create/write txt file in zephyr error.
Im working with nrf52833dk to implement USB mass storage using the flash to write into txt file.
main.c code is:
 * Copyright (c) 2016 Intel Corporation.
 * Copyright (c) 2019-2020 Nordic Semiconductor ASA
#include <zephyr.h>
#include <logging/log.h>
#include <usb/usb_device.h>
#include <fs/fs.h>
#include <stdio.h>
LOG_MODULE_REGISTER(main);
#if CONFIG_DISK_DRIVER_FLASH
#include <storage/flash_map.h>
#if CONFIG_FAT_FILESYSTEM_ELM
#include <ff.h>
#if CONFIG_FILE_SYSTEM_LITTLEFS
#include <fs/littlefs.h>
FS_LITTLEFS_DECLARE_DEFAULT_CONFIG(storage);
static struct fs_mount_t fs_mnt;
static int setup_flash(struct fs_mount_t *mnt)
	int rc = 0;
	unsigned int id;
	const struct flash_area *pfa;
	mnt->storage_dev = (void *)FLASH_AREA_ID(storage);
	id = (uintptr_t)mnt->storage_dev;
	rc = flash_area_open(id, &pfa);
	printk("Area %u at 0x%x on %s for %u bytes\n",
	       id, (unsigned int)pfa->fa_off, pfa->fa_dev_name,
	       (unsigned int)pfa->fa_size);
	if (rc < 0 && IS_ENABLED(CONFIG_APP_WIPE_STORAGE)) {
		printk("Erasing flash area ... ");
		rc = flash_area_erase(pfa, 0, pfa->fa_size);
		printk("%d\n", rc);
	if (rc < 0) {
		flash_area_close(pfa);
	return rc;
static int mount_app_fs(struct fs_mount_t *mnt)
	int rc;
	static FATFS fat_fs;
	mnt->type = FS_FATFS;
	mnt->fs_data = &fat_fs;
	if (IS_ENABLED(CONFIG_DISK_DRIVER_RAM)) {
		mnt->mnt_point = "/RAM:";
	} else if (IS_ENABLED(CONFIG_DISK_DRIVER_SDMMC)) {
		mnt->mnt_point = "/SD:";
	} else {
		mnt->mnt_point = "/NAND:";
#elif CONFIG_FILE_SYSTEM_LITTLEFS
	mnt->type = FS_LITTLEFS;
	mnt->mnt_point = "/lfs";
	mnt->fs_data = &storage;
	rc = fs_mount(mnt);
	return rc;
static void setup_disk(void)
	struct fs_mount_t *mp = &fs_mnt;
	struct fs_dir_t dir;
	struct fs_file_t file;
	struct fs_statvfs sbuf;
	int rc;
	char fname[]="text.txt";
	fs_dir_t_init(&dir);
	fs_file_t_init(&file);
	if (IS_ENABLED(CONFIG_DISK_DRIVER_FLASH)) {
		rc = setup_flash(mp);
		if (rc < 0) {
			LOG_ERR("Failed to setup flash area");
			return;
	if (!IS_ENABLED(CONFIG_FILE_SYSTEM_LITTLEFS) &&
	    !IS_ENABLED(CONFIG_FAT_FILESYSTEM_ELM)) {
		LOG_INF("No file system selected");
		return;
	rc = mount_app_fs(mp);
	if (rc < 0) {
		LOG_ERR("Failed to mount filesystem");
		return;
	/* Allow log messages to flush to avoid interleaved output */
	k_sleep(K_MSEC(50));
	printk("Mount %s: %d\n", fs_mnt.mnt_point, rc);
	rc = fs_statvfs(mp->mnt_point, &sbuf);
	if (rc < 0) {
		printk("FAIL: statvfs: %d\n", rc);
		return;
	printk("%s: bsize = %lu ; frsize = %lu ;"
	       " blocks = %lu ; bfree = %lu\n",
	       mp->mnt_point,
	       sbuf.f_bsize, sbuf.f_frsize,
	       sbuf.f_blocks, sbuf.f_bfree);
	rc = fs_opendir(&dir, mp->mnt_point);
	printk("%s opendir: %d\n", mp->mnt_point, rc);
	if (rc < 0) {
		LOG_ERR("Failed to open directory");
	while (rc >= 0) {
		struct fs_dirent ent = { 0 };
		rc = fs_readdir(&dir, &ent);
		if (rc < 0) {
			LOG_ERR("Failed to read directory entries");
		if (ent.name[0] == 0) {
			printk("End of files\n");
		printk("  %c %u %s\n",
		       (ent.type == FS_DIR_ENTRY_FILE) ? 'F' : 'D',
		       ent.size,
		       ent.name);
	rc = fs_statvfs(fname, &sbuf);
	printk("%s stat: %d\\n", fname, rc);
	if (rc >= 0)
		printk("\\tfn '%s' siz %u\\n" ,sbuf.f_bsize);
	//struct fs_file_t file;
	rc = fs_open(&file, fname, FS_O_CREATE | FS_O_WRITE);
	if (rc < 0)
		printk("FAIL: open %s: %d\\n", fname, rc);
		return;
	uint32_t boot_count = 0;
	if (rc >= 0)
		rc = fs_read(&file, &boot_count, sizeof(boot_count));
		printk("%s read count %u: %d\\n", fname, boot_count, rc);
		rc = fs_seek(&file, 0, FS_SEEK_SET);
		printk("%s seek start: %d\\n", fname, rc);
	boot_count += 1;
	rc = fs_write(&file, &boot_count, sizeof(boot_count));
	printk("%s write new boot count %u: %d\\n", fname,
				 boot_count, rc);
	rc = fs_close(&file);
	printk("%s close: %d\\n", fname, rc);
	(void)fs_closedir(&dir);
	return;
void main(void)
	int ret,rc;
	ret = usb_enable(NULL);
	if (ret != 0) {
		LOG_ERR("Failed to enable USB");
		return;
	LOG_INF("The device is put in USB mass storage mode.\n");
when flash and plug the usb the file storage apeare but the part of creating txt file and write boot_count did not work.
am I missing something?
also can I create csv file in zephyr to write log data?
