Libuarte send and receive String
I am trying to send and receive strings using examples\peripheral\libuarte. I am trying to send a string like this but not receiving it on another board. Also how can I check coming data? Means how can I perform some action based on coming data?
Thanks!
  • Also, I have sent one command and getting data in a loop like this.
     * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup libuarte_example_main main.c
     * @ingroup libuarte_example
     * @brief Libuarte Example Application main file.
     * This file contains the source code for a sample application using libuarte.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "nrf_libuarte_async.h"
    #include "nrf_drv_clock.h"
    #include <bsp.h>
    #include "nrf_log_ctrl.h"
    #include "nrf_queue.h"
    NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
    static uint8_t text[] = "UART example started5.\r\nLoopback:\r\n";
    static uint8_t text_size = sizeof(text);
    static volatile bool m_loopback_phase;
    typedef struct {
        uint8_t * p_data;
        uint32_t length;
    } buffer_t;
    NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
    void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
        nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
        ret_code_t ret;
        switch (p_evt->type)
            case NRF_LIBUARTE_ASYNC_EVT_ERROR:
                bsp_board_led_invert(0);
            case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
                ret = nrf_libuarte_async_tx(p_libuarte,p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (ret == NRF_ERROR_BUSY)
                    buffer_t buf = {
                        .p_data = p_evt->data.rxtx.p_data,
                        .length = p_evt->data.rxtx.length,
                    ret = nrf_queue_push(&m_buf_queue, &buf);
                    APP_ERROR_CHECK(ret);
                bsp_board_led_invert(1);
                m_loopback_phase = true;
                printf("Rx Done");
            case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
                if (m_loopback_phase)
                    nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                    if (!nrf_queue_is_empty(&m_buf_queue))
                        buffer_t buf;
                        ret = nrf_queue_pop(&m_buf_queue, &buf);
                        UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
                bsp_board_led_invert(2);
                printf("Tx Done");
        ret_code_t ret = nrf_drv_clock_init();
        ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
        nrf_libuarte_async_config_t nrf_libuarte_async_config = {
                .tx_pin     = TX_PIN_NUMBER,
                .rx_pin     = RX_PIN_NUMBER,
                .baudrate   = NRF_UARTE_BAUDRATE_9600,
                .parity     = NRF_UARTE_PARITY_EXCLUDED,
                .hwfc       = NRF_UARTE_HWFC_DISABLED,
                .timeout_us = 100,
                .int_prio   = APP_IRQ_PRIORITY_LOW
        err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
        nrf_libuarte_async_enable(&libuarte);
        //err_code = nrf_libuarte_async_tx(&libuarte, text, sizeof(text));
        static uint8_t command[]="AT+GSN\r\n";
        err_code = nrf_libuarte_async_tx(&libuarte, command,sizeof(command) );
        while (true)
            NRF_LOG_FLUSH();
  • Make sure that the string you want to send is defined as a variable, e.g. static uint8_t command[] should work, since this will cause the string to exist in RAM. You should not point to a string that is placed in FLASH, which is the case in the picture in your original case desription.
    Also, I suggest that you check the return code from nrf_libuarte_async_tx(), if it's NRF_ERROR_BUSY you should retry until NRF_SUCCESS.
    I do believe the \nRF5_SDK_17.0.2_d674dde\examples\peripheral\libuarte example show both TX and RX.
    If it still fails you need to connect a logic analyzer to measure the RX and TX pins to see what is received and sent during an transaction.
    Kenneth
  • Muqarrab said:
    Is there any other way as I have to send many AT commands?
    You don't need many variables, instead update the command data once a transfer is finished.
    Muqarrab said:
    I am trying to get complete data but receive like one byte. How can receive complete string?
    You might need to assemble the received data, so if you receive 1byte, you may need to copy it to a variable until the entire string is received.
    Kenneth
  • You might need to assemble the received data, so if you receive 1byte, you may need to copy it to a variable until the entire string is received.
    How can I check that complete data is received?
  • I have made this function to send string(successfully received on another controller) but I have to put a 1-sec delay after one command.
    Is there any callback check which I can add in this function to wait until sending data?
    Thanks
    bool send_command(char cmd[],int size_cmd)
        ret_code_t err_code;
        printf("Sending : ");
        printf(cmd);
        printf("\n");
        memset(command, 0, sizeof(command));
        for (int i=0;i<size_cmd;i++)
          command[i]=cmd[i];
        while(err_code==NRF_ERROR_BUSY); // Is this correct??
        send_command("Muqarrab",sizeof("Muqarrab"));
        nrf_delay_ms(1000);
        send_command("Rahman",sizeof("Rahman"));
  • Looking at: https://sites.google.com/site/vmacgpsgsm/understanding-at-commands
    I can find that "Responses start and end with <CR><LF>."
    So I assume you could check if you receive <CR><LF>?
    CR= carriage return
    LF= line feed
    See ascii table for hex values: https://www.asciitable.com/
  • I have read this post.
    I also don't want to save the data in the queue and resend on tx. I want to send AT commands and want to check the response immediately. I am not getting how to do this. Can you please help?
                    buffer_t buf = {
                //while(ret==NRF_ERROR_BUSY)
                //printf("Data : %s\n",p_evt->data.rxtx.p_data);
                printf("Data1 : %s\n",p_evt->data.rxtx.p_data);
                if(p_evt->data.rxtx.p_data==0x0D  || p_evt->data.rxtx.p_data=='\r')
                  printf("Completed\n");
                printf("Rx Called\n");
                        buffer_t buf;
                printf("Tx Called\n");
                    buffer_t buf = {
                        buffer_t buf;
