Reconfig UART RX PIN as GPIO and use it to wake-up 52840. And how to do it using Zephyr UART?
Hi All,
I am new to Zephyr/NCS, so I am a little confused about which UART driver (Zephyr's uart/nrf_libuarte/nrfx_uart/nrfx_uarte) to use to approach this feature with the lowest power consumption:
My custom 52840 board have 2-wire rx/tx connected to a sensor's UART and there is no RTS/CTS.
After received UART data from the sensor, 52840 will wake up and then process the data send by the sensor and then back to sleep again.
The sensor will resend uart data until hear UART response from 52840, so I don't need to worry about data lost.
To do this, my plan is as same as mentioned in Case ID:231801
1. Configuring the rx as GPIO input and configuring the GPIO as wakeup pin with sense low
2. Read the GPIO status, if it is low then deinit the gpio and reinit it as UART
3. After done with the recved UART data, deinit the UART and reinit the rx pin as GPIO
My questions are:
1. Can I use Zephyr's UART/GPIO driver to do this or I must disable Zephyr's driver and use nrfx drivers directly?
2. Doing some search on devzone and it seems I should choose nrfx_uart over nrfx_uarte as enable easyDMA will have higher current consumption, am I correct?
3. Accourding to 1 and 2, which driver should I use? Zephyr's uart or nrf_libuarte or nrfx_uart or nrfx_uarte?
3. Is there any code snippet of init/deinit UART/GPIO in Zephyr/NCS? All I can find on github are using nrf APIs and seems deprecated in NCS 1.6.1.
Anthony
  • Hi Anthony
    Have you checked out the low power UART driver in NCS? It does exactly what you're describing here in terms of enabling the RX channel before setting up the receiver and go to sleep (low power state).
    Simon
  • Hi Simon,
    I came across this thread during my search: can-the-lpuart-be-used-without-the-2-additional-control-lines
    I think I can not take the advantage of lpuart directly, as config the rdy-pin to use the same GPIO as the rx-pin will not work.
    Can I find the source code of how rdy-pin/IRQ is handled by nrf-sw-lpuart? Maybe I can use it as an example to modified my own 2-wire UART application which using IRQ of rx-pin to enable UART receiver.
    Anthony
  • Hi The lpuart source code can be found in \NCS_FOLDER\v1.x.0\nrf\samples\peripheral\lpuart.
    Simon
  • Thanks for the update Simon.
    I read lpuart sample code and it looks like a sample shows how to use 4-wire lpuart but I can not find how it handles rdy-pin.
    I came across this repo NordicPlayground/nrf51-UART-examples and it use below code to set UART off when CTS pin toggled.
    uint32_t app_uart_close(uint16_t app_uart_uid)
        uint16_t gpiote_uid;
        if (app_uart_uid < UART_INSTANCE_GPIOTE_BASE)
            on_uart_event(ON_UART_CLOSE);
            return NRF_SUCCESS;
        gpiote_uid = (app_uart_uid >> 8) & UART_INSTANCE_GPIOTE_BASE;
        if (gpiote_uid != m_gpiote_uid)
            return NRF_ERROR_INVALID_PARAM;
        return app_gpiote_user_disable(m_gpiote_uid);
    /**@brief Function for disabling the UART when entering the UART_OFF state.
    static void action_uart_deactivate(void)
        m_current_state         = UART_OFF;
        NRF_UART0->TASKS_STOPTX = 1;
        NRF_UART0->TASKS_STOPRX = 1;
        NRF_UART0->ENABLE       = (UART_ENABLE_ENABLE_Disabled << UART_ENABLE_ENABLE_Pos);
    But I can not find code handle NRF_UART0 register in NCS1.6.1, seems deprecated?
    Could you let me know which function is the counterpart of app_uart_close() in NCS?
    Anthony
  • Hi Anthony
    Indeed, the development will be somewhat different on NCS than in the nRF5 SDK. The equivalent of app_uart_close() in NCS would be the nrfx_uart_uninit function which uninitializes and closes the UART driver.
    Simon
