This example I separately burned to the host and slave machine, how to send failed ,This does not require burning softDevice
I use NRF52840. The module of NRF52840 I bought is in China.
Hi
Have you mounted the module on a PCB?
If yes, can you send me a picture of it?
Usually these modules need to be mounted on a PCB with sufficient grounding in order to achieve optimal performance, and the module manufacturer should provide instructions how to design the PCB.
Have you tested with a standard nRF52840DK to see how the range compares?
If you can test with a DK it will show whether or not the issue is related to the hardware you are using.
Best regards
Torbjørn
