how Enhanced ShockBurst (ESB) to achive multi tx device some msg to the same rx device using nrf52832
now I had achived the function to communication using the esb in nrf52832 that one to one,but I need to achive multi tx device to one.
if there not doc for me to achive this funciton
thanks you
best wish
  • thank your reply
    Do you mean that I can realize the function of many-to-one communication without making any changes and using examples directly?
    using examples\proprietary_rf\esb_prx as center
    usging  examples\proprietary_rf\esb_ptx as multi salve
    and they will work as I want?
    The examples does not demonstrate multiple pipes (conceptually addresses) out of the box, but I believe app pipes are enabled by default so you could start using them. For instance, the Tx example always use pipe 0 by default (this is set by NRF_ESB_CREATE_PAYLOAD). However, you can specify another pipe by modifying the payload struct before calling nrf_esb_write_payload(). So with SDK 17.0.2, you could add a line as shown here to use another pipe:
            tx_payload.noack = false;
            tx_payload.pipe = 4; // Specify pipe
            if (nrf_esb_write_payload(&tx_payload) == NRF_SUCCESS)
  • thank your replay greatly
    as the code in prx example:
    uint8_t base_addr_0[4] = {0xE7, 0xE7, 0xE7, 0xE7};
    uint8_t base_addr_1[4] = {0xC2, 0xC2, 0xC2, 0xC2};
    uint8_t addr_prefix[8] = {0xE7, 0xC2, 0xC3, 0xC4, 0xC5, 0xC6, 0xC7, 0xC8 };
    My understanding is :
    there are 8 addr for ptx to communication:
    addr1: 0xE7, 0xE7, 0xE7, 0xE7 , 0xE7
    addr2: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC2
    addr3: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC3
    addr4: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC4
    addr5: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC6
    addr6: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC7
    addr7: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC8
    addr8: 0xC2, 0xC2, 0xC2, 0xC2 , 0xC9
    is that right?
    And if you want ptx to send data to prx using addr5,you should set the code like below?
    tx_payload.pipe = 5; // Specify pipe
    If my understanding above is right,the next  few question I want to confirm is
    1、Will different PTX devices using the same address cause interference
    2、If the PRX opens 8 pips, can it accept data from 8 addr ?
    Not really. But in that case the received could not distinguish between the transmitters, unless you have something in the data that has information about it. Also, acknowledgment packets might be confusing if device use the same address (ACK can be disabled though, if you do not need retransmissions on packet loss).
    However, you would get interference if multiple Tx devices send data at the same time, regardless of if they use the same address or not. If the signal strength at the receiver is about the same that would typically cause packet loss. If one is much stronger than the other, the strong signal could be received whiteout any issue.
    Yes.
