Hello All,
I'm currently working on an application with a central and peripheral devices both using nrf52832 with SDK 15.3 and S132.
I'd like for the central to be only trying to connect and attempt pairing/bonding to known peripheral devices.
Since both sides don't have keypad/display, I thought of using Legacy OOB for the pairing.
The same key will be provisioned on the central and one or many peripherals. The central in addition will get the address(es) of the peripheral(s) which it will try to connect to.
That is all fine and seems to be working properly, but my problem is that the central tries to pair (and succeeds) to the peripheral even if it does not have the OOB flag set.
How can I make sure that the central only uses Legacy OOB for pairing?
Here are my security settings on the central:
sec_params.bond = 1; sec_params.mitm = 1; sec_params.lesc = 0; sec_params.keypress = 0; sec_params.io_caps = BLE_GAP_IO_CAPS_NONE; sec_params.oob = 1; sec_params.min_key_size = 7; sec_params.max_key_size = 16; sec_params.kdist_own.enc = 1; sec_params.kdist_own.id = 1; sec_params.kdist_peer.enc = 1; sec_params.kdist_peer.id = 1;
And with these parameters on the peripheral the central got successfully paired:
sec_param.bond = 1; sec_param.mitm = 0; sec_param.lesc = 0; sec_param.keypress = 0; sec_param.io_caps = BLE_GAP_IO_CAPS_NONE; sec_param.oob = 0; sec_param.min_key_size = 7; sec_param.max_key_size = 16; sec_param.kdist_own.enc = 1; sec_param.kdist_own.id = 1; sec_param.kdist_peer.enc = 1; sec_param.kdist_peer.id = 1;
