Is it possible to check if a KMU slot is used ?
 I am using NCS v1.5.0 and would like to check is a KMU slot is being used or not. I erased the whole SoC and tried reading the directly the registers, in secure mode, as follows:
uint8_t hasKey = 0;
uint8_t i = 0;
for (i = 0; i < 4; i++)
    uint32_t value = NRF_UICR_S->KEYSLOT.KEY[2].VALUE[i];
    if (0xFFFFFFFF != value)
        hasKey = 1;
but the value is always 0xdeaddead. The same value is read when a key was present in the KMU slot.
I searched the NCS libraries and it seems it only supports writing a key into a KMU slot.
Is it possible to check if a KMU slot is in use ?
 Nelson
    From the KMU documentation;
    "Step 2 will be blocked and word 0xDEADDEAD will be returned on AHB if any of the following violations are detected:
    • No key slot selected
    • Key slot not configured as readable
    • Key slot is revoked
    • AHB read to KEYSLOT.KEY[ID-1].VALUE[0-3] registers not belonging to selected key slot"
     I'm not aware of any ways to check this, but you can look at this and this and see if there are any registers you can use for that.
