Random beacon value(UUID, TxPower, RSSI, ...) on nRF52840 with NRF52 SDK 17.0.2
Hi developer,
I am trying to understand Beacon behavior and program. I am using BLE_Central multilink example to get informaiton from Beacons.
I added the below code in the function "ble_evt_handler" from main.c.
case BLE_GAP_EVT_ADV_REPORT:
            printf("Advertise received.\n");
            scan_start();
            bsp_board_led_on(CENTRAL_SCANNING_LED);
            memmove(uuid, p_gap_evt->params.adv_report.data.p_data, p_gap_evt->params.adv_report.data.len);
            printf("UUID: %02x%02x%02x%02x%02x%02x\t", uuid[0], uuid[1], uuid[2], uuid[3], uuid[4], uuid[5]);
            printf("TX_POWER: %d\t", p_gap_evt->params.adv_report.tx_power);
            printf("RSSI: %d\n", p_gap_evt->params.adv_report.rssi);
            //nrf_ble_scan_on_adv_report(p_scan_data, p_adv_report);
            //printf("Address = %d\t TxPower = %d\t RSSI = %d\n", p_adv_report->direct_addr.addr, p_adv_report->tx_power, p_adv_report->rssi);
        } break;
My beacons are off, but I got values and the values not from beacons are still printed even after the beacons are turned on.
I couldn't receive the beacon values.
Should I add something more?
Thanks for your help
  • Hi!
    The BLE Central Multilink sample has a name filter enabled to filter out all advertising packets without the name "Nordic_Blinky", so I don't think these packets should be making their way to the application layer at all.
    Have you modified the code at all, a part from the portion you showed in your ticket?
    I will test this a bit here, to see if my understanding is correct.
    I can also suggest setting up a BLE sniffer and Wireshark to see all BLE packets, and to check if your Beacons are advertising.
    Heidi
  • Hi again, you must have modified more of the code because uuid is not defined in the event handler so the code doesn't run. What SDK version are you on?
