Hey there,
while developing a project, which uses a bit more object instances, we encountered the following problem:
When the registration message size from Device to Cloud exceeds the parameter CONFIG_LWM2M_COAP_BLOCK_SIZE, the registration fails with the output
00:00:41.424,011] <err> net_lwm2m_rd_client: Registration err: -12
This is a part of the registration message: H..RFs.- .. 8.rd.(9lwm2m=1.0..ep=[...].lt=600.</>;rt="oma.lwm2m";ct=11543,</32780/0>,</32780/1>,</32780/2>,</32780/3>,</32780/4>,</32780/5>,</32780/6>,</32780/7>, [...]
As the max value for CONFIG_LWM2M_COAP_BLOCK_SIZE is 1024 Bytes, this limits our application to too few instance. The point of failure happens inside the lwm2m engine while appending the instance information. Question is: Is this intended behaviour? Shouldn't it be possible to create a bigger registration message which is then sent over coap blockwise transfer to the server?
Thanks in advance.
using:
nRF9160
ncs v.1.5.1
zephyr v.2.4.99
