NCS v.1.6.1 migration issue for shell
Dear Nordic,
could you please suggest what should be done to make USB console & shell options work? What should be checked?
It was quite fine on nCS v1.5.1, and completely breaks after migration.
Should note both console & shell & log works on RTT completely, and only console works on USB.
Also, shell over NUS still works fine.
Current settings are:
# Console settings
CONFIG_CONSOLE=y
CONFIG_STDOUT_CONSOLE=y
# RTT settings
# Enable RTT
CONFIG_USE_SEGGER_RTT=y
CONFIG_SEGGER_RTT_MODE_NO_BLOCK_SKIP=y
# enable LOG on RTT
CONFIG_LOG=y
CONFIG_LOG_BACKEND_RTT=y
CONFIG_LOG_OVERRIDE_LEVEL=0
CONFIG_LOG_MAX_LEVEL=4
# CONFIG_LOG_PRINTK is not set
CONFIG_LOG_MODE_OVERFLOW=y
CONFIG_LOG_PROCESS_THREAD=y
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
# console output on RTT
CONFIG_RTT_CONSOLE=y
# USB settings, shell and console
# enable USB
CONFIG_USB=y
CONFIG_USB_DEVICE_STACK=y
CONFIG_USB_DEVICE_PRODUCT="VND"
CONFIG_USB_COMPOSITE_DEVICE=y
CONFIG_USB_SELF_POWERED=y
CONFIG_USB_MAX_POWER=50
# enable CDC ACM ports
CONFIG_SERIAL=y
CONFIG_UART_LINE_CTRL=y
CONFIG_USB_CDC_ACM=y
CONFIG_USB_CDC_ACM_DEVICE_NAME="CDC_ACM"
CONFIG_USB_CDC_ACM_DEVICE_COUNT=2
# enable USB shell on CDC #0
CONFIG_SHELL=y
CONFIG_SHELL_BACKENDS=y
CONFIG_SHELL_BACKEND_SERIAL=y
CONFIG_UART_SHELL_ON_DEV_NAME="CDC_ACM_0"
CONFIG_SHELL_PROMPT_UART="usb:~$ "
CONFIG_SHELL_LOG_BACKEND=n
