Howdy Nordic, hope that you are all well and safe.
Herewith I am reporting a bug I saw in the nrfMesh mobile application.
Information:
nrfMesh V3.1.6
Samsung Galaxy Note 10 Lite (Model number SM-N770F)
Android V11
Kernel V4.9.191-20722114
Steps: (not sure how hard it will be to reproduce but I will explain what I did)
1. Provisioned ~114 nodes
2. Updated one of the nodes via DFU
3. Provisioned the node again (previous node data was not removed from the DB)
Issues observed:
1. Firstly, when I import my network file on different mobile devices:
-> Some devices cannot connect to the provisioned nodes at all (although I can see them)
->On my specific device (as per the information) I can only do one operation on the target node I am connected to i.e. set a publication. After that, all other operations time out. I then have to disconnect, close and open nrfMesh, reconnect to the same device. Then I can do another single operation. Rinse and repeat.
2. Reprovisioned node:
->Cannot do any operations on the configuration server at all
->Same issue as mentioned in 1)
->The old software had 13 models, the new software has a total of 17 models. When I access the the updated node, it shows 17 models. After performing a set publication and going back to the elements on the device, it shows 13.
Things I can think of:
1. Not removing the old node from the database will result in two duplicate UUIDs. I am assuming that you use the UUID as some sort of 'primary key'.
2. Not being able to access the configuration server at all indicates that the wrong device key is probably used to bind the configuration client. I assume the old device key is being used.
Feel free to ask for more information.
Regards
Chris
