HFCLK timer issue
Hi Nordic Engineers,
I have few queries over HFCLK 16 MHz timer.
I am using nrf52840 custom board. IDE - segger embedded studio
#define TIME_IN_US  2600
 * @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
      switch (event_type)
          case NRF_TIMER_EVENT_COMPARE3:
              timerenabled = 1;
              if(!cal_HR_ir_enabled)
                  DisableHRMLed();       //Disabling RED and Enabling IR
                  EnableHRMLed(HR_IR_LED);
                   //printf("Timer IR\r\n");
              else if(!cal_HR_red_enabled)
                  DisableHRMLed();       //Disabling IR and Enabling RED
                  EnableHRMLed(HR_RED_LED);
                   //printf("Timer RED\r\n");
              //Do nothing.
void enable_HR_LED_timer(void)
      uint32_t time_ticks;
      uint32_t err_code = NRF_SUCCESS;
      //Configure TIMER_LED for generating simple light effect - leds on board will invert his state one after the other.
      nrf_drv_timer_config_t led_timer_cfg = NRF_DRV_TIMER_DEFAULT_CONFIG;
      err_code = nrf_drv_timer_init(&TIMER_LED, &led_timer_cfg, timer_led_event_handler);
      //Time(in microseconds) between consecutive compare events.
      time_ticks = nrf_drv_timer_us_to_ticks(&TIMER_LED, TIME_IN_US);
      nrf_drv_timer_extended_compare(
           &TIMER_LED, NRF_TIMER_CC_CHANNEL3, time_ticks, NRF_TIMER_SHORT_COMPARE3_CLEAR_MASK, true);
      nrf_drv_timer_enable(&TIMER_LED);
I have enabled HFCLK timer and able to reach timer callback.
The problem is...If I set the Timeout as 2600 us, it seemed only timer callback was running (not even while(1) )
But in 2700 us or greater, each and every functionalities were working fine.
I have to generate ~250us time delay.
I have attached my code snippet and I am using Timer 3
Looking forward for your suggestion.
Regards
Sudharsan
  • Yeah that can easily take a few millisecons, and it seems like that is a hard-limit for your use-case.
    sudharsan said:
    Should it be possible to see in naked eye ??
     The IR LED probably have some spectral components in the red color range. Or are you talking about the switching frequency?
    What sensor are you using btw?
    -EDIT:
    I see you're using an ADPD410x of some kind, they seems to accept TWI speeds up to 1mbps and SPI speeds upt to 24mbps. At what speed is the TWI bus currently running on?
  • I am using ADPD4101 sensor which is from Analog devices. I was not talking about the color of the LED. Its about fast processing.
    I wish to switch RED and IR LEDs. I have sent you the while(1) block of code also.
    Max speed that we can set in controller side is of 400K right?? SPI cannot be used as I have only I2C provision
    RED on for 250 us (IR should be off) ----- complete off ----- IR on for 250us  (RED should be off) ----- Both off ------ should continue in the same way.
    Its not only switching but also I have to read the FIFO data from the sensor.
    Please have a look at the below model pic.
  • Hey sudharsan, sry for the late response, i got sick with the flu last week :/
     Yes, you're right.
    I don't think that is possible with a 400k TWI bus.
    I suggest you scope the TWI bus and LEDs with a logical analyzer and verify what timings you are actually getting.
  • Hi Haakonsh,
    I have an option to turn on/off the LEDs which is connected ADPD sensor.
    Now its doing well.
    Thanks for your support. Take care
  • I'm glad to hear you've solved the issue, don't hesitate to ask for support in the future :)
