Problems adding Bluetooth LE support to Azure IoT hub sample.
I'm using the Azure Iot hub example a base for a new project I'm working on.
I've copied the example into its own folder, and can run it and connect my Azure IoT hub.
So far so good.
Next I want to add bluetooth support to this project, so that I can send Bluetooth LE sensor data to the hub.
I've had a look into the LTE gateway example, and copied the CONFIG_BT stuff into my own prj.conf file.
Initially I had problems with the HCI driver, but that seems to be resolved.
When I run my program I get an error at runtime:
ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:307
k_sem_take failed with err -11
[00:00:12.785,217] [1;31m<err> os: r0/a1: 0x00000003 r1/a2: 0x00000000 r2/a3: 0x00000001[0m
[00:00:12.785,247] [1;31m<err> os: r3/a4: 0x00012e8d r12/ip: 0x00001000 r14/lr: 0x00015e7d[0m
[00:00:12.785,247] [1;31m<err> os: xpsr: 0x41000000[0m
[00:00:12.785,247] [1;31m<err> os: Faulting instruction address (r15/pc): 0x00015e88[0m
[00:00:12.785,247] [1;31m<err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0[0m
[00:00:12.785,247] [1;31m<err> os: Current thread: 0x20015600 (unknown)[0m
(This also happens if I comment out all the Azure / LTE init code from the example)
Here's the configuration I've added or modified
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_BT=y
CONFIG_BT_HCI=y
CONFIG_BT_H4=y
CONFIG_BT_WAIT_NOP=y
CONFIG_BT_CENTRAL=y
CONFIG_BT_GATT_CLIENT=y
CONFIG_BT_GATT_DM=y
CONFIG_BT_SCAN=y
CONFIG_BT_SCAN_FILTER_ENABLE=y
CONFIG_BT_SCAN_UUID_CNT=1
CONFIG_BT_DEBUG_HCI_CORE=y
CONFIG_BT_DEBUG_HCI_DRIVER=y
CONFIG_BT_DEBUG_LOG=y
