Hello.
Now, I'm trying to make a Beacon with updatable Major Value, based on sample 'ble_app_beacon'.
I'm not really familiar with BLE and Nordic device, though...
I know the format of iBeacon. Also, I need to make the device connectable (maybe scannable as well) to update data.
I've investigated numerous samples but nothing is decisive.
Below is my code.
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "bsp.h"
#include "nrf_soc.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "ble_advdata.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_spi_mngr.h"
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#if defined (LEGACY_DEFINE)
#undef NRFX_DEFINE
#define NRFX_DEFINE LEGACY_DEFINE
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
//#define APP_BLE_OBSERVER_PRIO 1 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
//#define NON_CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define CONNECTABLE_ADV_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH 0x17 /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH 0x15 /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE 0x02 /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI 0xC3 /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
//#define APP_COMPANY_IDENTIFIER 0x0059 /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_COMPANY_IDENTIFIER 0x004C /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE 0x01, 0x02 /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE 0x03, 0x04 /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID 0x01, 0x12, 0x23, 0x34, \
0x45, 0x56, 0x67, 0x78, \
0x89, 0x9a, 0xab, 0xbc, \
0xcd, 0xde, 0xef, 0xf0 /**< Proprietary UUID for Beacon. */
#define APP_SIGNAL_OUT 0xc3 /**< Proprietary SIGNAL OUT for Beacon. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#if defined(USE_UICR_FOR_MAJ_MIN_VALUES)
#define MAJ_VAL_OFFSET_IN_BEACON_INFO 18 /**< Position of the MSB of the Major Value in m_beacon_info array. */
#define UICR_ADDRESS 0x10001080 /**< Address of the UICR register used by this example. The major and minor versions to be encoded into the advertising data will be picked up from this location. */
static ble_gap_adv_params_t m_adv_params; /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an encoded advertising set. */
#define UPDATE_MS 5000
#define BEACON_INTERVAL APP_TIMER_TICKS(UPDATE_MS)
APP_TIMER_DEF(m_beacon_timer_id); // Timer ID
static volatile bool m_beacon_timer_flag = false; // Timer Flag
#define APP_SPIS_SCK_PIN 26
#define APP_SPIS_MOSI_PIN 29
#define APP_SPIS_MISO_PIN 30
#define APP_SPIS_CS_PIN 31
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
//#define TEST_STRING_RS 0x1E, 0x00, 0x00
//static uint8_t m_tx_buf_rs[] = TEST_STRING_RS; /**< TX buffer. */
//static uint8_t m_rx_buf_rs[sizeof(TEST_STRING_RS) + 1]; /**< RX buffer. */
//static const uint8_t m_length_rs = sizeof(m_tx_buf_rs); /**< Transfer length. */
uint8_t m_rx_buf_rs[];
//#define TEST_STRING_RD 0xA6, 0x00, 0x00
//static uint8_t m_tx_buf_rd[] = TEST_STRING_RD; /**< TX buffer. */
//static uint8_t m_rx_buf_rd[sizeof(TEST_STRING_RD) + 1]; /**< RX buffer. */
//static const uint8_t m_length_rd = sizeof(m_tx_buf_rd); /**< Transfer length. */
uint8_t m_rx_buf_rd[];
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf_rs[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf_rs, strlen((const char *)m_rx_buf_rs));
if (m_rx_buf_rd[0] != 0)
NRF_LOG_HEXDUMP_INFO(m_rx_buf_rd, strlen((const char *)m_rx_buf_rd));
// BLE FUNCTIONS
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
.adv_data =
.p_data = m_enc_advdata,
.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX
.scan_rsp_data =
.p_data = NULL,
.len = 0
//static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] = /**< Information advertised by the Beacon. */
APP_DEVICE_TYPE, // Manufacturer specific information. Specifies the device type in this
// implementation.
APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
// manufacturer specific data in this implementation.
APP_BEACON_UUID, // 128 bit UUID value.
APP_MAJOR_VALUE, // Major arbitrary value that can be used to distinguish between Beacons.
APP_MINOR_VALUE, // Minor arbitrary value that can be used to distinguish between Beacons.
APP_MEASURED_RSSI // Manufacturer specific information. The Beacon's measured TX power in
// this implementation.
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
* @details Encodes the required advertising data and passes it to the stack.
* Also builds a structure to be passed to the stack when starting advertising.
uint32_t err_code;
ble_advdata_t advdata;
//uint8_t flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
uint8_t flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
ble_advdata_manuf_data_t manuf_specific_data;
manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
// If USE_UICR_FOR_MAJ_MIN_VALUES is defined, the major and minor values will be read from the
// UICR instead of using the default values. The major and minor values obtained from the UICR
// are encoded into advertising data in big endian order (MSB First).
// To set the UICR used by this example to a desired value, write to the address 0x10001080
// using the nrfjprog tool. The command to be used is as follows.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val <your major/minor value>
// For example, for a major value and minor value of 0xabcd and 0x0102 respectively, the
// the following command should be used.
