Platform: NRF52810
Emulator: JLink EDU Mini
JLink: JLinkV750a
NRFJPROG: 10.13.0
OS: Windows 10
> nrfjprog -f nrf52 --log nrfjlink.log --program D:\Program Files\Fitmind Tools\firmware\FirmwareQC_1629937893.hex --chiperase --reset
Parsing image file.
ERROR: [SeggerBackend] - JLinkARM.dll ReadMemU32 detected a read error 1.
ERROR: [SeggerBackend] - This typically indicates the read was blocked by a memory protection mechanism.
ERROR: [ nRF52] - Failed while erasing file D:\Program Files\Fitmind Tools\firmware\FirmwareQC_1629937893.hex.
ERROR: [SeggerBackend] - JLinkARM.dll WriteU32 returned error -1.
ERROR: nrfjprog failed for an unknown reason. Run the same command again with
ERROR: argument --log, contact Nordic Semiconductor and provide the generated
ERROR: log.log file to them.
here is log
[2021-Aug-26 17:25:46] [ info] --------------------------------------------------------------------------------
[2021-Aug-26 17:25:46] [ info] nrfjprog -f nrf52 --log nrfjlink.log --program D:\Program Files\Fitmind Tools\firmware\FirmwareQC_1629937893.hex --chiperase --reset
[2021-Aug-26 17:25:46] [ info] nrfjprog version 10.13.0
[2021-Aug-26 17:25:46] [ info] Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
[2021-Aug-26 17:25:46] [ info] Library loaded, loading member functions.
[2021-Aug-26 17:25:46] [ info] Member functions succesfully loaded.
[2021-Aug-26 17:25:46] [debug] [ Client] - open
[2021-Aug-26 17:25:46] [debug] [ Client] - start
[2021-Aug-26 17:25:46] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence ab876006-92f1-44f2-b2cc-3eb475260a1d.
[2021-Aug-26 17:25:46] [trace] [ Client] - Command open executed for 29 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ Client] - enum_emu_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2021-Aug-26 17:25:46] [debug] [ JLink] - Logger sink registered in JLink logger
[2021-Aug-26 17:25:46] [debug] [ nRF52] - open
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - open_dll
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2021-Aug-26 17:25:46] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLinkARM.dll.
[2021-Aug-26 17:25:46] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2021-Aug-26 17:25:46] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - dll_version
[2021-Aug-26 17:25:46] [ info] [SeggerBackend] - Segger dll version 7.50.a loaded.
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command open executed for 9 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - enum_emu_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - is_connected_to_emu
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - enum_emu_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_get_num_emus
[2021-Aug-26 17:25:46] [trace] [ Client] - Command enum_emu_snr executed for 19 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command enum_emu_snr executed for 5 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ Client] - connect_to_emu_with_snr
[2021-Aug-26 17:25:46] [debug] [ nRF52] - connect_to_emu_with_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Segger logging enabled.
[2021-Aug-26 17:25:46] [trace] [ JLink] - Firmware: J-Link EDU Mini V1 compiled Jun 24 2021 14:29:39
[2021-Aug-26 17:25:46] [trace] [ JLink] - Decompressing FW timestamp took 182 us
[2021-Aug-26 17:25:46] [trace] [ Client] - Command connect_to_emu_with_snr executed for 127 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ Client] - read_device_info
[2021-Aug-26 17:25:46] [trace] [ JLink] - Hardware: V1.00
[2021-Aug-26 17:25:46] [trace] [ JLink] - S/N: 801017188
[2021-Aug-26 17:25:46] [trace] [ JLink] - OEM: SEGGER
[2021-Aug-26 17:25:46] [trace] [ JLink] - Feature(s): FlashBP, GDB
[2021-Aug-26 17:25:46] [trace] [ JLink] - TELNET listener socket opened on port 19021
[2021-Aug-26 17:25:46] [trace] [ JLink] - WEBSRV Starting webserver
[2021-Aug-26 17:25:46] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 23.624ms returns "O.K."
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_HasError()
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_Lock()
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_GetHWStatus(...)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.215ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.004ms returns 0x01
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.009ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.005ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.020ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.765ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_SetSpeed(2000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.144ms
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_GetSN()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.011ms returns 801017188
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - read_debug_port_idr
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - read_debug_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - coresight_configure
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.897ms returns 0
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.350ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0x2BA01477
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.320ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.016ms
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 126 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - read_device_info
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_IsOpen()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.014ms returns 0x01
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_read_device_version
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_readback_status
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_is_ctrl_ap_available
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - read_access_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_read_access_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.272ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0xF0000040
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.280ms returns 0
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_select_access_port_register
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.308ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0x02880000
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.347ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.360ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.271ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.323ms returns 0
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.295ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0x00000001
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.392ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.453ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.415ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.337ms returns 0
[2021-Aug-26 17:25:46] [ info] [ nRF52] - Protection status read as NONE
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - read_u32
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_connect_to_device
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - is_connected_to_device
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_IsConnected()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.007ms returns FALSE
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.008ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("device = nRF52", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - Device "NRF52" selected.
