Unaligned memory access Fault using mbedTLS on nrf5340 cpuapp
I took the RSA example in /nrf/samples/crypto/rsa and added a function foo() to it. I am using nrf5340DK with nrfConnect v1.6.1 and build for cpuapp.
my function foo() uses mbedtls functions heavily and makes a call to mbedtls_entropy_init(entropy)
 I get the following exception when the mbedtls_entropy_init(entropy)  function is called from foo().
os: ***** USAGE FAULT *****
os:   Unaligned memory access
r0/a1:  0x00000000  r1/a2:  0x00000000  r2/a3:  0x200331d4
r3/a4:  0x00022845 r12/ip:  0x00000000 r14/lr:  0x00004621
os:  xpsr:  0x69000000
os: Faulting instruction address (r15/pc): 0x00023be8
os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
os: Current thread: 0x200003c8 (unknown)
fatal_error: Resetting system
here is the stack call.
mbedtls_entropy_init( &drbg->entropy );
mbedtls_mutex_init( &ctx->mutex );
mutex_init_platform(){
     p_mutex = (struct k_mutex *)mutex->mutex;  //p_mutex is NOT aligned 0x00022875
     k_mutex_init(p_mutex);
k_mutex_init(p_mutex) --> z_impl_k_mutex_init()
mutex->owner = NULL; <<----- exception happens here.
The rsa program itself makes a call to mutex_init_platform() as well. I checked all the values of p_mutex and all of them are aligned by 8 bytes. However my mbedtls calls leads to unaligned p_mutex values.
I appreciate if you could help me resolve this issue.
