Ncs1.2.0 cannot be upgraded to ncs1.6.0
I need to upgrade NCS1.2.0 to NCS1.6.0, the application firmware is downloaded successfully, but after restarting the IC, it still runs the previous application.I think there should be an error in bootloader.
Here is boot's log:
*** Booting Zephyr OS build v2.1.99-ncs1 ***
[00:00:00.003,021] [0m<inf> mcuboot: Starting bootloader[0m
[00:00:00.009,185] [0m<inf> mcuboot: Primary image: magic=bad, swap_type=0x1, copy_done=0x2, image_ok=0x2[0m
[00:00:00.019,042] [0m<inf> mcuboot: Boot source: none[0m
[00:00:00.024,505] [0m<inf> mcuboot: Swap type: test[0m
[00:00:10.972,961] [1;31m<err> mcuboot: Image in the secondary slot is not valid![0m
[00:00:11.204,101] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
[00:00:11.211,730] [0m<inf> mcuboot: Jumping to the first image slot[0m
How can this issue be solved?
Thanks.
    This is probably because the new version has a different flash partitoning scheme than the old version.
    In, NCS, the partitioning scheme is decided dynamically for each build by the Partition Manager.
    in the build folder for your old version, there should be a pm.yml file.
    If you copy it to your new project folder, and rename it to pm_static.yml, it should apply the old flash partitioning scheme to your new project.
    You can read more in the Partition Manager documentation.
    Didrik
  • I have done the tests. I copied pm.yml from nCS1.2.0\ bootloader\ McUboot \boot\zephyr\ to nCS1.6.0\ bootloader\ McUboot \boot\zephyr\ and renamed it pm_static.yml,In CmakeLists. TXT added
    set(PM_STATIC_YML_FILE
    ${CMAKE_CURRENT_SOURCE_DIR}/configuration/${BOARD}/pm_static_${CMAKE_BUILD_TYPE}.yml
    Unfortunately, it doesn't work.
    It still says: "Image in the secondary slot is not valid!" ,then " Jumping to the first image slot "
    Did I do something wrong?
  • You should copy <your 1.2.0 build directory>/partitions.yml (sorry for writing the wrong name previously) to <your 1.6.0 project directory> (where you have your CMakeLists.txt and prj.conf files), and rename it to pm_static.yml.
    You do not need to add anything to your CMakeLists.txt file if you rename it to pm_static.yml.
  • I have done as you suggested.but it does not work.I provide two "partitions.yml" files from ncs1.2.0 and 1.6.0
    Could you help me see how to do it?
     from 1.6.0
    app:
    address: 0x18200
    end_address: 0x7e000
    region: flash_primary
    mcuboot:
    address: 0x0
    end_address: 0xc000
    placement:
    before:
    - mcuboot_primary
    mcuboot_pad:
    address: 0xc000
    end_address: 0xc200
    placement:
    align:
    start: 0x1000
    before:
    - mcuboot_primary_app
    mcuboot_primary:
    address: 0xc000
    end_address: 0x86000
    orig_span: &id001
    - spm
    - mcuboot_pad
    - app
    sharers: 0x1
    span: *id001
    mcuboot_primary_app:
    address: 0xc200
    orig_span: &id002
    - app
    - spm
    span: *id002
    mcuboot_secondary:
    address: 0x86000
    end_address: 0x100000
    placement:
    after:
    - mcuboot_primary
    align:
    start: 0x1000
    share_size:
    - mcuboot_primary
    nrf_modem_lib_ctrl:
    address: 0x20010000
    end_address: 0x200104e8
    inside:
    - sram_nonsecure
    placement:
    after:
    - spm_sram
    - start
    region: sram_primary
    nrf_modem_lib_rx:
    address: 0x200124e8
    end_address: 0x200144e8
    inside:
    - sram_nonsecure
    placement:
    after:
    - nrf_modem_lib_tx
    nrf_modem_lib_sram:
    address: 0x20010000
    orig_span: &id003
    - nrf_modem_lib_ctrl
    - nrf_modem_lib_tx
    - nrf_modem_lib_rx
    span: *id003
    nrf_modem_lib_tx:
    address: 0x200104e8
    end_address: 0x200124e8
    inside:
    - sram_nonsecure
    placement:
    after:
    nvs_storage:
    address: 0x7e000
    end_address: 0x84000
    placement:
    before:
    - settings_storage
    otp:
    address: 0xff8108
    end_address: 0xff83fc
    region: otp
    settings_storage:
    address: 0x84000
    placement:
    before:
    - end
    spm:
    address: 0xc200
    end_address: 0x18200
    inside:
    placement:
    before:
    - app
    spm_sram:
    address: 0x20000000
    end_address: 0x20010000
    inside:
    - sram_secure
    placement:
    after:
    - start
    sram_nonsecure:
    address: 0x20010000
    end_address: 0x20040000
    orig_span: &id004
    - sram_primary
    - nrf_modem_lib_tx
    - nrf_modem_lib_rx
    span: *id004
    sram_primary:
    address: 0x200144e8
    sram_secure:
    address: 0x20000000
    orig_span: &id005
    - spm_sram
    span: *id005
    from 1.2.0
    app:
    address: 0x18200
    mcuboot:
    address: 0x0
    placement:
    before:
    - mcuboot_primary
    mcuboot_pad:
    address: 0xc000
    placement:
    align:
    start: 0x1000
    before:
    mcuboot_primary:
    address: 0xc000
    orig_span: &id001
    - spm
    - app
    - mcuboot_pad
    sharers: 0x1
    span: *id001
    address: 0xc200
    orig_span: &id002
    - app
    - spm
    span: *id002
    mcuboot_secondary:
    address: 0x86000
    placement:
    after:
    - mcuboot_primary
    align:
    start: 0x1000
    share_size:
    - mcuboot_primary
    spm:
    address: 0xc200
    inside:
    placement:
    before:
    - app
  • The two .yml files looks compatible, so it might not be the flash partitioning scheme that is the problem.
    What file are you using when you try to upgrade the firmware?