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.798ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_Connect()
[2021-Aug-26 17:25:46] [trace] [ JLink] - InitTarget() start
[2021-Aug-26 17:25:46] [trace] [ JLink] - J-Link Script File: Executing InitTarget()
[2021-Aug-26 17:25:46] [trace] [ JLink] - InitTarget() end
[2021-Aug-26 17:25:46] [trace] [ JLink] - Found SW-DP with ID 0x2BA01477
[2021-Aug-26 17:25:46] [trace] [ JLink] - DPIDR: 0x2BA01477
[2021-Aug-26 17:25:46] [trace] [ JLink] - AP map detection skipped. Manually configured AP map found.
[2021-Aug-26 17:25:46] [trace] [ JLink] - AP[0]: AHB-AP (IDR: Not set)
[2021-Aug-26 17:25:46] [trace] [ JLink] - AP[0]: Core found
[2021-Aug-26 17:25:46] [trace] [ JLink] - AP[0]: AHB-AP ROM base: 0xE00FF000
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Found Cortex-M4 r0p1, Little endian.
[2021-Aug-26 17:25:46] [trace] [ Client] - Command read_device_info executed for 139 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ Client] - read_memory_descriptors
[2021-Aug-26 17:25:46] [trace] [ JLink] - -- Max. mem block: 0x000013E0
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000EDF0)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE0002000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - FPUnit: 6 code (BP) slots and 2 literal slots
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000EDFC)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE000EDFC)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE0001000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE0001000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000ED88)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0xE000ED88)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CoreSight components:
[2021-Aug-26 17:25:46] [trace] [ JLink] - ROMTbl[0] @ E00FF000
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(64 bytes @ 0xE00FF000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE000EFE0)
[2021-Aug-26 17:25:46] [trace] [ JLink] - ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB000 SCS
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0001FE0)
[2021-Aug-26 17:25:46] [trace] [ JLink] - ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(32 bytes @ 0xE0002FE0)
[2021-Aug-26 17:25:46] [trace] [ JLink] - ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 119.356ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORE_GetFound()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.026ms returns 0xE0000FF
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_read_u32
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_invalidate_cache
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ExecCommand("InvalidateCache", ...).
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.039ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Data: 0A 00 00 00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.563ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Data: 01 00 00 00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.448ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_decode_device_version
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.007ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x10000110, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x10000110)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Data: C0 00 00 00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.449ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.012ms
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command read_device_info executed for 126 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ Client] - Command read_memory_descriptors executed for 14 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - read_memory_descriptors
[2021-Aug-26 17:25:46] [trace] [ Client] - Command read_memory_descriptors executed for 15 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.037ms returns 0x01
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_read_memory_descriptors
[2021-Aug-26 17:25:46] [debug] [ Client] - read_page_sizes
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.341ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.393ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.385ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.412ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.408ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.405ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.406ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.381ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.419ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.452ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.420ms returns 0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - update_device_memory_list
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.448ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.437ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.431ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.376ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.449ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.409ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.396ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.441ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.042ms returns TRUE
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.020ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ Client] - Command read_page_sizes executed for 0 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.570ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.042ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.592ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.436ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Read memory description from family DLL: "Flash" [0x00000000-0x00030000] 48 pages (48x4kB) static ID0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Read memory description from family DLL: "Code RAM" [0x00800000-0x00806000] 6 pages (6x4kB) static ID8388608
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Read memory description from family DLL: "FICR" [0x10000000-0x10001000] 1 pages (1x4kB) static ID268435456
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Read memory description from family DLL: "UICR" [0x10001000-0x10002000] 1 pages (1x4kB) static ID268439552
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Read memory description from family DLL: "RAM" [0x20000000-0x20006000] 6 pages (6x4kB) static ID536870912
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.057ms
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command read_memory_descriptors executed for 12 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.022ms returns 0x01
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.366ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.377ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.400ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.354ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.353ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.317ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.300ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.329ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.344ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.327ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.379ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.303ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.334ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.328ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.335ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.008ms returns TRUE
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.401ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.006ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.465ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.004ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.423ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Memory list already constructed. Skipping.
