nRF52832 custom board; RF antenna design and tuning
Hello, I am brand new to antenna design and especially antenna tuning and want to know if my antenna tuning design/method would work.
First I will be tuning with a VMA (nanoVGA-F V2) where I will connect from the SMA on the VMA to a u.FL connection (J1) on my board. You can see this in the schematic below.
I am using the Rainsun AN9520-245 antenna (LINK) as well.
After the capacitor (C12) and inductor (L3)  (I believe these should always be used??), I added the u.FL connector to hook up to the VMA and then I have added a 49.9 Ohm resistor to match the antenna impedance of 50 Ohm while also leaving some resistance for the traces.
All of the 0 Ohm resistors are SMD_0603. I plan to take these off and add applicable capacitors and inductors in their place while tuning. I also did this layout for the resistors so that it covers both T and Pi tuning layouts that could possibly happen.
I will get these test capacitors and inductors from these two links LINK and LINK. I feel like these small values will be good for tuning purposes but the most important thing is that they are SMD_0603 so they will fit in place of the 0 Ohms resistors.
The layout of the board is above. I read a lot of different things about how to go about this and I tried to stick to those design concepts like not having anything under the antenna, ground vias around the "keep out zone", keep chip-to-antenna trace as short as possible, etc. Is there anything else that I may not be doing correctly layout-wise?
Is this a good way to go about tunning my antenna and are there any issues with my layout/design?
Any help is greatly appreciated!
