I am quite new with nordic environment .
My application is to start 2 pwm instance in opposite polarity (i.e 1 high polarity and another is low polarity with same duty cycle) when got interrupt in gpio pin.
I am able to create the same by using PWM_Library example in SDK .
Here is my code
#define Period 20000 //20ms
#define PIN_IN 22
#define PWM_PIN (11UL)
int duty_1= 20;
static volatile bool ready_flag;
static int gpio_flag =0;
APP_PWM_INSTANCE(PWM1,1);
APP_PWM_INSTANCE(PWM2,2);
void pwm_ready_callback(uint32_t pwm_id) // PWM callback function
ready_flag = true;
void in_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
gpio_flag =1;
static void gpio_init(void)
ret_code_t err_code;
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
in_config.pull = NRF_GPIO_PIN_PULLDOWN;
err_code = nrf_drv_gpiote_in_init(PIN_IN, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(PIN_IN, true);
static void pwm_pin_init(void)
app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(Period, BSP_LED_0);
app_pwm_config_t pwm2_cfg = APP_PWM_DEFAULT_CONFIG_1CH(Period, BSP_LED_1);
pwm1_cfg.pin_polarity [0]= APP_PWM_POLARITY_ACTIVE_HIGH;
pwm2_cfg.pin_polarity [0]= APP_PWM_POLARITY_ACTIVE_LOW;
err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
err_code = app_pwm_init(&PWM2,&pwm2_cfg,pwm_ready_callback);
app_pwm_enable(&PWM1);
app_pwm_enable(&PWM2);
gpio_init();
pwm_pin_init();
uint32_t value;
while(true)
if(gpio_flag == 1)
value = duty_1;
gpio_flag =0;
ready_flag = false;
/* Set the duty cycle - keep trying until PWM is ready... */
while ((app_pwm_channel_duty_set(&PWM1, 0, value))&(app_pwm_channel_duty_set(&PWM2, 0, value)) == NRF_ERROR_BUSY);
/* ... or wait for callback. */
while (!ready_flag);
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM1, 0, value));
APP_ERROR_CHECK(app_pwm_channel_duty_set(&PWM2, 0, value));
// nrf_delay_ms(25);
app_pwm_channel_duty_set(&PWM1, 0, 0);
app_pwm_channel_duty_set(&PWM2, 0, 0);
This code is working properly but I want to set duty cycle inside the interrupt function not in main function .
So how to do so because I tried but without any success.
So guide me .