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.023ms
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command read_memory_descriptors executed for 9 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ nRF52] - read_page_sizes
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.020ms returns 0x01
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_read_page_sizes
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.015ms
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command read_page_sizes executed for 0 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.015ms returns 0x01
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.013ms
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.018ms
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.013ms returns 0x01
[2021-Aug-26 17:25:46] [debug] [ Client] - erase
[2021-Aug-26 17:25:46] [debug] [ nRF52] - erase_file
[2021-Aug-26 17:25:46] [debug] [ nRF52] - init_device_info
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.314ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.372ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.331ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.326ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.307ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.336ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.010ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.490ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.430ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Select AP 1, DP Bank 255, AP Bank 15
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.292ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.383ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.332ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.296ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.284ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.278ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.313ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.428ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.470ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - is_bprot_enabled
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_is_bprot_enabled
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.330ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.399ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.232ms returns 0
[2021-Aug-26 17:25:46] [trace] [ Client] - Command erase_file executed for 44 milliseconds with result -104
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.429ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.322ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.441ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.499ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x40000600, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x40000600)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Data: 00 00 00 00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x40000604, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x40000604)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.478ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_read_u32
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_halt
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_Halt()
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 3.975ms returns 0x00
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0xE000ED94, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0xE000ED94)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.496ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [warning] [ nRF52] - Erase action ERASE_ALL redirects to function NRFJPROG_erase_all.
[2021-Aug-26 17:25:46] [debug] [ nRF52] - erase_all
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_is_eraseprotect_enabled
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_erase_all
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.403ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.287ms returns 0
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - halt
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_nvmc_config_control
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - write_u32
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_write_u32
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_WriteU32_64(0x4001E504, 0x00000002)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0x4001E504)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.832ms returns 0 (0x00000000)
[2021-Aug-26 17:25:46] [debug] [ nRF52] - Just_nvmc_wait_for_ready
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_ReadMemU32(0x4001E400, 0x1 Items)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_ReadMem(4 bytes @ 0x4001E400)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.402ms returns 1 (0x1)
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_WriteU32_64(0x4001E50C, 0x00000001)
[2021-Aug-26 17:25:46] [trace] [ JLink] - CPU_WriteMem(4 bytes @ 0x4001E50C)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.489ms returns 0 (0x00000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - failed
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 1.469ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [error] [SeggerBackend] - JLinkARM.dll ReadMemU32 detected a read error 1.
[2021-Aug-26 17:25:46] [error] [SeggerBackend] - This typically indicates the read was blocked by a memory protection mechanism.
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 1.317ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 1.355ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 1.402ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 1.378ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [error] [ nRF52] - Failed while erasing file D:\Program Files\Fitmind Tools\firmware\FirmwareQC_1629937893.hex.
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command erase_file executed for 34 milliseconds with result -104
[2021-Aug-26 17:25:46] [debug] [ nRF52] - close
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.040ms returns 0x01
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - close
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - disconnect_from_emu
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.034ms returns TRUE
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.514ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0x00000000
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - power_debug_region
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_write_debug_port_register
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x50000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.289ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - Value=0xA0000000
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Disable trace before closing connection.
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_WriteU32_64(0xE000EDFC, 0x00000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - Debug reg: DEMCR
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.967ms returns -1 (0xFFFFFFFF)
[2021-Aug-26 17:25:46] [error] [SeggerBackend] - JLinkARM.dll WriteU32 returned error -1.
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - ---just_abort_debug_action
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.298ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.044ms returns 0 (0x00000000)
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Shortcut, lock is on and debug region is powered.
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - unpower_debug_and_system_regions
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.373ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - - 0.546ms returns 0
[2021-Aug-26 17:25:46] [trace] [ JLink] - JLINK_Close()
[2021-Aug-26 17:25:46] [debug] [SeggerBackend] - Segger Backend closed.
[2021-Aug-26 17:25:46] [debug] [ nRF52] - nRF family DLL closed
[2021-Aug-26 17:25:46] [trace] [ Client] - Command close executed for 73 milliseconds with result 0
[2021-Aug-26 17:25:46] [debug] [ Client] - terminate
[2021-Aug-26 17:25:46] [trace] [ Client] - Command terminate executed for 15 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command close executed for 56 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
[2021-Aug-26 17:25:46] [trace] [ Worker] - Executed 19 commands for 377 milliseconds
[2021-Aug-26 17:25:46] [debug] [ Client] - Worker process exited with code: 0
[2021-Aug-26 17:25:46] [debug] [ Client] - Child process terminated with result 0
[2021-Aug-26 17:25:46] [trace] [ Client] - Executed 19 commands for 475 milliseconds
