nRF52832 Bluetooth Keil configuration
Hi i just bough module E73-TBB(nRF52832) from EBYTE.
I've already downloaded the sdk this link
https://www.nordicsemi.com/Products/nRF52832/Download#infotabs
I test with ble_app_blinky (Keil uVision5 ), uploaded success work as normal.
but example Bluetooth Uart not working (no device found from my phone);
does module need special configuration for oscillator?
     Yes, in sdk_config.h, you need to configure it like this:
    // <h> Clock - SoftDevice clock configuration
    // <o> NRF_SDH_CLOCK_LF_SRC - SoftDevice clock source.
    // <0=> NRF_CLOCK_LF_SRC_RC
    // <1=> NRF_CLOCK_LF_SRC_XTAL
    // <2=> NRF_CLOCK_LF_SRC_SYNTH
    #ifndef NRF_SDH_CLOCK_LF_SRC
    #define NRF_SDH_CLOCK_LF_SRC 0
    // <o> NRF_SDH_CLOCK_LF_RC_CTIV - SoftDevice calibration timer interval.
    #ifndef NRF_SDH_CLOCK_LF_RC_CTIV
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    // <o> NRF_SDH_CLOCK_LF_RC_TEMP_CTIV - SoftDevice calibration timer interval under constant temperature.
    // <i> How often (in number of calibration intervals) the RC oscillator shall be calibrated
    // <i> if the temperature has not changed.
    #ifndef NRF_SDH_CLOCK_LF_RC_TEMP_CTIV
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    // <o> NRF_SDH_CLOCK_LF_ACCURACY - External clock accuracy used in the LL to compute timing.
    // <0=> NRF_CLOCK_LF_ACCURACY_250_PPM
    // <1=> NRF_CLOCK_LF_ACCURACY_500_PPM
    // <2=> NRF_CLOCK_LF_ACCURACY_150_PPM
    // <3=> NRF_CLOCK_LF_ACCURACY_100_PPM
    // <4=> NRF_CLOCK_LF_ACCURACY_75_PPM
    // <5=> NRF_CLOCK_LF_ACCURACY_50_PPM
    // <6=> NRF_CLOCK_LF_ACCURACY_30_PPM
    // <7=> NRF_CLOCK_LF_ACCURACY_20_PPM
    // <8=> NRF_CLOCK_LF_ACCURACY_10_PPM
    // <9=> NRF_CLOCK_LF_ACCURACY_5_PPM
    // <10=> NRF_CLOCK_LF_ACCURACY_2_PPM
    // <11=> NRF_CLOCK_LF_ACCURACY_1_PPM
    #ifndef NRF_SDH_CLOCK_LF_ACCURACY
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
  • i
    Thanks for your help!
    I've changed sdk_config.h, exactly as you mentioned; unfortunately it doesn't work!
    Any suggestion, what shoud I verify also!
  • Maybe some issue with the GPIO pins used for UART.
    Try to comment out this from main(), and see if it advertises then.
    //uart_init();
    //printf("\r\nUART started.\r\n");
  • not working also!
    I've tried with ble_peripheral ->ble_app_uart
    (\nRF5_SDK_17.0.2_d674dde\examples\ble_peripheral\ble_app_uart\pca10040\s112\arm5_no_packs) tested by UART terminal (Termite) works fine
    Today I change to (SEGGER Embedded Studio) and every thing is working well; the module start advertising.
    In addition when debugging with Keil I got the following error:
    *** error 35: undefined line number.
