Libuarte + GSM Communication
I am communicating SIM808 with nRF52840. I have made changes in libuarte example and send AT commands to send SMS. I have the following question.
  1. How can I know that I have received complete data?
  2. How can I send (char) 26 (termination character) at the end of SMS?
  3. Is there any library available for sending sms and MQTT communication?
Thanks!
 * Copyright (c) 2018 - 2020, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup libuarte_example_main main.c
 * @ingroup libuarte_example
 * @brief Libuarte Example Application main file.
 * This file contains the source code for a sample application using libuarte.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_libuarte_async.h"
#include "nrf_drv_clock.h"
#include <bsp.h>
#include "nrf_log_ctrl.h"
#include "nrf_queue.h"
#include "nrf_delay.h"
NRF_LIBUARTE_ASYNC_DEFINE(libuarte, 0, 0, 0, NRF_LIBUARTE_PERIPHERAL_NOT_USED, 255, 3);
static uint8_t text[] = "UART example started5.\r\nLoopback:\r\n";
static uint8_t text_size = sizeof(text);
static volatile bool m_loopback_phase;
static uint8_t command[]="123456789012345123456534623465351235412344123412341234";
unsigned char received_data[50];
int count_data=0;
bool data_completed=false;
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
NRF_QUEUE_DEF(buffer_t, m_buf_queue, 10, NRF_QUEUE_MODE_NO_OVERFLOW);
void uart_event_handler(void * context, nrf_libuarte_async_evt_t * p_evt)
    nrf_libuarte_async_t * p_libuarte = (nrf_libuarte_async_t *)context;
    ret_code_t ret;
    switch (p_evt->type)
        case NRF_LIBUARTE_ASYNC_EVT_ERROR:
            bsp_board_led_invert(0);
        case NRF_LIBUARTE_ASYNC_EVT_RX_DATA:
            //if(((unsigned char)*(p_evt->data.rxtx.p_data)>=0x20&(unsigned char)*(p_evt->data.rxtx.p_data)<=0xFE))
            if((unsigned char)*(p_evt->data.rxtx.p_data)!=0)
                  received_data[count_data]=(unsigned char)*(p_evt->data.rxtx.p_data);
                  count_data=count_data+1;
            //else
            //              printf("%d\n",(unsigned char)*(p_evt->data.rxtx.p_data));
            //if(received_data[count_data-2]==13 &received_data[count_data-1]==10)
            //    printf("Carriage\n");
            //  //data_completed=true;
            m_loopback_phase = true;
//            printf("Rx Called\n");
        case NRF_LIBUARTE_ASYNC_EVT_TX_DONE:
            if (m_loopback_phase)
                nrf_libuarte_async_rx_free(p_libuarte, p_evt->data.rxtx.p_data, p_evt->data.rxtx.length);
                if (!nrf_queue_is_empty(&m_buf_queue))
                    buffer_t buf;
                    ret = nrf_queue_pop(&m_buf_queue, &buf);
                    APP_ERROR_CHECK(ret);
                    UNUSED_RETURN_VALUE(nrf_libuarte_async_tx(p_libuarte, buf.p_data, buf.length));
            bsp_board_led_invert(2);
           // printf("Tx Called\n");
bool send_command(char cmd[],int size_cmd)
    ret_code_t err_code;
    count_data=0;
    for (int i=0;i<25;i++)
      received_data[i]=0;
    printf("Sending  : ");
    printf(cmd);
    memset(command, 0, sizeof(command));
    for (int i=0;i<size_cmd;i++)
      command[i]=cmd[i];
    do {
        err_code = nrf_libuarte_async_tx(&libuarte, command,sizeof(command));
    while (err_code == NRF_ERROR_BUSY);
    nrf_delay_ms(1000);
    printf("Received : %s\n",received_data);
    //char *ret;
    //ret = strstr(received_data, "OK");
    //printf("Response is: %s\n", ret);
    printf("-----------------------------------------------------\n");
    ret_code_t ret = nrf_drv_clock_init();
    ret_code_t err_code = NRF_LOG_INIT(app_timer_cnt_get);
    nrf_libuarte_async_config_t nrf_libuarte_async_config = {
            .tx_pin     = TX_PIN_NUMBER,
            .rx_pin     = RX_PIN_NUMBER,
            .baudrate   = NRF_UARTE_BAUDRATE_9600,
            .parity     = NRF_UARTE_PARITY_EXCLUDED,
            .hwfc       = NRF_UARTE_HWFC_DISABLED,
            .timeout_us = 100,
            .int_prio   = APP_IRQ_PRIORITY_LOW
    err_code = nrf_libuarte_async_init(&libuarte, &nrf_libuarte_async_config, uart_event_handler, (void *)&libuarte);
    nrf_libuarte_async_enable(&libuarte);
    //send_command("AT\n",sizeof("AT\n"));
    //send_command("AT+GSN\n",sizeof("AT+GSN\n"));
    //send_command("AT+CSQ\n",sizeof("AT+CSQ\n"));
    //send_command("AT+CCID\n",sizeof("AT+CCID\n"));
    //send_command("AT+CREG?\n",sizeof("AT+CREG?\n"));
    //send_command("AT+CMGF=1\n",sizeof("AT+CMGF=1\n"));
    //send_command("AT+CMGR=1\n",sizeof("AT+CMGR=1\n"));
    //sim.println("AT+CMGS=\"" + Auth_Number + "\"\r"); //Mobile phone number to send message
    //delay(1000);
    //sim.print(BLE_Feedback);
    //delay(100);
    //sim.println((char)26);// ASCII code of CTRL+Z
    //send_command("AT+CSCS=\"GSM\"\r\n",sizeof("AT+CSCS=\"GSM\"\r\n"));
    send_command("AT+CMGS=\"+923026620366\"\r\n",sizeof("AT+CMGS=\"+923026620366\"\r\n"));
    send_command("Hello World\n",sizeof("Hello World\n"));
    //send_command("\x1a",sizeof("\x1a"));
nrf_serial_write()
    while (true)
        NRF_LOG_FLUSH();
