Utilizing waveshare e-paper display on nRF52840 dongle with Zephyr RTOS
Hi Sir/Mdm,
I want to use 1.54 inch e-paper module from waveshare with nRF52840 dongle with Zephyr RTOS.
I have read the documentation from Zephyr about the display and noticed that the display can only be used with a board that provides a configuration for Arduino connectors and defines node aliases for SPI and GPIO interfaces (see Shields for more details).
However, based on the board configuration code provided by zephyr in nrf52840dongle_nrf52840.dts, it doesn't come with a configuration for Arduino connectors like in nrf52840dk_nrf52840.dts did.
Hence, I added
arduino_header: connector {
		compatible = "arduino-header-r3";
		#gpio-cells = <2>;
		gpio-map-mask = <0xffffffff 0xffffffc0>;
		gpio-map-pass-thru = <0 0x3f>;
		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
			   <1 0 &gpio0 4 0>,	/* A1 */
			   <2 0 &gpio0 28 0>,	/* A2 */
			   <3 0 &gpio0 29 0>,	/* A3 */
			   <4 0 &gpio0 30 0>,	/* A4 */
			   <5 0 &gpio0 31 0>,	/* A5 */
			   <6 0 &gpio1 1 0>,	/* D0 */
			   <7 0 &gpio1 2 0>,	/* D1 */
			   <8 0 &gpio1 3 0>,	/* D2 */
			   <9 0 &gpio1 4 0>,	/* D3 */
			   <10 0 &gpio1 5 0>,	/* D4 */
			   <11 0 &gpio1 6 0>,	/* D5 */
			   <12 0 &gpio1 7 0>,	/* D6 */
			   <13 0 &gpio1 8 0>,	/* D7 */
			   <14 0 &gpio1 10 0>,	/* D8 */
			   <15 0 &gpio1 11 0>,	/* D9 */
			   <16 0 &gpio1 12 0>,	/* D10 */
			   <17 0 &gpio1 13 0>,	/* D11 */
			   <18 0 &gpio1 14 0>,	/* D12 */
			   <19 0 &gpio1 15 0>,	/* D13 */
			   <20 0 &gpio0 26 0>,	/* D14 */
			   <21 0 &gpio0 27 0>;	/* D15 */
and
arduino_spi: &spi3 {
	status = "okay";
	sck-pin = <47>;
	miso-pin = <46>;
	mosi-pin = <45>;
	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
into the nrf52840dongle_nrf52840.dts file and it does build without giving an error.
These are the pins config in the waveshare_epaper.overlay file I'm supposed to connect:
E-paper display Pins
Arduino Pins
nRF52840 dongle Pins
Vcc
5V
5V
GND
GND
GND
DIN
D11
P1.13
CLK
D13
P1.15
CS
D10
P1.12
DC
D9
P1.11
RST
D8
P1.10
BUSY
D7
P1.08
The problem I'm facing is there are only a few pins on the dongle that I could connect them directly, hence I'll need to do some configuration.
These are the steps that I tried and it didn't work out:
1. I tried matching the original pins (which directly copied from nrf52840dk.overlay) without changing anything but it didn't work because there are only 5 matching pins (including analog pins).
2. I tried with the analog pins cuz there are there are P0.29 and P0.31 match with the dongle and still couldn't work.
3. I tried changing the gpio to match with the pins on the dongle as the example below which I changed the D7, D9 and D10 to P0.xx and it still didn't display anything.
		#gpio-cells = <2>;
			   <13 0 &gpio0 24 0>,	/* D7 */
			   <15 0 &gpio0 20 0>,	/* D9 */
			   <16 0 &gpio0 22 0>,	/* D10 */
4. I tried changing to different digital pins in the epaper.overlay file and didn't manage to get it work as well.
5. I also couldn't find much things related to arduino pins configuration for the nRF52840 dongle.
This is my github repo for the current project.
Please do provide suggestions and solutions that I can try out for this.
Thanks and Regards,
Xian Cong.
