32_t *)0x40007640ul = temp1;
// *(volatile uint32_t *)0x40007644ul = temp2;
// *(volatile uint32_t *)0x40007648ul = temp3;
void saadc_configure_init_and_sample(void * p_event_data, uint16_t event_size)
uint32_t err_code;
err_code = nrfx_saadc_init(NRFX_SAADC_CONFIG_IRQ_PRIORITY);
err_code = nrfx_saadc_channels_config(channels, SAADC_CHANNEL_TOTAL_COUNT);
err_code = nrfx_saadc_simple_mode_set((1<<0|1<<1),
NRF_SAADC_RESOLUTION_12BIT,
NRF_SAADC_OVERSAMPLE_4X,
saadc_event_handler);
err_code = nrfx_saadc_buffer_set(samples, SAADC_CHANNEL_TOTAL_COUNT);
err_code = nrfx_saadc_mode_trigger();
and my main function is:
void stop_sample(void)
bool erase_bonds;
// Initialize.
// lfclk_config();
// rtc_config();
log_init();
scheduler_init();
user_times_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// NRF_LOG_INFO("Debug logging for UART over RTT started.");
advertising_start();
//user_times_start();
saadc_configure_init_and_sample(NULL, NULL);
// Enter main loop.
for (;;)
stop_sample();
app_sched_execute();
idle_state_handle();
I called just one time before for(;;), then I will call nrfx_saadc_uninit() in saadc_event_handler() to stop it , but It didn't work, So I call this in for(;;) all the time to make sure it is uninited, but It is still don't work, now the power consumption added 7mA, it‘s very high and abnormal!
So, Why nrfx_saadc_uninit() do not work?
Thanks for your kind suggestion and best regards.
