BLE peripheral whitelist advertising
Dear all,
Can I achieve ble peripheral whitelist advertising without peer manager? (Assuming central address is already known)
Following are several places that I've modified based on ble_app_uart but it will cause an assert:
First part is whitelist address function.
static void whitelist_set()
	ble_gap_addr_t peer_address;
	ble_gap_addr_t const *p_peer_address;
	uint32_t err_code;
	Traget central addr:0x15ca97ce14f4
	peer_address.addr[5] = 0x15;
	peer_address.addr[4] = 0xca;
	peer_address.addr[3] = 0x97;
	peer_address.addr[2] = 0xce;
	peer_address.addr[1] = 0x14;
	peer_address.addr[0] = 0xf4;
	p_peer_address = &peer_address;
	err_code = sd_ble_gap_whitelist_set(&p_peer_address, 0x01);
adding previous function into BLE_ADV_EVT_WHITELIST_REQUEST
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
		case BLE_ADV_EVT_WHITELIST_REQUEST:
            whitelist_set();
			break; //BLE_ADV_EVT_WHITELIST_REQUEST
Enabling the whitelist in adv parameters.
    ble_advertising_init_t init;
    init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
		/* Modified parts */
		init.config.ble_adv_whitelist_enabled          = true;
    init.config.ble_adv_directed_high_duty_enabled = true;
    init.config.ble_adv_directed_enabled           = false;
    init.config.ble_adv_directed_interval          = 0;
    init.config.ble_adv_directed_timeout           = 0;
Did I implement anything wrong or did I miss anything?
Ava
    This looks mostly correct. You should set the address type in the ble_gap_addr_t before calling sd_ble_gap_whitelist_set(), though.
    There could be some other errors also that I do not spot, but in general this looks good.
    Does it not work? If not, how does it fail and does any API call return an error?
  • Hi Einar,
    Could it be that you (like most example) disable whitelisting after some time?
    Probably, but all I can find is "ble_advertising_restart_without_whitelist" in bsp_evt_handler, but it shouldn't be activated unless I touch that button right. Just in case, I commented these lines but it still not works.
    I'm posting the whole main.c codes. The code basically remains what it was like as ble_app_uart.
    I did modifications in:
    1. on_adv_evt
    2. advertising_init
    3. created the function "whitelist set"
    #define DEBUG
    #include "nrf_delay.h"
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
    /* 白名单地址 */
    	uint32_t err_code;
    	地址为:489051eb76f2
    	memset(&peer_address, 0x00, sizeof(peer_address));
    	peer_address.addr_id_peer = 1;
    	peer_address.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
    	peer_address.addr[0] = 0x48;
    	peer_address.addr[1] = 0x90;
    	peer_address.addr[2] = 0x51;
    	peer_address.addr[3] = 0xeb;
    	peer_address.addr[4] = 0x76;
    	peer_address.addr[5] = 0xf2;
    	printf("Setting whitelist...");
    	printf("Setting done!\n");
        uint32_t err_code;
                sleep_mode_enter();
                whitelist_set();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    //        case BSP_EVENT_WHITELIST_OFF:
    //            if (m_conn_handle == BLE_CONN_HANDLE_INVALID)
    //                err_code = ble_advertising_restart_without_whitelist(&m_advertising);
    //                if (err_code != NRF_ERROR_INVALID_STATE)
    //                    APP_ERROR_CHECK(err_code);
    //            break;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    		/* Whitelis settings */
    //    init.config.ble_adv_directed_high_duty_enabled = true;
    //    init.config.ble_adv_directed_enabled           = false;
    //    init.config.ble_adv_directed_interval          = 0;
    //    init.config.ble_adv_directed_timeout           = 0;
    //		memset(&peer_address, 0x00, sizeof(peer_address));
    //	m_advertising.peer_address.addr_id_peer = 1;
    //	m_advertising.peer_address.addr_type = BLE_GAP_ADDR_TYPE_RANDOM_STATIC;
    //	m_advertising.peer_address.addr[0] = 0x48;
    //	m_advertising.peer_address.addr[1] = 0x90;
    //	m_advertising.peer_address.addr[2] = 0x51;
    //	m_advertising.peer_address.addr[3] = 0xeb;
    //	m_advertising.peer_address.addr[4] = 0x76;
    //	m_advertising.peer_address.addr[5] = 0xf2;
    //	m_advertising.adv_params.p_peer_addr = &m_advertising.peer_address;
    //		m_advertising.adv_params.filter_policy = BLE_GAP_ADV_FP_FILTER_BOTH;//CONNREQ;
    //		m_advertising.whitelist_in_use = true;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    Sorry for posting the whole page but I really need your help.
    Appreciate it!
    Best regard,
    Ava
  • Hi Ava,
    I see you are using the advertising module, and in this case it will do a bit behind the scenes. Therefor, (if you continue to use it) you should not use sd_ble_gap_whitelist_set() but rather ble_advertising_whitelist_reply() in your handling of the BLE_ADV_EVT_WHITELIST_REQUEST event. If not, the advertising module will not start advertising with whitelist, as it does not know that the whitelist has been set. You should be able to see this if you enable logging for the advertising module (then it will log the type of advertising every time advertising is started).
  • Hi Ava,