// nrfjprog --snr <Segger-chip-Serial-Number> --memwr 0x10001080 --val 0xabcd0102
uint16_t major_value = ((*(uint32_t *)UICR_ADDRESS) & 0xFFFF0000) >> 16;
uint16_t minor_value = ((*(uint32_t *)UICR_ADDRESS) & 0x0000FFFF);
uint8_t index = MAJ_VAL_OFFSET_IN_BEACON_INFO;
m_beacon_info[index++] = MSB_16(major_value);
m_beacon_info[index++] = LSB_16(major_value);
m_beacon_info[index++] = MSB_16(minor_value);
m_beacon_info[index++] = LSB_16(minor_value);
manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
manuf_specific_data.data.size = APP_BEACON_INFO_LENGTH;
// Build and set advertising data.
memset(&advdata, 0, sizeof(advdata));
advdata.name_type = BLE_ADVDATA_NO_NAME;
advdata.flags = flags;
advdata.p_manuf_specific_data = &manuf_specific_data;
// Initialize advertising parameters (used when starting advertising).
memset(&m_adv_params, 0, sizeof(m_adv_params));
//m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
m_adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
m_adv_params.p_peer_addr = NULL; // Undirected advertisement.
m_adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
//m_adv_params.interval = NON_CONNECTABLE_ADV_INTERVAL;
m_adv_params.interval = CONNECTABLE_ADV_INTERVAL;
m_adv_params.duration = 0; // Never time out.
//m_adv_params.duration = 10; // Never time out.
m_adv_params.scan_req_notification = 1; //VLS
err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
* @brief Function for starting application timers.
* @param None.
* @retval None.
static void application_timers_start(void)
ret_code_t err_code;
// Start application timers.
err_code = app_timer_start(m_beacon_timer_id, BEACON_INTERVAL, NULL);
err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
* @brief Function for stopping advertising.
* @param None.
* @retval None.
static void advertising_stop(void)
err_code = sd_ble_gap_adv_stop(m_adv_handle);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
case BLE_GAP_EVT_SCAN_REQ_REPORT:
NRF_LOG_INFO("RSSI %d",p_ble_evt->evt.gap_evt.params.scan_req_report.rssi);
// No implementation needed.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing LEDs. */
static void leds_init(void)
ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
/**@brief Function for initializing timers. */
static void timers_init(void)
/*static void power_management_init(void)
nrf_pwr_mgmt_run();
static void update_beacon_data(void)
uint8_t m_tx_buf_rs[3] = {0x1E, 0x00, 0x00}; /**< TX buffer. */
m_rx_buf_rs[sizeof(m_tx_buf_rs) + 1]; /**< RX buffer. */
uint8_t m_tx_buf_rd[3] = {0xA6, 0x00, 0x00}; /**< TX buffer. */
m_rx_buf_rd[sizeof(m_tx_buf_rd) + 1]; /**< RX buffer. */
// beacon update
advertising_stop();
nrf_gpio_cfg_output(APP_SPIS_CS_PIN);
nrf_gpio_pin_set(APP_SPIS_CS_PIN);
memset(m_rx_buf_rs, 0, m_length_rs);
memset(m_rx_buf_rd, 0, m_length_rd);
spi_xfer_done = false;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf_rs, m_length_rs, m_rx_buf_rs, m_length_rs));
nrf_delay_ms(5);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf_rd, m_length_rd, m_rx_buf_rd, m_length_rd));
//nrf_delay_ms(10);
nrf_delay_ms(5);
m_beacon_info[18] = m_rx_buf_rd[2];
m_beacon_info[19] = m_rx_buf_rd[3];
advertising_init();
advertising_start();
* @brief Function for application main entry.
// Initialize.
//NRF_POWER->TASKS_CONSTLAT = 1;
log_init();
timers_init();
leds_init();
//power_management_init();
ble_stack_init();
advertising_init();
NRF_LOG_INIT(NULL);
// Start execution.
NRF_LOG_INFO("Beacon started.");
//application_timers_start();
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = APP_SPIS_CS_PIN;
spi_config.miso_pin = APP_SPIS_MISO_PIN;
spi_config.mosi_pin = APP_SPIS_MOSI_PIN;
spi_config.sck_pin = APP_SPIS_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
//memset(m_rx_buf, 0, m_length);
//spi_xfer_done = false;
//APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
/*while (!spis_xfer_done)
__WFE();
//APP_ERROR_CHECK(nrf_drv_spis_init(&spis_2, &spis_config, spis_event_handler2));
// Enter main loop.
for (;; )
idle_state_handle();
update_beacon_data();
I changed parameter to 'BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED'.
However, it is not scannable and conectable.
Do you have any specific idea to make it?
My environment are the custom board with nRF52832 and SDK17.0.2.
Kindly Regards,
Shigeto
