nRF9160 lowest power with RTC running
Hi
I try to run a nRF9160 on a nRF9160DK with lowest power possible.
A wake up from pin and periodically from RTC is required.
In the  nRF9160_PS_v2.0.pdf is IMCUON1 MCU on IDLE, modem off, RTC on 2.2 μA
When I run nrf_regulators_system_off(NRF_REGULATORS_NS);
Current is ok 2-3uA
Wake up with PIN works
Wake up from RTC does not work.
When I run __WFI();
Current is not ok 10-12uA
Wake up with PIN works.
How to setup nRF9160 for IMCUON1 MCU on IDLE, modem off, RTC on 2.2 μA
with wake up from PIN and RTC?
  • Wake up from RTC does not work.
    When I run __WFI();
    If you make a very simple main() that only use k_sleep(), then that uses the RTC in the background, so this should be power optimized. What current consumption do you measure then?
    I would think that the current consumption problem with "10-12uA" is that you have not configured wakeup on pin correct, you should configure to use "sense" wakeup from lowest power consumption, I suspect you have configured "in event" for wakeup from sleep. Using "in event" will have higher current consumption:
    https://infocenter.nordicsemi.com/topic/ps_nrf9160/gpiote.html
  • Hi Kenneth
    Now I've an working sample to wakeup from pin and rtc.
    the current consumption on the dk is 2-3uA.
    So every thing is OK
    Thanks.
    BTW.
    It would be helpful if there is a sample in nRF connect SDK for this situation.
