app_uart_init() function error:
I wanted to add uart in ble_custom_template project. I have added UART and FIFO Libraries in User include Libraries. Also i set the bits for uart in sdk_config.h. Still I get following error.
Linking xyz.elf
Output/Release/Obj/smart_cap_v1/modbus_handle.o: in function `uart_init':
undefined reference to `app_uart_init'
Build failed
I read other Q and A also as lot of people have this error. But didnt get promisable answer. Please guide me for the same.
Thank you in advance.
Regards.
  • This is really frustrating that I have done everything to get rid of this error but not having the success. Please reply as soon as possible.
    Thanks in advance.
    Regards.
    What toolchain are you using? Have you remembered to add the path of the source files to the project?
    regards
    Jared
    I solved the problem by adding some macro definations from uart example to my project which are not in my project. It solved my error. But right now, I have a problem with app_uart_get function though I can see the data on RX pin. Also it seems NRF_DRV_UART_EVT_RX_DONE is generated.
    void data_send_uart(uint8_t slaveaddress,uint8_t fn_code,uint16_t start_address,uint16_t number_of_pts)
      char crc_data[2]={0};
      uint8_t data_write[8];
      uint8_t len,Index=0;
      unsigned char CRCLo = 0xff;
      unsigned char CRCHi = 0xff;
      unsigned char *puchMsg;
      uint16_t crc;
      data_write[0]=slaveaddress;
      data_write[1]=fn_code;
      data_write[2]=start_address/256;
      data_write[3]=start_address%256;
      data_write[4]=number_of_pts/256;
      data_write[5]=number_of_pts%256;
      len=sizeof(data_write)-2;
      puchMsg= data_write;
      while(len--)
        Index = CRCLo ^ *puchMsg;
        puchMsg++;
        CRCLo = CRCHi ^ auchCRCHi[Index];
        CRCHi = auchCRCLo[Index];
      data_write[6]=CRCLo;
      data_write[7]=CRCHi;
      printf("CRC Low Byte : %x\n",data_write[6]);
      printf("CRC High Byte : %x\n",data_write[7]);
      printf("data sent :\n");
      for(int i=0;i<sizeof(data_write);i++)
        printf("%x\n",data_write[i]);
        uint8_t i;
        for(i = 0; i < sizeof(data_write); i++)
            while (app_uart_put(data_write[i]) != NRF_SUCCESS);
    static void on_read(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
        uint32_t time = 0;
        ret_code_t err_code;
        char rx_data[8];
        ble_gatts_evt_rw_authorize_request_t  req = p_ble_evt->evt.gatts_evt.params.authorize_request;
        data_send_uart(21,4,0,1);
        nrf_delay_ms(500);
        //while(uart_received_flag==0);
        uart_received_flag=0;
        //err_code=app_uart_get(rx_data[0]);
        for(int i=0;i<8;i++)
            err_code=app_uart_get(&rx_data[i]);
            printf("error code %d",err_code);
        printf("Rx data :%s",rx_data);
        if(req.type == BLE_GATTS_AUTHORIZE_TYPE_READ){
            ble_gatts_rw_authorize_reply_params_t response;
            response.params.read.gatt_status = BLE_GATT_STATUS_SUCCESS;
            response.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
            response.params.read.update = 1;
            response.params.read.offset = 0;
            response.params.read.len =strlen(data);
            response.params.read.p_data = (uint8_t *)data;
            err_code=sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle, &response);
            //NRF_LOG_INFO("Reply function responded with: %d", err_code);
    This is my OnRead Function when there is a read Command and on which we respond to that command
    sd_ble_gatts_rw_authorize_reply function. In this function I am sending some MODBUS Data to my
    controller (right now i am just shorting TX and RX for testing) and trying to get the data which
    will be present in RX_FIFO and for that, i am using app_uart_get. But everytime I get ERROR CODE 5
    which is NRF_ERROR_NOT_FOUND. Please guide me.
    Thank you so much.
    Regards.
    Good that you solved the problem.
    NRF_ERROR_NOT_FOUND is returned if If no byte is available in the RX buffer of the app_uart module.
    regards
    Jared
    Can you tell me how to receive the data ?
    Can you provide me the snippet?
    Thanks.
